Magic IR, universal IR record & playback object
I've been working on a home automation project for a while - Jon's Spin Zone column on Sony SIRCS got me started on IR control. It's an awesome & well documented object, problem was it only worked with SIRCS.
I looked at the other IR objects in the Object Exchange, & they supported NEC & RC5 IR formats, but I was having problems getting it to work with my TV. I needed something dumber, so I built my own object, Magic IR.
Magic IR stores any arbitrary IR code, as received from an IR receiver (I've been using this Vishay, but all others should work) with a max of 128 transitions. Store code is written in pasm, so the transition timing is as high resolution as possible. The stored IR code can then be played back.
Usage is pretty simple, there are just 2 methods;
The playcode method runs in the existing cog - if you've just called storecode, it will pause until storecode completes. Once storecode is done, it will playback the code at 38kHz on the LED connected to the output pin.
This is my first object meant for others to use - it's attached. I also did a video demo. Any suggestions are welcome!
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
magicir : "magicir_010"
VAR
LONG code1[128], code1len
PUB main
magicir.storecode(0, @code1, @code1len)
'' store a code received at pin 0 at code1 with total
'' transition count at code1len
repeat
magicir.playcode(1,@code1,@code1len)
waitcnt(clkfreq + cnt)
'' playback a code with the IR LED connected to pin 1.
'' Code is stored at code1, length at code1len
The storecode method starts a new cog - it will pause until the input pin goes low & will timeout after 1/8 second or 128 transitions have been received.The playcode method runs in the existing cog - if you've just called storecode, it will pause until storecode completes. Once storecode is done, it will playback the code at 38kHz on the LED connected to the output pin.
It fits in with a project I've been kicking around in the back of my mind but haven't found time to work on. Maybe this is the kick I needed.
I did nearly the same thing a while back. It was close to be a candidate for the object exchange, but I paused with my propeller activity for a while. What are the differences:
1. I did not measure the exact timing. Instead I read the signal to build up a timing table. In each IR signal you only have a limited amount of different high- and low-times if you allow some deviation. The longest timings are recognized as pause of the signal, so I only need to store 1 sequence in case of a normal code and 2 sequences in case there are alternating bits in the signal.
2. The signal itself is stored as a list of indexes to this timing table but translated to a string where uppercase letters are pointing to a high time entry and the lowercase letters are pointing to a low time entry. For example:
AaBaBaCb
This way even human can read the signal.
I think the main things are ... the timings are good in reading remote controls. If you have several sets of timings you can detect on the fly which remote control has been used and then search for the key pressed in the right list. For example I want to use an old remote control for easy functions and I found this nice IR keyboard which is of course much better for entering text.
Playback of each code from a list is also easily possible with the recorded string and the timing table.
If you are interested I could post what I have up to now.
I made a project that reacted to a remote command, and then put out another about two seconds latter, very amusing. SHE didn't think so though (it used one of those other sorts of chips).
I am trying to make my own universal remote.
Does Cox cable use some other protocol or freq?
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 receiver = 0 'pin that is attached to ir receiver button = 1 'button that is connect to propeller pin 1 OBJ magicir : "magicir_010" DEBUG : "Parallax Serial Terminal" VAR LONG code1[128], code1len long i,translen,x PUB main DEBUG.start(250000) dira[button]~ DEBUG.clear DEBUG.Position(20,10) debug.str(string("Press Button to record")) repeat if ina[button]==1 magicir.storecode(receiver, @code1, @code1len) waitcnt(clkfreq*3 + cnt) DEBUG.clear debug.str(string(13)) debug.str(string(13)) debug.str(string(13)) x:=1 debug.str(string(" name long ")) repeat i from 0 to code1len x++ debug.dec(code1[i]) if x == 11 debug.str(string(13)) debug.str(string(" long ")) x:=1 elseif i == code1len debug.str(string(13)) debug.str(string(13)) debug.str(string("length long ")) debug.dec(code1len) debug.str(string(13)) else debug.str(string(",")) repeat while ina[button]==0 'wait for button press to clear screen DEBUG.clear DEBUG.Position(20,10) debug.str(string("Press Button to record"))
