Bitmap to a nokia 5110 LCD
Hello Guys!
I have my 5110 up and running with the object from obex!
But now ofcourse i also want to try out to show a bitmap. I have created a bitmap that is 84x48, converted it with LCD assistant, and get this output:
i guess i need to replace the 0x with a $, but i have no idea how to modify the object, or create the function for this.
Is there anyone that maybe can help me in the right direction?
// File generated by LCD Assistant
// http://en.radzio.dxp.pl/bitmap_converter/
const unsigned char igen [] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
0x40, 0x30, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x02, 0x1C, 0x60, 0x80, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0x40, 0x20, 0x20, 0x20, 0x10, 0x10, 0x08,
0x04, 0x06, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x03, 0x0C, 0x08, 0x10, 0x20, 0x20, 0x40, 0x40, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80,
0x80, 0x40, 0x20, 0x20, 0x10, 0x08, 0x08, 0x04, 0x02, 0x01, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00,
dat igen byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $80, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $FF, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $80 byte $40, $30, $10, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $01, $02, $1C, $60, $80, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $80, $C0, $40, $20, $20, $20, $10, $10, $08 byte $04, $06, $01, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $03, $0C, $08, $10, $20, $20, $40, $40, $80, $80, $80, $80, $80, $80 byte $80, $40, $20, $20, $10, $08, $08, $04, $02, $01, $01, $01, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 byte $00, $00, $00, $00, $00, $00, $00, $00My favorite tool for this kind of stuff is EditPlus
That was a fast conversion you did!
Iam a bit unsure of how to send this to the LCD also. Any tip for that?
and also Do i need to break it down to 5 sections like the fonts are?
For that you are on your own. I kind of assumed that taking the time to make a bitmap meant you knew how to get it into the display. I don't have one of those so I have no experience with it.
Oh okey. Yes well, i needed to create a bitmap to try this out. hehe. Editing single chars the font i do understand. But how to send that whole chunk to the lcd is another story.
foo byte $00,$01, { } $02,$03, { } $04, $05It would have been much cleaner to do it how you did, but I couldn't find any examples that showed that syntax!
[code]
PUB LcdInitialize
'AT RESET THE LCD HAS THE FOLLOWING:
'Power-down mode (bit PD = 1) **DEFAULT AFTER RESET**
'Horizontal addressing (bit V = 0) **DEFAULT AFTER RESET**
'Normal instruction set (bit H = 0) **DEFAULT AFTER RESET**
'Display blank (bit D = 0, bit E = 0) **DEFAULT AFTER RESET**
'X6 to X0 = 0 | 0 | 0 | 0 | 0 | 0 | 0 - (Line0) **DEFAULT AFTER RESET**
'Y2 to Y0 = 0 | 0 | 0 - (Bank0) **DEFAULT AFTER RESET**
'Temperature control mode (TC1 TC0 =0) **DEFAULT AFTER RESET**
'BS2 to BS0 = 0 | 0 | 0 - 1:100 **DEFAULT AFTER RESET**
'reset lcd
outa[LcdCs] := 0 'turn the lcd chip on
outa[LcdRst] := 0 'turn the reset on
BS2.SHIFTOUT(LcdRst, LcdClk, 0, BS2#MSBFIRST, 2) ' clock the reset in ****REQUIRED****
outa[LcdRst] := 1 'turn the reset off
outa[LcdDc] := 0 'sets Lcd command mode
'CHANGES INSTRUCTION SET
'Extended instruction set (bit H = 1)
'Power-on mode (bit PD = 0)
BS2.SHIFTOUT(LcdSda, LcdClk, 33, BS2#MSBFIRST, 8) '33 0010 0001
{The settings below are voltage related. They should not be changed unless you know
what your doing. If you are using 3.3v, then the default settings are correct for you.}
'Needs Extended instruction set (bit H = 1)
'Command set VOP; (set operation voltage to 0.8 V -- 8)
'BS2.SHIFTOUT(LcdSda, LcdClk, 136, BS2#MSBFIRST, 8) '136 1000|1000
'Command set VOP; (set operation voltage to 1.6 V -- 16)
'BS2.SHIFTOUT(LcdSda, LcdClk, 144, BS2#MSBFIRST, 8) '144 1001|0000 ***BEST? FOR 5v OPERATION***
'Command set VOP; (set operation voltage to 1.8 V -- 18)
'BS2.SHIFTOUT(LcdSda, LcdClk, 146, BS2#MSBFIRST, 8) '146 1001|0010
'Command set VOP; (set operation voltage to 2.2 V -- 22)
'BS2.SHIFTOUT(LcdSda, LcdClk, 150, BS2#MSBFIRST, 8) '150 1001|0110
'Command set VOP; (set operation voltage to 2.4 V -- 24)
BS2.SHIFTOUT(LcdSda, LcdClk, 152, BS2#MSBFIRST, 8) '152 1001|100 ***BEST FOR 3.3v OPERATION***
'Command set VOP; (set operation voltage to 2.8 V -- 28)
'BS2.SHIFTOUT(LcdSda, LcdClk, 156, BS2#MSBFIRST, 8) '156 1001|1100
{Needs Extended instruction set (bit H = 1)
Command set VOP; (set operation voltage to 3.3 V -- 33) }
'BS2.SHIFTOUT(LcdSda, LcdClk, 161, BS2#MSBFIRST, 8) '161 1010|0001
Command set VOP; (set operation voltage to 7 V -- 70)}
'BS2.SHIFTOUT(LcdSda, LcdClk, 198, BS2#MSBFIRST, 8) '198 1100|0110
Sets Bias - 1:48 **Optimum**}
BS2.SHIFTOUT(LcdSda, LcdClk, 19, BS2#MSBFIRST, 8) '19 0001|0011
{CHANGES INSTRUCTION SET
Horizontal addressing (bit V = 0)}
BS2.SHIFTOUT(LcdSda, LcdClk, 32, BS2#MSBFIRST, 8) ' 32 0010|0000
outa[LcdDc] := 1 'sets Lcd data mode
ZeroLcdRam 'puts cursor at 0, and clears lcd ram.
