Stepping Boe-Bot forward, not moving normally!
I've noticed that when Boe-Bot navigates with IR (Infrared Headlights), it's actually steping very quickly moving forward cause the "forward subroutine":
Is there any other way to program it without this stepping forwarding and make it move normal?
P.S I copy the full code for examination. The freqout instructions makes Boe-Bot to sound as R2D2 from the StarWars...
Forward:
PULSOUT SERVO_Right,650
PULSOUT SERVO_Left, 850
PAUSE 20
RETURN
' {$STAMP BS2}' {$PBASIC 2.5}
'<------Variables--------->
irDetectLeft VAR Bit
irDetectRight VAR Bit
counter VAR Word 'variable for PULSOUT loop
'<------Constants--------->
SERVO_Left CON 12 ' Right Servo
SERVO_Right CON 13 ' Left Servo
DO
FREQOUT 7,1,38500
irDetectLeft=IN8
FREQOUT 1,1,38500
irDetectRight=IN0
DEBUG HOME, "irDetectLeft= ", BIN1 irDetectLeft,CR, "irDetectRight= ", BIN1 irDetectRight,CR
PAUSE 100
IF (irDetectLeft=0) AND (irDetectRight=0) THEN
DEBUG "R2D2:surprised sound", CR
HIGH 3
HIGH 10
FREQOUT 2, 10, 2000
FREQOUT 2, 10, 2100
FREQOUT 2, 10, 2200
FREQOUT 2, 10, 2300
FREQOUT 2, 30, 2400
FREQOUT 2, 40, 2500
FREQOUT 2, 10, 3000
FREQOUT 2, 10, 3100
FREQOUT 2, 10, 3200
FREQOUT 2, 20, 3500
FREQOUT 2, 90, 3900
FREQOUT 2, 100, 4500
FREQOUT 2, 100, 4000
FREQOUT 2, 10, 3900
FREQOUT 2, 10, 2800
FREQOUT 2, 10, 2700
FREQOUT 2, 30, 2600
FREQOUT 2, 40, 2500
FREQOUT 2, 10, 2200
FREQOUT 2, 10, 2100
FREQOUT 2, 10, 2000
FREQOUT 2, 100, 1000
GOSUB Backwards
GOSUB Turn_Left
GOSUB Turn_Left
ELSEIF (irDetectRight=0) THEN
HIGH 3
DEBUG "R2D2:Musical Scale", CR
FREQOUT 2, 100, 3520
PAUSE 1
FREQOUT 2, 100, 3729
PAUSE 1
FREQOUT 2, 100, 3322
PAUSE 1
FREQOUT 2, 100, 3136
PAUSE 1
FREQOUT 2, 100, 3720
PAUSE 1
FREQOUT 2, 100, 3929
PAUSE 1
FREQOUT 2, 100, 3522
PAUSE 1
FREQOUT 2, 100, 3336
PAUSE 1
FREQOUT 2, 100, 3900
GOSUB Backwards
GOSUB Turn_Left
ELSEIF (irDetectLeft=0) THEN
HIGH 10
PAUSE 1
PAUSE 1
PAUSE 1
PAUSE 1
PAUSE 1
PAUSE 1
PAUSE 1
PAUSE 1
GOSUB Backwards
GOSUB Turn_Right
ELSE
LOW 3
LOW 10
GOSUB Forward
ENDIF
LOOP
Forward:
PAUSE 20
RETURN
Turn_Left:
FOR counter = 1 TO 20
PULSOUT SERVO_Left, 650
PULSOUT SERVO_Right, 650
PAUSE 20
NEXT
RETURN
Turn_Right:
PULSOUT SERVO_Right, 850
PAUSE 20
NEXT
RETURN
Backwards:
FOR counter = 1 TO 40
PAUSE 20
NEXT
RETURN
The Stamp can do only one thing at a time. Normally, in this program, the Stamp does the IR sensing and related decision making in the time between servo control pulses. There's about 20 milliseconds after a servo pulse is generated before the next pulse has to be sent (or the servo shuts down). That's normally enough time for a few PBasic statements including the IR sensing and the other servo's control pulse to be generated. With the DEBUG statements and sound effects, there are huge extra hunks of time used.
thanks for your prompt reply...I will comment the DEBUG statement and the "sound effects" and let you know. Thanks again...
Cheers,
Jessica
I've just commented the DEBUG statement and Voila!!! Boe-Bot is moving forward NORMALLY. Thank you. The FREQOUT commands do not affect considerabley the motion, I left them uncommented...
Jessica, thanks for your reply too. I will follow your instructions and let you know.
