Stalled... Program will not enter Sub Routine
Hello All,
I am having with my program not recognizing the Alarm sub routine of my alarm clock program. I am sure that I am missing something obvious but I am too close to this to see my error. If anyone can point out where I am going wrong I would appreciate the help.
I have included the portions of the code that I thought applied. If I left anything out let me know. Also it is base on Chris Savages Digital Alarm Clock code.
Zeus
Zeus
[/B]
IF secs <> oldSecs THEN ' Next Second?
oldSecs = secs ' Update Old Seconds
GOSUB Show_Time ' Display Current Time/Status
ENDIF
IF AlarmSwitch = 0 THEN
a1Status = 1
ELSE
a1Status = 0
ENDIF
IF (AlarmSwitch = 0) THEN
DEBUG CR, "Alarm On"
ELSE
DEBUG CR, CLREOL
ENDIF
IF a1Status = 1 AND mins = AlmMins AND hrs = AlmHrs AND secs = $00 THEN
GOSUB Alarm ' Activate Alarm Sequence
Alarm:
DEBUG BELL
PAUSE 1000
DEBUG BELL
oldSecs = secs
DO
GOSUB Get_Time
IF INL <> $FF THEN Alarm_Exit
LOOP UNTIL secs <> oldSecs
oldSecs = secs
DO
GOSUB Get_Time
Alarm_Exit:
RETURN
[B]
I have put a Debug BELL before and after the code where the alarm is supposed to trip and from that I confirmed that the program is indeed reaching that point in the program and then moving beyond and then finally looping. In short the clock works fine however the alarm portion is not functioning on any level.
Zeus
[/B] ' -----[ I/O Definitions ]------------------------------------------------- ' 8 Active-Low Inputs Available On P9 - P15 DataIO PIN 0 ' DS1302.6/DS1620.1/MAX7219.1 Clock PIN 1 ' DS1302.7/DS1620.2/MAX7219.13 DS1302 PIN 2 ' DS1302.5 DS1620 PIN 3 ' DS1620.3 MAX7219 PIN 4 ' MAX7219.12 LCD PIN 6 ' LCD Display Output Speaker PIN 7 ' Speaker Output AlarmSwitch PIN 8 ' Alarm On/Off Switch ' -----[ Constants - DS1302 ]---------------------------------------------- WrSecs CON $80 ' Write Seconds RdSecs CON $81 ' Read Seconds WrMins CON $82 ' Write Minutes RdMins CON $83 ' Read Minutes WrHrs CON $84 ' Write Hours RdHrs CON $85 ' Read Hours CWPr CON $8E ' Write Protect Register WPr1 CON $80 ' Set Write Protect WPr0 CON $00 ' Clear Write Protect WrBurst CON $BE ' Write Burst Of Data RdBurst CON $BF ' Read Burst Of Data WrRam CON $C0 ' Write RAM Data RdRam CON $C1 ' Read RAM Data Hr24 CON 0 ' 24 Hour Mode Hr12 CON 1 ' 12 Hour Mode ' -----[ Constants - MAX7219 ]--------------------------------------------- Decode CON $09 ' BCD Decode Register Brite CON $0A ' Intensity Register Scan CON $0B ' Scan Limit Register ShutDn CON $0C ' Shutdown Register (1 = On) Test CON $0F ' Display Test Mode DecPnt CON 000000 ' Decimal Point Blank CON 11 ' Blank A Digit ' -----[ Constants - DS1804 ]---------------------------------------------- 'Duration CON 5 ' PULSOUT Duration For DS1804 ' -----[ Constants - Other ]----------------------------------------------- Yes CON 1 ' Yes Constant No CON 0 ' No Constant IsOn CON 1 ' On Constant IsOff CON 0 ' Off Constant True CON 1 ' True Constant False CON 0 ' False Constant ' -----[ Variables - DS1302 ]---------------------------------------------- oldSecs VAR Byte ' Old Seconds secs VAR Byte ' Seconds mins VAR Byte ' Minutes hrs VAR Byte ' Hours date VAR Byte ' Date month VAR Byte ' Month day VAR Nib ' Day year VAR Byte ' Year clockMode VAR hrs.BIT7 ' 12/24 Hour Mode Bit AlmMins VAR Byte ' Defines "AlmMins" as a "Byte" sized variable. AlmHrs VAR Nib ' Defines "AlmHrs" as a "Nib" sized variable. flags VAR Byte ' Alarm Flags a1Status VAR flags.BIT0 ' Alarm 1 Status Flag TimeAmPm VAR flags.BIT2 ' Time Am/Pm Flag: 0 = AM, 1 = PM tripFlag2 VAR flags.BIT3 ' Unassigned dimAct VAR flags.BIT4 ' Unassigned dimFlag VAR flags.BIT5 ' Dimmer Flag 1 = Dim, 0 = Bright dimming VAR flags.BIT6 ' Dimming Enabled? 1 = Yes, 0 = No valid VAR flags.BIT7 ' RTC RAM Valid? 