programming the sumobot with ping
Hello everyone...I've been trying to blend the ping program with the simple sumobot program. I thought my goals were modest but I am a bit overwhelmed at this point after hours of trying to get the program to work. Generally speaking, the code works for everything except for the following: when the sumobot goes forward, I want it to go slow (which it does). When it identifies an opponent, I want it to charge ahead at full speed (which it doesn't do) If the PING senses something it runs a bit smoother than when it doesn't detect anything (a bit chattery) Any help would be appreciated. thanks in advance
Here's the code
' Modified SumoBot-3.3-Simple-Mini-Sumo with Ping.BS2
' {$STAMP BS2}
' {$PBASIC 2.5}
[ I/O Definitions ]
LMotor PIN 13 ' left servo motor
RMotor PIN 12 ' right servo motor
LED PIN 14 ' Red LED active high
Ping PIN 15 ' Parallax Ping))) sensor
LLinePwr PIN 10 ' left line sensor power
LLineIn PIN 9 ' left line sensor input
RLinePwr PIN 7 ' right line sensor power
RLineIn PIN 8 ' right line sensor input
StartLED PIN 0 ' display start delay
[ Constants ]
LFwdFast CON 1000 ' left motor fwd; fast
LFwdSlow CON 770 ' left motor fwd; slow
LStop CON 750 ' left motor stop
LRevSlow CON 730 ' left motor rev; slow
LRevFast CON 500 ' left motor rev; fast
CmConstant CON 2260 ' Calc roundtrip time of sound
MaxDistance CON 20 ' Maximum can measure (empirical)
RFwdFast CON 500 ' right motor fwd; fast
RFwdSlow CON 730 ' right motor fwd; slow
RStop CON 750 ' right motor stop
RRevSlow CON 770 ' right motor rev; slow
RRevFast CON 1000 ' right motor rev; fast
[ Variables ]
lLine VAR Word ' left sensor raw reading
rLine VAR Word ' right sensor raw reading
lineBits VAR Nib ' decoded sensors value
lbLeft VAR lineBits.BIT1
lbRight VAR lineBits.BIT0
cmDistance VAR Word ' Distance in centimeters
time VAR Word ' Round trip echo time
pulses VAR Byte ' counter for motor control
temp VAR Byte
[ EEPROM Data ]
RunStatus DATA $00 ' run status
[ Initialization ]
Reset:
READ RunStatus, temp ' read current status
temp = ~temp ' invert status
WRITE RunStatus, temp ' save for next reset
IF (temp > 0) THEN END ' run now?
Start_Delay:
HIGH StartLED ' show active
PAUSE 5000 ' start delay
LOW StartLED ' LED off
[ Program Code ]
Main:
GOSUB Read_Line_Sensors
BRANCH lineBits, [Go_Fwd, Spin_Left, Spin_Right, About_Face]
Go_Fwd:
PULSOUT LMotor, LFwdSlow
PULSOUT RMotor, RFwdSlow
LOW LED ' LED off before each measurement
PULSOUT 15, 5 ' Start Ping)))
PULSIN 15, 1, time ' Read echo time
cmDistance = cmConstant ** time ' Calculate distance from time
IF cmDistance >= MaxDistance THEN HIGH LED ' Toggle LED if out
' range
PULSOUT LMotor, LFwdFast
PULSOUT RMotor, RFwdFast
GOTO Main
Spin_Left:
FOR pulses = 1 TO 10 ' back up from edge
PULSOUT LMotor, LRevFast
PULSOUT RMotor, RRevFast
PAUSE 20
NEXT
FOR pulses = 1 TO 20
PAUSE 20
NEXT
GOTO Main
Spin_Right:
PAUSE 20
NEXT
PAUSE 20
NEXT
GOTO Main
About_Face:
PAUSE 20
NEXT
FOR pulses = 1 TO 30 ' turn around
PAUSE 20
NEXT
GOTO Main
END
[ Subroutines ]
Read_Line_Sensors:
HIGH LLinePwr ' activate sensors
HIGH RLinePwr
HIGH LLineIn ' discharge caps
HIGH RLineIn
PAUSE 1
RCTIME LLineIn, 1, lLine ' read left sensor
RCTIME RLineIn, 1, rLine ' read right sensor
LOW LLinePwr ' deactivate sensors
LOW RLinePwr
' convert readings to bits
LOOKDOWN lLine, >=[300, 0], lbLeft ' 0 = black, 1 = line
LOOKDOWN rLine, >=[300, 0], lbRight
RETURN
Here's the code
' {$STAMP BS2}
' {$PBASIC 2.5}
[ I/O Definitions ]
[ Constants ]
[ Variables ]
temp VAR Byte
[ EEPROM Data ]
[ Initialization ]
Reset:
Start_Delay:
[ Program Code ]
Main:
Go_Fwd:
' range
GOTO Main
Spin_Left:
PAUSE 20
NEXT
PAUSE 20
NEXT
GOTO Main
Spin_Right:
PAUSE 20
NEXT
PAUSE 20
NEXT
GOTO Main
About_Face:
PAUSE 20
NEXT
PAUSE 20
NEXT
GOTO Main
END
[ Subroutines ]
Read_Line_Sensors:
HIGH RLinePwr
HIGH RLineIn
PAUSE 1
LOW RLinePwr
RETURN
However, I might could help by asking exactly what you have powered by the sumo's voltage regulator?
You might be running into some power issues, if you are trying to draw more then 50ma from the sumo's regulator.
-Tommy
- Deliver a slow motor pulse
- Turn LED off
- Copy ping distance to cmDistance
- If cmDistance is too large, then deliver fast motor pulse
- Go back to main loop
Once you have the logic on paper, it become apparent that your code is delivering a slow pulse no matter what, and then only going fast if the object is out of range. Next, you have to decide what you want to do in the Go_Fwd routine. For example:
- Check ping
- Turn off LED
- If distance > 15, deliver slow pulse & leave LED off
- if distance <=15, LED on and fast pulse
That would translate to a Go_Fwd routine that looks like this. Notice that I put my actual list of actions as comments right above the code. That helps keep your code on the right track.
Go_Fwd: ' Check ping PULSOUT 15, 5 ' Start Ping))) PULSIN 15, 1, time ' Read echo time cmDistance = cmConstant ** time ' Calculate distance from time ' Turn off LED LOW LED ' LED off before each measurement ' if distance > 15, deliver slow pulse & leave LED off ' if distance <= 15, LED on and fast pulse IF cmDistance > 15 THEN PULSOUT LMotor, LFwdSlow PULSOUT RMotor, RFwdSlow ELSE IF cmDistance >= MaxDistance THEN HIGH LED ' light if in range PULSOUT LMotor, LFwdFast PULSOUT RMotor, RFwdFast ENDIF ' Go back to main loop GOTO MainNow, I'm not sure if that's the only bug, but I can tell you that this is a necessary step toward getting the program to work right. One thing the code doesn't show is that I changed maxDistance to from 20 to 15. We don't want the "maxiumum it can measure", because then you are comparing it to a condition it cannot get to, so it'll never happen. You should probably reduce it to 10 for the sake of testing. Once the SumoBot charges at your hand when it's less than 10 cm, then, start testing for a practical distance that works.
Please let me know what happened with the modified Go_Fwd routine.
