Gyroscope Module 3-Axis L3G4200D with Propeller
Does this gyro output a 3.3 volt signal or a 5 volt signal? I cannot find in the documentation, and I need to know so I can use a resistor or not. I know the gyro regulates itself down to 2.5 volt so could it also use this for its output?
I found: http://www.pololu.com/file/download/L3G4200D.pdf?file_id=0J491
Excerpt: "Wide supply voltage: 2.4 V to 3.6 V"
It's a 3.3V device.
Link to Gyroscope Module 3-Axis L3G4200D web page at Parallax.com
The Parallax KickStart page has diagrams showing how to connect the gyroscope module to a Basic Stamp Homework Board, a Propeller QuckStart and an Arduino Uno, along with demo code. All they use is some wire.
Link to KickStart page for the L3G4200D Gyroscope Module
