I'll bet erco doesn't have one of these
Phil Pilgrim (PhiPi)
A highly desirable collectible from the early 50's:
But now I'm sure he wants one!
But I suppose I could retrofit one of my robots to be powered by Plywoodium decay. Sort of a slow ongoing outgassing process, AFAIK...
from the 2011 Dangerous toy list:
"Burst balloons
Balloons are all fun and games until they burst. Pieces of burst balloons pose a choking risk for children under 8 years of age, and have caused 86 deaths since 1990. For this reason, U.S. PIRG recommends keeping balloons away from young children completely, and was discouraged to find balloons in stores that were being marketed for infants' and toddlers' birthday parties."
I guess radiation was just safer back then!!
http://www.goldmine-elec-products.com/products.asp?dept=1468
That kit has some interesting parts.
OMG! That is totally awesome! Dunno about erco, but =I= want one!!!
Amanda
Isn't the Plywoodium decay caused by the interaction of a Termiteium particle? :-)
http://unitednuclear.com/index.php?main_page=index&cPath=2_4
http://unitednuclear.com/index.php?main_page=index&cPath=2_5
http://unitednuclear.com/index.php?main_page=index&cPath=2_12
About 15 to 20 years ago you could find old Radiac sets for fifty bucks, steal their Geiger tubes, and make a simple geiger counter. People are trying to sell them for $150 to $250 now, untested. Most of these from the 50s will be useless as is (dry out caps, impossible to find batteries), and the GM tube likely degassed and inoperable.
Heathkit made a nice pocket GM back in the mid 80s. I still have mine, and it still works. So far, no signs of any radioactive flotsam. Or jetsam for that matter.
-- Gordon
I'd never heard of them until I picked up a weird green glowing tube in a load of surplus equipment, and discovered it was an atomic-powered lightbulb!
http://www.nrc.gov/reading-rm/doc-collections/fact-sheets/fs-tritium.html
It's been sitting on my windowsill at home for a few years now, glowing a soft green as the tritium decays.
Also here
I can see why the $50 is a worthwhile investment - reading the fine print it appears the govt was handing out $10,000 bounties if you found a seam of radioactive ore. Wonder how many of those were paid out.
http://www.orau.org/ptp/collection/atomictoys/GilbertU238Lab.htm
I bought and built one of these too. In fact I ordered it from them just as Three Mile Island was happening and I wasn't the only one. Heathkit told me that they instantly had a several month backup on these. I suppose the same thing happened last year and Goldmine is trying to capitalize on this (but might be a little late to the party).
-Katie
Your father didn't also provide you with a Cutie Pie neutron detector to estimate your exposure? Also, IIRC, the silicon gamma detectors of that era required a supply of liquid nitrogen to keep electrical noise below the signal threshold. (BTW, the Teletype machine was probably a Model 33, right?)
While Coleman switched its lantern mantles to nonradioactive yttrium back in the 90's, some other firms still sell Thorium mantles.
Imagine trying to take one of those through airport security these days!
A few years ago, I bought a CD radiation survey meter on eBay for about 30 dollars. These days, after the tsunami and Fukushima event, the same meters are being offered for 3 to 5 times that amount.
At 45+ years old, I doubt it is still in calibration, but it tests properly using the check source on the side and it detects the beta and gamma particles from salt substitute.
I've taken the set with me a couple of times on my rock hunting ventures and it does get the occasional odd stare. :-)
I also have a number of the old CD dosimeters and a charging set. I've charged a couple of them, but so far no indication!
Y'all may want to look at www.nukalert.com if you're interested in pocket-sized radiation detectors.
--Rich
P.S. -- Note the radiation burn on the right side of the kid's face!!
I didn't actually enter do neutron activation; I used the gamma and X-ray sources which were kept on hand to calibrate the gamma detector. And yes, it did live atop a liquid nitrogen dewar; not only did it need to be kept cool to keep the noise down, it had to always stay cool or the lithium would drift out of the silicon crystal and ruin the resolution. Which eventually happened when the department head neglected to keep the dewar full. IIRC that detector was around $5000 in 1974. And yep, the teletype was a 33, somewhere down the years I slipped an 11.
