unexplained gosub delay
Hi All,
As a good soldier iḿ following the basics book and while doing some experimenting of my own i ran into some strange behaviour while working with gosub routines which i cannot overcome.
My 1st code runs pefectly but if i turn the pot the servo takes small steps to get to its new position.
If i remove all the gosub stuff it runs perfectly.
Why its that? i looked in my books but i just cant find a explanation for this
' {$STAMP BS2}
' {$PBASIC 2.5}
rcLR PIN 1
rcUD PIN 2
serLR PIN 14
serUD PIN 15
scaleFactor CON 143
offset CON 400
delay CON 10
timeLR VAR Word
accuLR VAR Word
timeUD VAR Word
accuUD VAR Word
'Main
PAUSE 1000
DO
GOSUB getrc
GOSUB calcPulse
GOSUB dispPulse
LOOP
getrc:
HIGH rcLR
HIGH rcUD ' charge the cap
PAUSE 1 ' for 1 ms
RCTIME rcLR, 1, timeLR ' measure RC discharge time
RETURN
calcPulse:
timeLR = timeLR */ scaleFactor
timeLR = timeLR + offset
accuLR = (accuLR + timeLR) /2
RETURN
dispPulse:
PULSOUT serLR, accuLR
RETURN
' {$STAMP BS2}
' {$PBASIC 2.5}
rcLR PIN 1
rcUD PIN 2
serLR PIN 14
serUD PIN 15
scaleFactor CON 143
offset CON 400
delay CON 10
timeLR VAR Word
accuLR VAR Word
timeUD VAR Word
accuUD VAR Word
'Main
PAUSE 1000
DO
HIGH rcLR
PAUSE 1 ' for 1 ms
PAUSE 10
LOOP
Maybe PhiPi or Tracy Allen can weigh in here on gosub execution speeds. Tracy has a website at http://www.emesystems.com/BS2speed.htm with lots of juicy timing info and more.
Can you "attach" both versions as actual .bs2 files? Something seems odd here. A BS2 gosub might take 750us, so say 2.25ms extra for the gosubs. Still that would be like having a PAUSE 2 or PAUSE 3 in the second program, not a PAUSE 10 or PAUSE 100.
Edit: Zoot beat me to it!
Try a different servo, at any rate.
In the program with the GOSUBs, you need to do the same thing. You need to add a variable PAUSE based on the RCTIME value. It's just that the PAUSE time would be slightly different because of the difference in the overall execution time of the main loop.
DO
GOSUB getrc
GOSUB dispPulse
GOSUB calcPulse
GOSUB dispPulse
LOOP
BTW, did you leave any DEBUG statements in your first program? Does "dispPulse" mean "display Pulse" on a debug screen? That would clearly slow down a program and make your servo stutter, my good soldier.
I stripped and added a debug and this cleared the issue. With DEBUG ON you have a servo with huge jitter. with DEBUG OFF it runs very smooth as desired.
And up went the learning curve again ;-)
Thanks all for the good feedback (in which i find this forum really excels)
