I need help finding a size 13 / 3E bicycle shoe
Capt. Quirk
I need to convert my road bike to clip-on's, but I haven't found a manufacturer that produces an extra wide shoe.
Shimano sells a standard "wide" shoe, but it's to narrow.
Does anybody know of a company that sells an extra wide road or mountain bike shoe? or have any advice
for purchasing my first set of clip-on's.
Bill M.
Bill M.
ps: I've found that using clip-in pedals on a bike is the second best thing that you can do to extend your power and efficiency on a bike (the first is to raise the seat up high). It's fun to be able to blast out of a dead stop, and only possible by using each leg through the entire stroke.
SRLM: I have looked at the Shimano shoes. My local bike shop has a size 48 wide in
stock, but it was a 1E width and looked to narrow and a little short.
I have an XL frame (59cm) and my seat post raised 15" above the frame, and my seat
is 45" above the ground. Unfortunately the raised seat post shifted my center of gravity is too
far back. Next time I buy a bike, I will pay more attention to the frame specs.
I also found Giro HV (high volume) shoes; Does anybody have any experience with them?
and check out Northwave, per these posts:
http://beginnertriathlete.com/discussion/forums/thread-view.asp?tid=247448&posts=8
http://www.bikeradar.com/forums/viewtopic.php?p=16189815
P.S. Erco, that chainring is amazing! I can't imagine going as fast downhill as that thing must propel you!
I have 5000 + miles on my mountain bike, and about 1000 on my road bike.. but my brother is just nuts...
-Tommy
That makes two of us, I crossed in '95 on PAC Tour and met all my ultracycling heroes on that trip. That was the beginning of my obsession.
With a bit of work, I can sustain 60+ MPH on the 10-mile downhill into Death Valley. At night, with a van on my butt lighting the way. Fun.
I have no need for speed. If I was green; I would look like Shrek riding a bicycle, and
the "bigger you are, the harder you fall" definitely applies to me.
Phil: I have made similar changes to my bike. When I replaced my 10 speed, I purchased
a Cross-Over style bike for a more comfortable cruising position.
I moved my grips inwards to keep my hands from falling asleep, and installed the bar extenders.
I installed "Grab-On" grips, worked on finding my best CG, and tire combinations.
When I cruise, I place the palms of my hands on the end of the bar extenders.
Erco: thanks for the links
Everybody: Thank You for your input.
Bill M.
http://bicycledreamsmovie.com/trailer.html
