Underwater optical wireless communication system based on visible light
Hi All;
I am a Ph.d student and part of my project (underwater optical wireless communication) is to design an optical wireless system.
I am using OPT101 in a reciver circuit based on FSK modulation. I got a problem with the effect of the strong ambient light. Even, I put an optical filter on the OPT101 but the problem still which is the strong ambient light affect the circuit from receiving the correct data. However, with the room light the circuit is working fine and reciving the data correctly but with the strong ambient light the circuit stop reciving data and sometimes just reciving rubbish data.
I am using XR2206 as FSK modulator at the transmitter and XR-2211 as FSK demodulator at the receiver. Also, I am using the green light at 520nm.
Any suugesstions and feedback will be appreciated.
Thanks all
Thanks all
Any suggestions?
There is also a chance that, if you're using a colored-glass filter (as opposed to an interference filter), that it will pass IR, in addition to the stated passband. Incandescent lamps are very rich in IR, and that could be what is saturating your sensor. A wide-band IR-blocking filter (e.g. Schott BG38) atop your color filter would help to eliminate interference from the IR. A quick check of the Schott (or other) catalog for your filter should help to ascertain its IR characteristics.
I bought it from the website below
http://www.photocontinental.com.au/products/106010106000
Thank you
Are you sure that's an interference filter? Just googling around a bit, it looks like a non-interference filter to me.
Maybe compare it to product number NT43-069 here:
http://www.edmundoptics.com/products/displayproduct.cfm?productID=3429&dc&PageNum=2#products
The RCTIME circuit could not be expected to work for a communications scheme at any reasonable rate. That is a very crude approach for detecting abient light level based on the Stamp's RCTIME command.
Is there a definite direction involved in the underwater path, that would allow for narrowing the field of view by using a tube or lens or something of the sort?
There are tricks that can be played with two photodiodes and subraction of their front end currents, one detecting ambient+signal and the other only ambient, but that does get into some thorny issues of matching and circuitry.
I would stay away from interference filters. They have very narrow passbands, but their angle of acceptance is very restricted -- probably not what you want for the app at hand.
just so there's no confusion: when we talked about "optical interference filters", we're talking about a type of narrow-band filter that utilizes the optical phenomenon of light wave interference to narrow the light coming through to a very specific wavelength range, maybe +/- 10 to 50 nm. We're not talking about something analogous to electronic interference filtering, etc.
To Phil,
I know that interference filters are specified for a given entrance angle that is usually very narrow, but if I remember correctly, what happens at the larger angle is that the center wavelength that is allowed through the filter gets shifted a bit. I'm not sure by how much or at what range of angles, but I was just wondering if a broader angle of entrance would matter that much in a case like this.
EDIT: For example, here's an article where they tilted the filter 12 degrees just to shift the center of wavelength less than 3 nm:
http://spie.org/etop/2009/etop2009_2.18.37.pdf
Do you think it is better to use NT43-069 instead of the filter that I am using to solve the ambient light problem?
Thanks all for your reply and help
If the Schott filters are difficult to obtain in Oz (I take it that's where you're located), and if you can order from Edmund, they carry a wide variety of filters that could be combined to give you the passband you want. For example, they have both longpass and shortpass filters with sharp cutoffs that, when sandwiched together, would provide a fairly narrow passband. Just make sure that the short pass filters block well into the IR, or you will end up having the same problem with an incandescent ambient light source as you're having now.
Okay. In that case definitely take Phil's advice. He's one of the gurus here, especially when it comes to electro-optics.
One thing to check if you're operating in water and air: if the light must pass through an air/water interface, you will want to watch out for situations in which total internal reflection could break your transmission path.
http://en.wikipedia.org/wiki/Total_internal_reflection
Are you able to help me with ship this filter to Australia If I want to order the NT43-069 because I found that the shipping fee for this filter is $45 and the price of the filter is $50.
I thank this is a good narrow bandpass filter. I will also check with my supervisors.
I do notice that Edmund carries Schott filters. You might try their selection with the Schott Excel worksheet to find the best match.
