SAY IT, Help
I GET ALL THE WAY TO GENERATE CODE ON THE STAMP GUI. I RUN THE CODE THE SCREEN TURNS BLUE AND i GET A MESSAGE GROUP 0 "WAITING FOR COMMAND". I THOUGHT iWAS USING WORDSET 2 THAT CONTAINED THE WORD SET i WANTED TO USE. hOW DO I GET THE PROGRAM TO USE WORDSET 2 AND WHAT COMMAND WOULD IT BE WAITING FOR. hELP
Thanks for your help but nothing seems to be going right with me and this module. If I wasn't so stubborn I would have given up on it.
There's more information about posting code here:
Dave
' {$PBASIC 2.5}
' COM Parameters
COM_RX PIN 0 ' rx pin
COM_TX PIN 2 ' tx pin
COM_SPEED CON 84 ' baud 9600
COM_10MS CON 10 ' 10ms unit
' Protocol Command
CMD_BREAK CON "b" ' abort recog or ping
CMD_SLEEP CON "s" ' go to power down
CMD_KNOB CON "k" ' set si knob <1>
CMD_LEVEL CON "v" ' set sd level <1>
CMD_LANGUAGE CON "l" ' set si language <1>
CMD_TIMEOUT CON "o" ' set timeout <1>
CMD_RECOG_SI CON "i" ' do si recog from ws <1>
CMD_RECOG_SD CON "d" ' do sd recog at group <1> (0 = trigger mixed si/sd)
' Protocol Status
STS_AWAKEN CON "w" ' back from power down mode
STS_ERROR CON "e" ' signal error code <1-2>
STS_INVALID CON "v" ' invalid command or argument
STS_TIMEOUT CON "t" ' timeout expired
STS_INTERR CON "i" ' back from aborted recognition (see 'break')
STS_SUCCESS CON "o" ' no errors status
STS_RESULT CON "r" ' recognised sd command <1> - training similar to sd <1>
STS_SIMILAR CON "s" ' recognised si <1> (in mixed si/sd) - training similar to si <1>
' Protocol arguments are in the range 0x40 (-1) TO 0x60 (+31) inclusive
ARG_MIN CON 64 ' 0x40
ARG_MAX CON 96 ' 0x60
ARG_ZERO CON 65 ' 0x41
ARG_ACK CON 32 ' 0x20 'TO READ more status arguments
'Groups and Commands
GROUP_1 CON 1 '(Command count: 1)
G1_UNNAMED_COMMAND_0 CON 0
RES_ERROR CON 255
RES_TIMEOUT CON 254
RES_COMMFAIL CON 253
RES_BUILTIN CON 32
'Robot Constant
VRLED PIN 4
'Global Variable
VRA VAR Byte
VRA1 VAR Byte
VRGROUP VAR Byte
VRCOMMAND VAR Byte
' Main Start
INPUT COM_RX
HIGH COM_TX
Restart:
LOW VRLED
VRGROUP = 0
DEBUG CR, "Setting up VRbot... "
'Wake up or stop recognition
GOSUB VR_Wakeup
DEBUG "awake... "
'Set SI Language
VRA1 = 0
GOSUB VR_SetLanguage
DEBUG "language ", DEC VRA1, "... "
'Set 5 seconds timeout
VRA1 = 5
GOSUB VR_SetTimeout
DEBUG "timeout ", DEC VRA1, "... "
DEBUG CR, "VRbot ready!"