******************PCD8544******DATA*****************************************
For all commands below, D/C mode = 0 (command mode) (command/data mode pin needs to be low)
D/C 7 6 5 4 3 2 1 0
_____|____|______|______|______|______|______|______|__________________________________________
0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 - no operation
0 | 0 | 0 | 1 | 0 | 0 | PD | V | H = PD-power down control; V-address entry mode; H-normal/extended instruction set control
1 | D7 | D6 | D5 | D4 | D3 | D2 | D1 | D0 - writes data to display RAM
The write data’and function set’commands can be executed in both cases of H. (H = 0 or 1)
• All LCD outputs at VSS (display off)
• Bias generator and VLCD generator off, VLCD can be disconnected
• Oscillator off (external clock possible)
• Serial bus, command, etc. function
• Before entering Power-down mode, the RAM needs to be filled with‘0’s,
to ensure the specified current consumption.
'Vertical addressing (bit V = 1)
(H = 0) Normal instruction set. When H = 0 the commands‘display control’,‘set Y address and‘set X address can be performed
Display control (bit D, bit E)
• 0 | 0 | 0 | 0 | 1 | 0 | 0 | 0 - Display blank (bit D = 0, bit E = 0) **DEFAULT AFTER RESET** 8
• 0 | 0 | 0 | 0 | 1 | 1 | 0 | 0 - Normal Display (bit D = 1, bit E = 0) 12
• 0 | 0 | 0 | 0 | 1 | 0 | 0 | 1 - All display segments on (bit D = 0, bit E = 1) 9
• 0 | 0 | 0 | 0 | 1 | 1 | 0 | 1 - Inverse video mode (bit D = 1, bit E = 1) 13
'Address counter X6 to X0
• X6 to X0 = 0 | 0 | 0 | 0 | 0 | 0 | 0 - (Line0) **DEFAULT AFTER RESET**
• X6 to X0 = 1 | 0 | 1 | 0 | 0 | 1 | 1 - (Line83, last line)
'Address counter Y2 to Y0
• Y2 to Y0 = 0 | 0 | 0 - (Bank0) **DEFAULT AFTER RESET**
• Y2 to Y0 = 1 | 0 | 1 - (Bank5, last bank)
7 6 5 4 3 2 1 0
|____|______|______|______|______|______|______|______-___________________________________
| 0 | 0 | 0 | 0 | 0 | 1 | X | X - do not use
| 0 | 0 | 0 | 0 | 1 | D | 0 | E - sets display configuration
| 0 | 0 | 0 | 1 | X | X | X | X - do not use
| 0 | 1 | 0 | 0 | 0 | Y2 | Y1 | Y0 - sets Y-address of RAM 0 <=≤ Y =>≤ 5
| 1 | X6 | X5 | X4 | X3 | X2 | X1 | X0 - sets X-address part of RAM 0 <=≤ X =>≤ 83
(H = 1) The extended instruction set can be executed.
7 6 5 4 3 2 1 0
| 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 - do not use
| 0 | 0 | 0 | 0 | 0 | 0 | 1 | X - do not use
| 0 | 0 | 0 | 0 | 0 | 1 | TC1 | TC0 - set Temperature Coeffcient (TCx)
| 0 | 0 | 0 | 0 | 1 | X | X | X - do not use
| 0 | 0 | 0 | 1 | 0 | BS2 | BS1 | BS0 - set Bias System (BSx)
| 0 | 1 | X | X | X | X | X | X - do not use
| 1 | VOP6 | VOP5 | VOP4 | VOP3 | VOP2 | VOP1 | VOP0 - write VOP to register
• The temperature coefficient of VLCD is selected by bits TC1 and TC0.
'Bias system (BS2 to BS0 =0)
BS2 to BS0 = 0 | 0 | 1 - 1:80
BS2 to BS0 = 0 | 1 | 0 - 1:65 / 1:65
BS2 to BS0 = 0 | 1 | 1 - 1:48 **Optimum**
BS2 to BS0 = 1 | 0 | 0 - 1:40 / 1:34
BS2 to BS0 = 1 | 0 | 1 - 1:24
BS2 to BS0 = 1 | 1 | 0 - 1:18 / 1:16
BS2 to BS0 = 1 | 1 | 1 - 1:10 / 1:9 / 1:8
'VOP is set to a +16
See next post for latest code.
Moved to ObEx
-- http://obex.parallax.com/objects/836/
Can you please help me?
Where can I find one that works (spin) or PBAs for the display: Nokia 5110?
Since the connections should be described.
Thank you.
greeting
If you can't find it then I will do that later from my PC. (On iPhone now)
