Dissolving Enamel from Magnet Wire?
I have a project that requires as many as 60 custom-wound electromagnets each time. The construction and winding is a breeze... the thing that is a HUGE PITA? Scraping the enamel off of the magnet wires with an exacto knife to make the connections!
Does anyone have a preferred method / product for dissolving enamel from magnet wire? Acetone and toluene don't touch it.
Thanks for your ideas,
Dave
Dave
I think in this case I'm looking more for a "process solution" where I can just dip & wipe. There's 60 of them... that's 120 wires.
Dave
http://www.spectrumtech.com/product-groups/magnet-wire-stripping
This might be more reasonable...
http://www.eraser.com/catalog.cgi?mode=details&product_id=1442
C.W.
That stuff ate just about anything IIRC.
If you have ever spilled some on your fender or gas tank...You'll know what I mean.
The brake fluid doesn't smell near as bad as the paint stripper and an 8oz. bottle should last for years.Its cheap too!
I know it sounds weird, But it works
I got the idea at the one company I worked where they wound their own magnetics (no chemicals.) Their "stripping machine" was like a grinding wheel but outfit with large bristle brushes instead.
(Jasco, brake fluid, MEK, that's toxic stuff.)
Thanks... any more?
Dave
The rotary bristle brush method intrigues me. Can you elaborate on your technique? Do you use the "disc" shaped brush, or the "cone" shaped brush? How do you immobilize the end of the wire while you're stripping it?
...and your point is???
Steady enough to place 0603 resistors on a PCB, but not steady enough to perform surgery on someone's pet ferret.
The primary reason for using wet process sandpaper is that the stuff can be stored forever in a high humidity environment (like where I live) while the other stuff falls apart after a year or so.
Actually emery cloth is also good, but a bit more expensive.
I suppose that JASCO paint stripper will work, but that stuff is nasty with lots of chlorinated hydrocarbons. It eats through rubber gloves and other protective barriers and should only be used outdoors.
You don't really need to use power tools, do you?
Thanks!
Dave
just dip it and remove. its kinda gel solution so it sticks to the wire even if thin and removes it...
with thin wires, its useful coz scratching and burning breaks the wire... lol
This thread is almost 7 years old. Had I seen it back then I would have suggested acetone (AKA nail polish remover) as it is inexpensive and readily available.
Like Publison I've used a lighter and fine steel wool on even the thinnest wire, much finer than 26 gauge. It takes but a moment to get the enamel to burn, and that's all the heat that is needed.
Dave
