Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Propeller IDE problem — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
AIman
531
2012-01-06 21:32
edited 2012-01-10 20:36
in
Propeller 1
How can I fix the letters bleeding over on to each other?
Word doc is attached with a screen print.
IDE Problem.doc
80K
StefanL38
2,292
2012-01-07 01:02
edited 2012-01-07 01:02
did you install the parallax font?
what's your OS? Name and service pack
keep the questions coming
best regards
Stefan
AIman
531
2012-01-07 17:37
edited 2012-01-07 17:37
I downloaded all the installs from the demo board and Hydra (I have both) and don't seem to be able to get anything to work for changing the font.
The OS is XP with SP 3.
StefanL38
2,292
2012-01-08 09:43
edited 2012-01-08 09:43
Hi Alman,
here's another thread about it. Maybe you got the same problem
http://forums.parallax.com/showthread.php?135974-Prop-Tool-(IDE)-fonts-overlap&highlight=font+problem
] font overlap problem solved
best regards
Stefan
AIman
531
2012-01-10 20:36
Thanks - replacing the font did it.
Sign In
Register
to comment.
best regards
Stefan
http://forums.parallax.com/showthread.php?135974-Prop-Tool-(IDE)-fonts-overlap&highlight=font+problem] font overlap problem solved
best regards
Stefan