VR_Loop:
DEBUG CR, "VRbot in group ", DEC VRGROUP, " waiting for command... "
LOW VRLED
PAUSE 150
IF VRGROUP > 0 THEN HIGH VRLED
VRA1 = VRGROUP
GOSUB VR_RecognizeSD
'-- handle errors or timeout
IF VRA1 = RES_ERROR THEN
DEBUG "error"
'try again in the same group
GOTO VR_Loop
ENDIF
IF VRA1 = RES_TIMEOUT THEN
DEBUG "timed out"
VRGROUP = 0 ' back to trigger
GOTO VR_Loop
ENDIF
IF VRA1 = RES_COMMFAIL THEN
DEBUG "comm failed"
'resync and try again
GOSUB VR_Wakeup
GOTO VR_Loop
ENDIF
'-- got a command
VRCOMMAND = VRA1
IF VRCOMMAND <= RES_BUILTIN THEN GOSUB VR_Action
GOTO VR_Loop
VR_Action:
DEBUG "got ", DEC VRCOMMAND
SELECT VRGROUP
CASE GROUP_1
SELECT VRCOMMAND
CASE G1_UNNAMED_COMMAND_0
PAUSE 0 '-- write your code here
ENDSELECT
ENDSELECT
RETURN
'=== VR Routines ===
' Wake up:
VR_Wakeup:
TOGGLE VRLED
VRA = CMD_BREAK
SEROUT COM_TX, COM_SPEED, [VRA]
SERIN COM_RX, COM_SPEED, 100*COM_10MS, VR_Wakeup, [VRA]
IF (VRA <> STS_SUCCESS) THEN GOTO VR_Wakeup
LOW VRLED
RETURN
' Inputs:
' VRA1 = language index (0 = english, ...)
VR_SetLanguage:
VRA = CMD_LANGUAGE
VRA1 = VRA1 + ARG_ZERO
SEROUT COM_TX, COM_SPEED, [VRA1]
SERIN COM_RX, COM_SPEED, 20*COM_10MS, VR_CommFailed, [VRA]
VRA1 = VRA1 - ARG_ZERO
'IF (VRA <> STS_SUCCESS) THEN GOTO VR_Wakeup
RETURN
' Inputs:
' VRA1 = timeout (in ms, 0=forever, 255=default)
VR_SetTimeout:
VRA = CMD_TIMEOUT
RETURN
' Inputs:
' VRA1 = SI knob (0=loosest, 2=normal, 4=tightest)
VR_SetKnob:
VRA = CMD_KNOB
RETURN
' Inputs:
' VRA1 = SD level (1=easy, 2=default, 5=hard)
VR_SetLevel:
VRA = CMD_LEVEL
RETURN
' Inputs:
' VRA1 = wordset (0=trigger)
' Ouputs:
' VRA1 = result (0-31=word, 32..=builtin, 253=comm err, 254=timeout, 255=error)
VR_RecognizeSI:
VRA = CMD_RECOG_SI
GOTO VR_Recognize0
VR_RecognizeSD:
VRA = CMD_RECOG_SD
VR_Recognize0:
' send Group/WS
' wait for answer
SERIN COM_RX, COM_SPEED, 600*COM_10MS, VR_CommFailed, [VRA]
IF VRA = STS_RESULT THEN
' send ack
VRA = ARG_ACK
' wait for recognised command code
SERIN COM_RX, COM_SPEED, 20*COM_10MS, VR_CommFailed, [VRA1]
ELSEIF VRA = STS_SIMILAR THEN
' send ack
VRA = ARG_ACK
VRA1 = VRA1 - ARG_ZERO + RES_BUILTIN
ELSEIF VRA = STS_TIMEOUT THEN
VRA1 = RES_TIMEOUT
ELSE
VRA1 = RES_ERROR
ENDIF
RETURN
VR_CommFailed:
VRA1 = RES_COMMFAIL
RETURN]
This is the message I get" Vbot in group 0 waiting for command.... Timed out
There aren't any commands in group o. I was trying to work with "2 Wordset" which has the commands I want. I tested the group and all commands were accepted. Then I ran the Generate code command which transferred me to the Stamp GUI with the program listed I hit run and the results above are what I got.
Also, I don't work for Parallax and only check in on the forum randomly. But I do have a Say It program for the BS2 I wrote a year ago, so I do know how to get this working.
