Near Space Helium Balloon
Hey Guys,
I'm developing a near space helium balloon (weather balloon) in my spare time (with some friends of mine). I wanted to share my experience with the Propeller community (as I will be using the Parallax Propeller to implement the Telemetry/Recovery systems).
Other projects which have done something similar:
http://natrium42.com/halo/flight2/
http://www.w6xe.net/~jmeehan/balloon/
rules, etc:
http://www.eoss.org/pubs/faqloon.htm
1. Telemetry
Obviously to find this thing once it comes back down, I'm going to need some way to track / locate it. After doing some research and looking at various xBee devices, I'm starting to lean toward leveraging SMS messages on a cell phone network. There are obvious advantages/disadvantages to this. Firstly, modern cell networks are ALMOST everywhere. Meaning just about no matter where I land (crash land), I'll be able to receive position reports over SMS. I've already been able to send SMS messages from my computer using my personal cell phone. AT Command Set reference was quite useful.http://www.smssolutions.net/tutorials/gsm/sendsmsat/
2. Recovery
I've seen some projects that use a parachute that kind of auto deploys when the balloon pops. I don't like this kind of system as the payload is significantly slowed during the whole course of it's descent which can allow the payload to drift many many miles. Because of this, I'd like to design a system which will deploy a parachute when the payload is descending and has reached an altitude of < 2000ft.
Here are some parts I have picked out so far for this development.
Propeller Backpack (because of it's small size)
http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/SortField/0/Level/a/ProductID/602/Default.aspx
Altimeter Module (for pressure and temperature)
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/pressure/List/0/SortField/4/ProductID/780/Default.aspx
For the Telemetry system using SMS I'm looking at several pay as you go type cell phones. I liked this one the best so far because of the price.
http://www.walmart.com/ip/AT-T-GoPhone-Prepaid-Samsung-A107-Cell-Phone-Silver/15421486
At&t looks like the way to go for doing this because they offer unlimited everything for $2 per day of use. Meaning I only pay when I use SMS and I get that whole day for $2.
I haven't figured out how I am going to connect the Cell phone to the micro controller. I did find this cable.
http://bestcelldist.com/samsung_sgh_a107_serial_data_cable.html
But after a search on RS232 I found that RS232 can actually have a negative voltage. I don't believe the propeller can handle negative voltages on it's pins.
http://en.wikipedia.org/wiki/RS-232#Voltage_levels
In any case, I'm open to any comments or suggestions you guys have especially on connecting the cell phone to the Propeller.
Non-functional objectives (what we want to achieve):
1. Record high altitude video
2. Log atmospheric parameters at various altitudes
3. Expand our knowledge and experience in building autonomous and robotic systems
Functional objectives (what it does)
1. Records video using a camera (go Pro)
2. Reports it's GPS coordinates over SMS (using a cell phone and GPS)
3. Can cut away from the helium balloon (either with a timeout or by SMS command)
4. Can automatically deploy a recovery parachute
5. Records atmospheric and location parameters
6. Logs mission and flight time
7. Regulates the internal temperature of the payload
8. Emits loud buzzing noise for easier recovery
9. Payload should be modular and assembled with connectors for easy maintenance.
rules, etc:
1. Telemetry
2. Recovery
I was looking at this IC
http://search.digikey.com/us/en/products/MAX232CPE%2B/MAX232CPE%2B-ND/947834
Which could convert RS232 to TTL for the microcontroller.
Which could connect to this cable:
However, when reading the product description it says that the RS232 cable converts the phones TTL to RS232. So, if I could find a pinout for the cell phone, I could probably just hook the propeller directly to the cell phone's serial port instead of going from TTL to RS232 back to TTL.
Any thoughts?
George
Salutations,
That is precisely what is happening. For reasons unknown to me your posts kept getting trapped in the spam-filter. I asked one of the other monkies to look into the issue and they assured me that this shouldn't be a problem anymore. Sorry for any inconvenience or confusion this may have caused.
For that matter, any cheap phone anyone knows of that has a pinout.
For -12v this equates to 24k. Often the RS232 negative voltage is more like -5~-6 volts. The resistor may cause problems with really fast baudrates, as it introduces an RC filter, but you'll probably be fine. You just need to try it.
The serial objects have an 'invert RX' option which might be required.
http://forums.parallax.com/showthread.php?130380-Android-Debug-Bridge-on-a-prop
If I understand correctly, it allows terminal type access to the Android device. The Android can provide terminal, storage, processing, and communications services, and the prop can provide interface to the sensors and actuators.
I recently received my first android device, so I should be looking into the android bridge soon. If you pursue this option, maybe we can collaborate.
If you know of a way to get an a android phone up and running on the cheap, I'd love to hear about it.
thanks,
George
Not sure if this option is too pricey for the project but I was just browsing through posts last night for fun and ran across someone who put up this link and it looks like a very interesting device to maybe have in ones toolbox just for fun:
https://store.diydrones.com/DroneCell_p/br-dronecell-01.htm
I also saw a page for sim cards (can't remember the link now) that was thru T-mobile that had a text only plan (no data) for like $4.99/mo for 30 or fewer SMS's up to $9.99/mo for a couple hundred SMS's.
I don't know anything about making it work with the Prop; I just figured I'd post because it seems like something that could fit into your project.
I also updated the first post with some requirements we determined.
For recovery, I suggest using a parachute that will open when the payload begins to descend. The descent from 100,000 feet will take about a half hour or less. Even with the chute open the payload will fall at a rate of several hundred MPH at high altitudes because of the thin air. It will slow down as the air gets denser closer to the ground.
Make sure you use a battery that will last for the duration of the flight. You don't want the battery to die before the payload lands, or it will be difficult to find it. The battery should last for 3 or 4 hours to give you enough margin.
I want to eventually be able to not only have the payload report it's position, but be able to send commands (like cutdown the payload, etc).
To achieve maximum versatility, I was looking for some solution like this
Payload: 2m radio - modem - micro controller.
Ground Station: 2m radio - modem - laptop
Meaning that each would be a discrete component I could interface with.
I still have a bit of research do to in understanding packet radio, but I was hoping to start with something like this
http://www.gigaparts.com/store.php?action=profile&sku=ZAL-DJ-175T
and interface the micro controller with it.
If any of your guys have links to tutorials about setting up packet radio / APRS I would appreciate them.
George
