How to get the Maximum or Minimum value of an array?
Hello everyone~
Are there any one could suggest that how to get the Maximum or Minimum value of an array?
Just like it:
x[0] := 0
x[1] := 1
x[2] := 2
x[10] := 10
Than I want to get the Maximum or Minimum Value of x array, are there any OBJ or command just like Max(x) or Min(x)?
Are there any example or any suggestion?
Thanks a lot.
Just like it:
x[0] := 0
x[1] := 1
x[2] := 2
x[10] := 10
Thanks a lot.
You would have to do:
pub max(arr, n) result := 0 repeat x from 0 to n if arr[x] > result result := arr[x] pub min(arr, n) result := 0 repeat x from 0 to n if arr[x] < result result := arr[x]
I am grateful for your assistance~
The idea is ok, but the implementation won't work!
arr is a local variable that can be found on the stack. You can't pass arrays, only 32-bit values or pointers.
arr[x] does not work, as it treats a variable like an array. arr[0] would in fact give you the content of arr, but arr[1] would give you the content of n. (the 2nd parameter on the stack) From there on you operate in memory areas which can contain anything.
What you have to do is pass the address of the array to the function, which means that accessing the elements has to be changed.
Additionally there are operators in SPIN which return the min and the max values, so you don't need to use the if-statement.
pub max(arr_ptr, n) result :=0 repeat x from 0 to n result #>= long[ arr_ptr ][ x ]
You'd call max like that:
VAR long myArray[10] PUB main | maxVal maxVal := max( @myArray, 10 )
PS: By the way ... there is another problem (in both implementations) if the numbers are allowed to be negative or the numbers are unsigned because SPIN deals with signed numbers. The negative number problem can be fixed easily by initializing result with the lowest possible negative number. Unsigned numbers need to be treated differently.
pub maxval(arr_ptr, n) | i result := long[arr_ptr] repeat i from 1 to n - 1 result #>= long[arr_ptr][i]
Merry Xmas
long[base][idx] access is slow. This version - although slightly bigger - speeds things up a bit. Merry Christmas!pub maxval2(addr, n) addr := (addr - @addr) >> 2 result := addr[addr++] repeat n - 1 result #>= addr[addr++]
