BS2pe Mobo Tach question
I need to build a precision RPM Gauge for a rotating light (light house) I must be able to display to the hundredth of an RPM and the Rotating assembly has an IR sensor and an encoding strip which has 550 pulses per revolution. I know sounds like a lot but this will make it easier. Max rotation speed to be measured is 20 rpm. I think that is 183.333 hz so i think this would work. I would like to display this on the master 7seg display. I am guessing that an update rate of the display around once a second or faster would be sufficient. Can this be done? I onlyhave experience with the BS2. Would it be very difficult?
TIA
TIA
it is a sinwave with 3.44v Pk to Pk riding on 2.96vdc. High part of the wave is at 4.68vdc and low part is at 1.24vdc.
Alternatively, use a pot as a voltage divider to do the same thing. Using the Stamp's inputs directly as comparators are one of my favorite tricks.
Your idea would certainly work, but with a sinewave input coming, perhaps, over a cable from the encoder, I would still encourage the addition of some hysteresis to eliminate any concerns about noise.
Pulse widths will be shorter as RPM increases, but you cannot count on their individual widths for measuring RPM.
Jitter and pulse asymmetry issues are beginning to scare from the period measurement approach. And I don't believe they will give you more accuracy any quicker than a simple pulse count would, since you have to average them anyway. The best part is that counting pulses is just simpler.
