fsrw 2.6 speed tests - Page 2 — Parallax Forums
2»
  • pgbpsupgbpsu Posts: 460
    edited 2011-12-21 13:02
    Got it. Thanks. p
  • lonesocklonesock Posts: 917
    edited 2011-12-27 09:29
    Hi, Peter.
    How is this project coming? Is there anything I can do to help?
    Jonathan
  • rokickirokicki Posts: 1,000
    edited 2011-12-28 22:12
    lonesock wrote: »
    Hi, Peter.
    Jonathan
    Also watching this.
    It has been briefly mentioned already, but you need to be ready for that odd
    time when the card will suddenly be *very* slow (usually for a write) for a
    single block. This does happen periodically (when the card decides it
    needs to erase a new page, or do some housekeeping).
    So even with all the magic available, at some point the card *can* just
    stall, for a good fraction of a second.
    There is a lot of intelligence inside the card to manage wear leveling and
    the like, and that does show up as occasional delays.
    But let us know how it is going; we're all keen to hear.
    -tom
    edited 2011-12-29 07:46
    Hi Tom and Jonathan-
    Sorry I haven't updated this lately. We've been traveling for the holidays and although I brought a small Prop platform I haven't had any time to work on this. I've had a hard time even keeping up with the forum. I'm back home now and hope to find time to work on this. I'll post any results I get.
    Tom, we've had similar discussions before and I recall needing about 1/3 of a second buffer to handle those occasions when the card just went off to do its own thing. If that's the case, I have no chance of buffering things in the prop. If I find the same things now (I can't remember if I was using the FAT layer at that time or not), this discussion will turn to external memory solutions.
    Thanks.
    Peter
    edited 2011-12-30 08:46
    I had a chance to return to this problem. I switched SD cards. The first was a 4GB SanDisk micro SDHC class 4 card. Data presented so far have been from that card. The graphs below were created using a 2GB PNY MicroSD. There are some other numbers on the bottom of the card, but clearly no SDHC and no class rating. This smaller "off-brand" card has much better read performance. In fact, the read is much faster than the write.
    In the attached plots, each point is represents the max, min, average of 10,000 512-byte blocks. The amount of data I need to store is 30 seconds at a 160KBytes/sec which works out a bit less than 5.12Mbytes over 30 seconds. The code used to produce these plots, starts at block zero of the card. It writes one 512-byte block, releases the card then reads one 512-byte block and releases the card, repeating this 10,000 times. For each individual 512-byte block, I time how long it takes to both read and write this block and capture the maximum and minimum times over these 10,000 blocks and print out the results. I then started at block 10,000 and do this again, etc until I had tested nearly the entire card. Here's a sample of the output. The times listed below are microseconds except for the "time(ms)" column which is clearly in milliseconds:
    Main Cog:                        0
    Serial ports running in cog:     1
    Mount Command Returned:          2
    Cardsize: 2
    Blocks to write: 4193280
    Blocks in buffer: 10000
    Expected Iterations: 419
    Running speed tests.
         start  time(ms)  sumWrite  avgWrite  maxWrite   maxWLoc  minWrite   minWLoc   sumRead   avgRead   maxRead   maxRLoc   minRead   minRLoc
             0     39173  25561330      2556     15743      6815      2250        64  10507219      1050      1176        16       908        14
         10000     39252  25638323      2563     12107     14783      2250     10080  10511105      1051      1176     10001       908     16494
         20000     39584  25971361      2597    377937     24576      2189     24607  10510714      1051      1176     20001       908     24590
         30000     38786  25173739      2517     11119     37916      2189     32799  10511094      1051      1176     30000       908     32846
         40000     38738  25127028      2512     11217     40626      2189     40991  10509730      1050      1176     40000       908     40991
         50000     38746  25134467      2513     11144     56495      2189     57375  10510111      1051      1176     50016       908     51327
         60000     38740  25127877      2512     11278     65139      2189     65567  10510224      1051      1176     60000       908     61535
         70000     38756  25143314      2514     10997     73396      2189     73791  10510947      1051      1176     70000       908     70239
         80000     38755  25143839      2514     11339     81137      2189     81951  10509038      1050      1176     80001       908     81951
         90000     38764  25152924      2515     11253     97522      2189     90143  10508984      1050      1176     90000       908     90111
        100000     38915  25303305      2530     11058    105263      2201    100063  10510084      1051      1176    100001       908    102623
    The plots make things a bit easier to see over the entire capture. Keep in mind the y-scale is logarithmic. One plot is for the write measurements; the other for read measurements. In both cases blue is total time for 10,000 operations, red is the max single time, green is the min single time, and yellow is the average (total/10,000). A few things stood out to me. First the reads are faster and more stable than the writes. This is the opposite of my 4GB SanDisk card. The range between max and min on the read times are very small compared to the same measurement on the writes. The min and avg write times are stable at about 3x the read time. However the max write is more than 100 times as long as the max read. Because the average is so close to the minimum it appears that the max value only happens once. In fact it appears to me that this one max value is FAR outside the normal, but it does happen at least once every 10,000 blocks, which is all I need to know.
    I hope to run this same program on my 4GB SanDisk card. It will probably be tonight because it takes hours to run. Each of these 10,000 block read write tests takes ~40 seconds. Doing several hundred in the 2GB test took ~4 hours. Moving to a 4GB card will presumably double that. Then again, maybe not. Clearly there's a big difference between cards.
    Thoughts, observations, and suggestions are welcome and appreciated.
    Peter
    1024 x 791 - 41K
    1024 x 791 - 47K
  • RaymanRayman Posts: 16,121
    edited 2011-12-30 10:16
    Just a thought... I had trouble with my 3D camera cutting out after 20 seconds of video...
    Did some googling and found out that I needed a class 10 card to be fast enough for the camera.
    So, I'd recommend getting a class 10 card. They're fairly cheap on Amazon...
    BTW: I did upgrade my camera to a class 10 and it fixed the problem. So, I think there's something to it.
    edited 2011-12-30 18:11
    Rayman wrote: »
    Hi Rayman- I need to get a few different cards and see how the performance varies. I'll probably try a range of classes and a range of sizes. But I still think this is headed toward an external memory solution.
    p
