Image corrupt or truncated
I am trying to toggle the visibility of a red led jpg on my web page when the Spinneret led is told to turn on and off. The The web page works correctly when I am not tied to the Spinneret and am just testing the web page. When I connect to the Spinneret and toggle the led on and off, a generic icon appears and the error console says " Image corrupt or truncated" and the pop up says "The image "view source:http://192.168.1.200:5000/red led.jpg cannot be displayed because it contains errors." I remembered that the html files had to have a 8.3 format, so I changed the red led. jpg to that format with no help. I googled the error and found that it has to do with the file being in the wrong format ie a jpg should be a ico or png or vice versa. . Is there a limitation on the type of file (jpg,png,ico) that I can have on the SD card?
However, it sounds like you want to toggle an image when a link or button is clicked. There's a few way s to do this. What I would do... Use javascipt to set the image src attribute and let the browser do the HTTP get. I used the technique on the Multi-Socket tutorial when you click a link and the image downloads.
<html> <head> <script language="javascript" type="text/javascript"> function DisplayLED (LedID) { var state = document.getElementById(LedID).style.visibility if(state == "hidden") {document.getElementById(LedID).style.visibility="visible"; return getRequest('led/23/on', 'placeholder'); } else {document.getElementById(LedID).style.visibility="hidden"; return getRequest('led/23/off', 'placeholder'); } } </script> <script language="javascript" type="application/javascript"> //Gets the browser specific XmlHttpRequest Object function getXmlHttpRequestObject() { if (window.XMLHttpRequest) { return new XMLHttpRequest(); } else if (window.ActiveXObject) { return new ActiveXObject("Microsoft.XMLHTTP"); } else { alert("Your Browser does not support AJAX!\nIt's about time to upgrade don't you think?"); } } //XmlHttpRequest object var req = getXmlHttpRequestObject(); var htmlTarget; function getRequest(resource, elementId) { // handle the case where a querystring is not detected var char = "&"; if(resource.indexOf("?", 0) == -1) { char = "?"; } if (req.readyState == 4 || req.readyState == 0) { req.open("GET", resource + char + 'ms=' + new Date().getTime(), true); req.onreadystatechange = handleResponse; htmlTarget = elementId; req.send(null); return false; } } function handleResponse() { if (req.readyState == 4) { var str = req.responseText; //alert(str); var placeholder = document.getElementById(htmlTarget); placeholder.innerHTML = str; } } </script> <p>LED: <span id="placeholder">State</span></p> <title>Sanity Ridge Ranch Control Page</title> </head> <body> <div style="width:720px;margin:auto;"> <h1 style="text-align:center;color:blue;">Sanity Ridge Ranch</h1> <h2 style="text-align:center;color:blue;">Home Control Page</h2> <div style=" top: 0px; left: 0px; position: absolute; z-index: 1; visibility: show;"> <div style=" top: 200px; left: 0px; position: absolute; z-index: 1; visibility: show;"> <form> <input type="button" value="Light 1" id="Light1" onClick="DisplayLED ('Led1');" /> <div id="Led1" style=" top: 5px; left: 99px; position: absolute; z-index: 1; visibility: hidden;"> </form><img src="red led.jpg" alt="Red Led" width="20" height="20" /> </div> </div> <div style=" top: 230; left: 0; position: absolute; z-index: 1; visibility: show;"> <form> <input type="button" value="Light 2" id="Light2" onClick="DisplayLED ('Led2');"/> <div id="Led2" style=" top: 5; left: 99; position: absolute; z-index: 1; visibility: hidden;"> </form><img src="red led.jpg" alt="Red Led" width="20" height="20" /> </div> </div> <div style=" top: 260; left: 0; position: absolute; z-index: 1; visibility: show;"> <form> <input type="button" value="Light 3" id="Light3" onClick="DisplayLED ('Led3');"/> <div id="Led3" style=" top: 5; left: 99; position: absolute; z-index: 1; visibility: hidden;"> </form><img src="red led.jpg" alt="Red Led" width="20" height="20" /> </div> </div> <div style=" top: 200; left: 200; position: absolute; z-index: 1; visibility: show;"> <form> <input type="button" value="Light 4"id="Light4" onClick="DisplayLED ('Led4');" /> <div id=Led4 style=" top: 5; left: 99; position: absolute; z-index: 1; visibility: hidden;"> </form><img src="red led.jpg" alt="Red Led" width="20" height="20" /> </div> </div> <div style=" top: 230; left: 200; position: absolute; z-index: 1; visibility: show;"> <form> <input type="button" value="Light 5" id="Light5" onClick="DisplayLED ('Led5');" /> <div id=Led5 style=" top: 5; left: 99; position: absolute; z-index: 1; visibility: hidden;"> </form><img src="red led.jpg" alt="Red Led" width="20" height="20" /> </div> </div> <div style=" top: 260; left: 200; position: absolute; z-index: 1; visibility: show;"> <form> <input type="button" value="Light 6" id="Light6" onClick="DisplayLED ('Led6');" /> <div id=Led6 style=" top: 5; left: 99; position: absolute; z-index: 1; visibility: hidden;"> </form><img src="red led.jpg" alt="Red Led" width="20" height="20" /> </div> </div> <div style=" top: 200; left: 400; position: absolute; z-index: 1; visibility: show;"> <form> <input type="button" value="Light 7" id="Light7" onClick="DisplayLED ('Led7');" /> <div id=Led7 style=" top: 5; left: 99; position: absolute; z-index: 1; visibility: hidden;"> </form><img src="red led.jpg" alt="Red Led" width="20" height="20" /> </div> </div> <div style=" top: 230; left: 400; position: absolute; z-index: 1; visibility: show;"> <form> <input type="button" value="Light 8" id="Light8" onClick="DisplayLED ('Led8');"/> <div id=Led8 style=" top: 5; left: 99; position: absolute; z-index: 1; visibility: hidden;"> </form><img src="red led.jpg" alt="Red Led" width="20" height="20" /> </div> </div> <div style=" top: 260; left: 400; position: absolute; z-index: 1; visibility: show;"> <form> <input type="button" value="Light 9" id="Light9" onClick="DisplayLED ('Led9');" /> <div id=Led9 style=" top: 5; left: 99; position: absolute; z-index: 1; visibility: hidden;"> </form><img src="red led.jpg" alt="Red Led" width="20" height="20" /> </div> </div> </div> </body> </html>jvrproductions is right the error is coming from the browser html encoding the space in red leg.jpg. The error message is
The Spinneret receives the following resource request.
I did not HTML decode the resource request. Do not put spaces in the file name.
I'll look into decoding the whole request header line if you really need to have a space. I'm not sure how the SD card driver will react as I have never tried to open a file that contains a space.
Secondly, you HTML is not valid. It has to do with the opening and closing of the < div > tags.When I open your page the buttons shoot over to the upper left corner, one button on top of the other.
