Conflicting Serail Objects — Parallax Forums
davidpzkdavidpzk Posts: 19
edited 2012-01-13 13:41 in Propeller 1
Has anyone else had problems with serial objects conflicting with each other?
I am using "Full-Duplex_COMEngine" to send commands at 300 baud to a serial device.
I am simultaniously using "Parallax Serial Terminal" at 9600 baud to do code troubleshooting and debugging.
When both are started, I get conflicts/unwanted characters/noise on both of them.
If I comment out one or another, all is well.
Anyone else see this happen?
    edited 2012-01-13 10:08
    Yes, This is to be expected.
    You should only use one serial driver per set of IO pins. You can use the same serial driver from multiple cogs by using locks to keep the output from mixing together.
    I believe there's a multicog debug object that takes care of this for you (I haven't used it).
    Kye's objects often use locks, "Full-Duplex_COMEngine" might be usable from multiple cogs (I haven't used it in a long time).
    edited 2012-01-13 10:15
    Welcome to the forum David.
    While I have not used either of the serial objects you mention - I use FullDuplexSerial or my modified version (..._rr004) and do not have any problems at 115,200 baud.
    It may be better to post your code. You can zip it with proptool and post that, or if short, post the code between {code} ... {/code} tags using square brackets instead of the braces shown here.
    A guess could be as simple as not enough stack space.
    edited 2012-01-13 10:32
    David,
    Are the serial objects sharing IO pins? If not, then there's some other problem like Cluso99 suggests.
  • davidpzkdavidpzk Posts: 19
    edited 2012-01-13 11:33
    Howdy guys... Here is my sample code. If you run this, you can see on your terminal window part of the string that is intended to send to pin 7 clearly makes it to pin 30.
    CON
       _clkmode = xtal1 + pll16x
       _xinfreq = 5_000_000
    OBJ
      term : "Parallax Serial Terminal"
      Serial : "Full-Duplex_COMEngine"
    VAR
      Byte RecievedBufferCount [3]
    PUB BootUp
      term.start(1200)
      Serial.COMEngineStart(5,7, 1200)                    'rxpin, txpin, baud
      RecievedBufferCount :=  Serial.receivedNumber
      repeat
        term.str(string("Message to terminal. This is a long looping test to see if we can spot some conflicts or errors between the serial objects",13))
        Serial.WriteString (string("Message to *******************  serial device. This is a long looping test to see if we can spot some conflicts or errors between the serial objects.",13))
        term.str(string("How much info is in Serial recieve buffer \\\"))
        term.str(RecievedBufferCount) '<<<<<<<<<<<<<<<<<<<<<<<<<<<< If you comment out this line, the problem changes
        waitcnt (99999999+cnt)
        term.str(string("///",13))
  • Mike GMike G Posts: 2,702
    edited 2012-01-13 11:44
    RecievedBufferCount is a pointer like RecievedBufferCount[0] assigned to the result of Serial.receivedNumber
    I believe you want something like
    RecievedBufferCount[0] :=  Serial.receivedNumber
    The line below says print from the address RecievedBufferCount until we see a terminating zero.
    edited 2012-01-13 11:54
    Hi Mike G.
    I made your code suggesion chage(s) but still have the same problem. Part of the string that is clearly intended for pin 7 is making it to pin 30.
    See updated code...
    CON
    OBJ
    VAR
    PUB BootUp
      term.start(1200)
      RecievedBufferCount[1] := 0
      'RecievedBufferCount := Serial.receivedNumber
      repeat
    Google return zero hits for "Full-Duplex_COMEngine".
    Could you provide a link?
    edited 2012-01-13 12:01
    I would suggest using the four port serial object if you need multiple serial ports. In your case it sounds like you nedd at least 2 ports, one for your 300 baud device and another for debugging with PST.
    edited 2012-01-13 12:02
    This line...
    Says go to the memory address RecievedBufferCount, which is whatever was in Serial.receivedNumber, then start transmitting until we find a zero. Anything can be in memory starting at Serial.receivedNumber
    edited 2012-01-13 12:08
    Take a look at this...
    CON
    VAR
      Byte buffer[3]
    OBJ
      pst : "Parallax Serial Terminal"
      serial : "FullDuplexSerial"
    PUB Main
      serial.start(5, 7, %0000, 9600)
      pst.start(115200)
      Pause(500)
      ' Lets pretend we received some serial data
      buffer[0] := $41
      buffer[1] := $42
      buffer[2] := $00
      pst.str(@buffer)
    PRI Pause(Duration)
      waitcnt(((clkfreq / 1_000 * Duration - 3932) #> 381) + cnt)
      return
    edited 2012-01-13 12:24
    Ive included the Full-Duplex_COMEngine.spin below.
    In the mean time, Im looking into kwinn's suggestion and seeing if I can make use of the 4port serial object instead...
    edited 2012-01-13 12:33
    David,
    Thanks for posting the driver.
    I like to think I improved a good thing. I have a couple of modified versions of Tim Moore's four port driver here. The 128 byte rx buffer version gives you a bigger buffer at the cost of a few longs in increased program size. (Most of the increase is due to fixing the Dec method's bug in the original.)
    edited 2012-01-13 12:36
    Changing the driver is not going to fix the problem. This is a conceptual issue.
    CON
    OBJ
    VAR
    PUB BootUp | i
      term.start(1200)
      repeat
        'term.str(RecievedBufferCount) '<<<<<<<<<<<<<<<<<<<<<<<<<<<< If you comment out this line, the problem changes
        repeat i from 0 to 2
          term.dec(RecievedBufferCount[i])
    edited 2012-01-13 12:47
    Yes, Mike G's got the fix (to the main problem). You need to use the "dec" method of PST.
    I don't see the need for:
    I think the above code would adds two zeros after number of bytes in the buffer.
    I think this would work.
    term.dec(RecievedBufferCount[0])
    Since only one byte of data was stored. (I think that's what the program is doing.)
    edited 2012-01-13 12:50
    Whatever is clever. I dumped the entire buffer simply for illustration.
    edited 2012-01-13 12:55
    Mike G wrote: »
    Which is a good idea.
    I'd suggest separating the bytes.
          term.str(string(", "))
    Or adding a carraige return between bytes.
    edited 2012-01-13 13:15
    Wow thanks guys.
    The 4 port serial object is really cool. Preliminary tests show it is pretty good at serial traffic control across multiple ports. I dont think I need it for this project but its nice to have around for larger serial project needs. Very good to know it exists!
    Turns out the heart of the problem was me needing to use the term.dec command instead of the term.str command.
    Problem solved.
  • max72max72 Posts: 1,155
    As a side note consider the 4 ports serial object has been shown by Tracy Allen to work better if you start all the ports.
    In case just use -1 as rx/tx pin for the dummy ports..
    http://forums.parallax.com/showthread.php?129776-Anybody-aware-of-high-accuracy-%280.7-or-less%29-serial-full-duplex-driver
    Massimo
