Plastic Fiber Optic Cable -- Looking for Source
JonnyMac
I'm looking for a source of inexpensive plastic fiber optic cable, the kind typically used to make lighted lamps and ornaments. In my case, I will be use the cable, some LEDs, and a custom Propeller controller to light elements of a model of Los Angeles. Any recommendations are appreciated.
http://www.fiberopticproducts.com/Archery.htm
http://www.fiberopticproducts.com/Sideglow.htm
http://www.trinorthlighting.com/Store/index.php?main_page=index&cPath=80
http://www.wiedamark.com/fiberopticendglow.aspx
http://www.tprlights.com/fibercable/
http://www.alibaba.com/showroom/end-glow-fiber-optic.html
This one is only $.04/ft... if you buy a full reel.
http://www.cockeyed.com/incredible/fiber/fiber1.php
Ends are suppose to be cut, cut perpendicular, maybe polished, NOT melted.
ADDED thoughts.
1. Bundle together before cutting with a very sharp razor blade or such.
2. Polish the bundled cuts with either Dupont Polishing Compound or Dupont Rubbing Compound (available at automotive supply stores for making your car nice and shinny).
Polish ca be washed away with liquid dish soap and water.
But monofilament fishing line is still a poorer light conductor than plastic fibre-optics.
They are a Hong Kong outfit and seem to have a vision to lead the retail market.
The QuickStart add-on had MOSFET outputs for high-intesity LEDs that drove the wick elements, and a WS2801/WS2812 interface for a set of color-changing LEDs behind the skull.
It's been a while since I've played with it, but apart from the Spencer Gift mall store buys, all the optical fiber I've ever used has been purchased surplus. I don't see any clear stuff at my old regular haunts, like AmSci, but I'm sure it's out there.
Jon, if you have a CA resellers licence, you can also investigate the wholesalers in the wholesale districts south of town. They have a lot of cheap optical toys and gifts for rave and party use. Some are shop and carry, and there are no minimums. But you must have that resale card.
