Propeller wins yet again. — Parallax Forums
davidsaundersdavidsaunders Posts: 1,559
edited 2011-12-18 10:30 in General Discussion
I accidentally fried my second BeagleBoard xM in trying to migrate to ARM, and I realized if these things are so easy to fry what does that mean for a customer. At $150 USD that hurt.
I will check out the Raspberry Pi once it is out, though I think that the Propeller Proto board will be my primary from here on out (at least till the Propeller II comes along).
dbb.jpg 59.9K
  • LeonLeon Posts: 7,620
    edited 2011-12-17 21:37
    I've ordered one of the new BeagleBone boards. Mouser is waiting for export approval.
    What did you do to your BeagleBoards?
  • davidsaundersdavidsaunders Posts: 1,559
    edited 2011-12-17 21:48
    Used the DVI at the same time as Ethernet and 3 USB ports, over current killed them.
    edited 2011-12-17 21:51
    Though I would note that Risc OS flies on them.
    edited 2011-12-18 06:47
    What were you using on the 3 USB ports? Each should be alloted only 500ma max.
    And yes, Parallax has always managed to provide products at the rugged end of the scale. After, they cater to a great deal of novices. Still, I really like the Beagleboard and the Pandaboard even better. Digikey dropped shipment of a Pandaboard to me because I hadn't provided a company name here in Taiwan. I guess this is one of those export requirements.
    edited 2011-12-18 07:15
    I think that the DVI to VGA converter is what topped the limit (it draws 370ma).
    edited 2011-12-18 10:22
    So, if you use the DVI without VGA - you are in safer territory? I am finding it a bit odd that a brown out would cause permanent damage.
    No not brown out, actual overcurrent (it had enough current and drew more than it could handle).
