Is there such a thing as "ceiling effect" (analogous to ground effect) ?
Tubular
If one flies a quadcopter inside, close to the ceiling, is there a region where flight is more efficient ?
Just wondering
(edit: sorry meant to post in general discussion; feel free to move it)
Just wondering
On the other hand the air that is between the blade and the ceiling is "less mobile" than free air (thinking along da Vinci's "air screw" line, it might therefore require fewer rpm to 'screw' into this air than free air and remain static).
Just as it takes less power to hover when near the ground it takes less power to hoer near the ceiling.
In "Ground Effect" one is supported not only from lift but also from pressure under the structure.
In "Ceiling Effect" one is supported not only from lift but also from vacuum over the structure.
Duane
I'm kidding. I didn't think of that. It makes sense, but it seems like the lift lost due to the vacuum would be fairly significant. Would the benefit of the "ceiling effect" have to do a lot with the design of the overall structure? Or would the vacuum above the blades always create more lift than the lift lost due to the vacuum?
Close to the ceiling the air must rush in from the sides to supply the rotor. The higher velocity of the incoming air would create an area of lower pressure above the rotor. At some point I think the benefit will reverse when not enough airflow is available.
This is very true for indoor helicopters. It behaves as if it is being sucked into the ceiling.
But I think the aerodynamics put forward might be a bit off.
Graham
Exactly. Ping sensors to control elevation, and stud finders to determine how far one has travelled.
And light sockets for recharging
The vacuum is zero force, not a negative one.
I am not sure why, if it is true, that the helicopter is attracted to the ceiling. Perhaps because a relative absence of air pressure develops up there.
