Counting Cogs — Parallax Forums
Counting Cogs
doggiedocdoggiedoc Posts: 2,255
edited 2011-12-26 17:33 in Propeller 1
Anybody know if there is a way to find out how many cogs are in use at any given time in a program? Besides counting manually, that is.
Doc
  • sidecar-racersidecar-racer Posts: 82
    edited 2011-12-26 16:52
    Look for sparecogs.spin by Alex. Works great
    Rick
  • doggiedocdoggiedoc Posts: 2,255
    edited 2011-12-26 17:04
    Thanks! I'll check it out.
    I've attached the project I'm fiddling with. It's Chip's SpatialSoundDemo that I've modified to use a 2-axis joystick instead of a mouse. I think I may be running out of cogs or possible I am doing something else wrong.
    if I use cognew like I have here it works, but if I try to check for cogs it doesn't - I've commented out the line the doesn't work.
    CON
    _xinfreq = 5_000_000 ' External Crystal Frequency
    _clkmode = xtal1 + pll16x ' Enabled External Crystal and PLL X16
    OBJ
      rc         : "RCTime"
    VAR
    long joyStickStack[2]
    long UDx, LRy
    long  cog
    PUB start : okay
    '  stop
      cognew(RawUDLR,@joyStickStack)
    '  return cog := cognew(RawUDLR,@joyStickStack) + 1
    PUB stop
    '' Stop joystick driver - frees a cog
      if cog
        cogstop(cog~ -  1)
    PUB RawUDLR  | UD, LR
       repeat
        rc.rctime(4, 1, @LR)
        rc.rctime(2, 1, @UD)
        UDx := UD
        LRy := LR
    PUB _UD : x
        x :=  UDx
    PUB _LR : y
        y := LRy
  • Mike GMike G Posts: 2,702
    edited 2011-12-26 17:16
    Since cognew returns the newly started COG ID. How about encoding ( |< ) the COG ID in a byte. Then you can use logic operator to keep track of the COGs in use. You could just keep track of the COGs in an array.
    edited 2011-12-26 17:21
    @doggiedoc: Be generous and give your joystick stack a few more longs (I stick with 32 during development). Two is definitely too small.
    Also, the way you use the RCTime object looks wrong. You're supposed to start it and simply read variables which are updated by its background task. Just realised it's in foreground mode. Apologies.
    edited 2011-12-26 17:29
    I think I got it. I didn't need cognew there at all. I should be calling the "start" method in RCTIME instead of the rctime method directly. This fixes the cog assignment problem posted above. I figured it out when I was bring to count manually how many cogs I was using.
    {---->replaces mouse.spin for SteroSpatializerDemo
    RC time uses 2axis joystick on pins 4 and 2
    CON
    OBJ
      UD         : "RCTime"
      LR         : "RCTime"
    VAR
    long UDx, LRy
    PUB start
        UD.start(4, 1, @UDx)
        LR.start(2, 1, @LRy)
    PUB _UD : x
        x :=  UDx
    PUB _LR : y
        y := LRy
    Thank you all for the responses - @kuroneko - I see you had the answer for me right there! Thank you all again.
    Paul
