Propeller or the crystal
Currently I'm trying to overclock my propeller to 96Mhz using a 6Mhz crystal. I had to do some tinkering and I've switched one of my QFP44 propellers from one pcb to another as well as the crystal. I'm successfully able to download and run programs with a PLL multiplier of x8 but not x16. I was wondering if the PLL could have been damaged by using my hot air gun on the chip, if the crystal could have been damaged, or is the chip just not liking the 96Mhz run speed?
P.S. The board has a bypass capacitor at every set of power pins as well as several capacitors near the voltage regulator. Before removing the crystal from the old PCB the propeller there worked like a charm.
You may need a 10uF bypass cap at the prop chip to help this - try soldering a tantalum across the smt cap. Your xtal pins also need to be short and you should have a proper ground plane.
A pair (one 0.1 and one 4.7) lie right next to the xtal pins. Another pair lies on the bottom supply pins (pin 1 is the top, xtals are to the right, etc.) and a single 0.1uf lies to the left. There are other caps scattered around the board trying to stick with the one IC one decoupling cap rule.
I had the same setup before on another board and that functioned properly (no pun intended
You may have to post some photos of your pcbs or the layouts.
You could check the margin this has, by slowly lowering Vcc until it stops working, and/or warming the device.
Some vendors 'bin' grade their parts, perhaps Parallax do not quite have the volumes for that ?
Others have a 'sweet spot' spec, that tightens Vcc and sometimes lowers Tj, to also nudge up a speed-grade.
This recognizes that FreqMax is actually a Linear Equation combining Vcc,Tj, f
Then there is always Peltier cooling for the serious over-clocker..
