What are your steering techniques? — Parallax Forums
lardomlardom Posts: 1,659
edited 2011-12-16 11:18 in Robotics
I'm trying to design a 3 or 4 wheel platform where a servo steers the front wheel or wheels. For locomotion a stepper will power one of the rear wheels. I'm researching a parallel-steering set up and I wanted to know if anyone else uses that method?
  • lardomlardom Posts: 1,659
    edited 2011-12-16 10:39
    From my research it seems differential steering is more common than parallel so I will go with differential. The extra hardware would add slop that I'd have to compensate for. It would make more sense to use math to get the precision I'm after.
    Mechanical simplicity and stability is critical. Good choice!
