Low cost test equipment for the home work bench
Found this little 5MHZ function generator (from many sellers) on ebay. http://www.ebay.com/itm/5MHz-DDS-Function-Signal-Generator-Source-60MHz-Frequency-Counter-DDS-Module-/160702187538?pt=BI_Signal_Sources&hash=item256a98c812
It looks pretty slick but I'm waiting on a reply to some questions before buying.
In the mean time, I thought it would be great to start a discussion on low cost solutions for test equipment. Oscilloscopes, Spectrum Analyzers, Function generators, etc.. What do you use now, and what's on your wish list for teh work bench?
I have an ancient Tektronix O'scope and some day I'd like to add a spectrum analyzer. It'd be nice to have a counter and a couple of ARB's too.
Tek 2235 100 MHz 'scope
Two Marconi 2019A signal generators
1.2 GHz counter
Home-made function generator (AVR and DDS software)
I'm thinking of buying a Rigol DS1052E 50MHz digital 'scope in the new year (£250). I'll use a simple software hack to get 100 MHz bandwidth.
http://www.saelig.com/product/PSPC017.htm?gclid=CPi0geHAka0CFcJgTAodcT86LQ
I've got the Rigol 1052E and have done the software mod, seems to work well.
This might also be happening in your area, you might want to check out the following link for more info:
http://www.eevblog.com/forum/index.php?topic=5746.0
Could you say more about the software hack on the 1052E?
Go over to www.eevblog.com, and search the fourm area, you'll find out all about the software mod.
Also my function generator is an AVR32 and a RDAC.
The combined cost to build both was under $40.00 USD. I still have my analog scope for situations where higher sampling speeds are needed.
I'm very pleased with the scope.
Can you tell me more about your function generator?
That seems similar to the product I posted originally. I've seen others as well.
WRT the DS1102, I noticed that they mention the capability to display an FFT of the signal being monitored. Does this mean it provides a spectrum analyzer display (freq domain) as well? If so what's the bandwidth and sweep rates??