1 = Yes, 0 = No 'My Variables MenuNum VAR Nib ' Defines "MenuNum" as a "Nib" sized variable. MenuText VAR Byte ' Defines "MenuText" as a "Byte" sized variable. Text VAR Byte ' Defines "Text" as a "Byte" sized variable. AlarmAmPm VAR Bit ' Defines "AlarmAmPm" as a "Bit" sized variable, Alarm Am/Pm Flag: 0 = AM, 1 = PM Snooze VAR Byte ' Defines "Snooze" as a "Byte" sized variable. LCDOut VAR Byte ' Defines "LCDOut" as a "Byte" sized variable, used for backlight timer. AlarmOnOff VAR Bit ' Defines "AlarmOnOff" as a "Bit" sized variable. ' -----[ Variables - MAX7219 ]--------------------------------------------- d7219 VAR Byte ' Data For MAX7219 dSet VAR Nib ' Dimmer Level Setting ' -----[ Variables - Other ]----------------------------------------------- index VAR Byte ' Loop Counter idxOdd VAR index.BIT0 ' Is Index Odd? (1 = Yes) ioByte VAR Byte ' Data To/From Devices work VAR Byte ' Work Data (Temp Variable) ' -----[ EEPROM Data ]----------------------------------------------------- Defaults: DATA $30, $06, $30, $07, $00, $21, $55, $05, $02, $C3 'My EEPROM DATA AlarmHr DATA "Set ALARM Hours", 0 AlarmMin DATA "Set ALARM Minutes", 0 AmPmAlarm DATA "Set ALARM AM/PM", 0 Snooze5 DATA "Set Snooze", 0 empty DATA "Empty", 0 ' -----[ Initialization - DS1302 ]----------------------------------------- GOSUB Get_RAM ' Initialize DS1302 ' -----[ Initialization of Variables ]------------------------------------- MenuNum = 0 AlmHrs = 6 AlmMins = 30 Snooze = 15 ' -----[ Initialization - MAX7219 ]---------------------------------------- GOSUB Display_Test ' For Debugging Purposes FOR index = 0 TO 7 ' 4 Registers & 4 Values LOOKUP index, [Scan, 5, Brite, 1, Decode, $FF, ShutDn, 1], ioByte SHIFTOUT DataIO, Clock, MSBFIRST, [ioByte] IF (idxOdd = No) THEN No_Load ' Wait For Value To Be Shifted PULSOUT MAX7219, 5 No_Load: NEXT ' -----[ Initialization - LCD ]---------------------------------------- SEROUT LCD, 84, [22, 12] 'Assigns Pin 6 as LCD output, 84 establishes BAUD rate, 22 turns on LCD, 12 clears LCD. PAUSE 5 '"Pause 5" required for "12" command above. ' -----[ Initialization - DS1804 ]----------------------------------------- ' GOSUB Reset_Volume ' Make Sure Volume Is Down ' -----[ Initialization - Other ]------------------------------------------ 'GOSUB Dimmer ' Restore Dimming State ' -----[ Program Code - Main Loop ]---------------------------------------- Start: DO IF (IN12 = 0) OR (IN13 = 0) OR (IN14 = 0) OR (IN15 = 0) THEN 'If any BUTTON INPUT is detected the program enters the "Buttons_Sub" sub routine, GOSUB Buttons_Sub ENDIF GOSUB Get_Time ' Get Date/Time Data From DS1302 DEBUG HOME, "Time: ", HEX hrs, ":", HEX2 mins, 9, HEX2 secs, 9, ? TimeAmPm DEBUG "Alarm: ", DEC2 AlmHrs, ":", DEC2 AlmMins, 9, ? AlarmAmPm DEBUG ? a1Status 'DEBUG CR, HEX2 d1Hrs, ":", HEX2 d1Mins, CR, DEC dSet, CR, BIN flags, CR, BIN8 INL IF secs <> oldSecs THEN ' Next Second? oldSecs = secs ' Update Old Seconds GOSUB Show_Time ' Display Current Time/Status ENDIF IF AlarmSwitch = 0 THEN a1Status = 1 ELSE a1Status = 0 ENDIF IF (AlarmSwitch = 0) THEN DEBUG CR, "Alarm On" ELSE DEBUG CR, CLREOL ENDIF IF a1Status = 1 AND mins = AlmMins AND hrs = AlmHrs AND secs = $00 THEN GOSUB Alarm ' Activate Alarm Sequence ENDIF DEBUG CR, DEC2 ? LCDOut LCDOut = LCDOut + 1 'Adds one to LCDOut counter. IF LCDOut > 30 THEN 'End of nested "Do Loop", scanning for button inputs (Backlight Timer). LCDOut = 0 SEROUT LCD, 84, [18] 'Assigns Pin 6 as LCD output, 84 establishes BAUD rate, 18 turns LCD Backlight Off. 'PAUSE 600 'Pauses for 6 sec. before shutting off LCD. SEROUT LCD, 84, [21] 'Command to Shut Off LCD. ENDIF LOOP 'End of Loop. Sends program back to "Do" statement. ' -----[ Subroutines - DS1302 ]-------------------------------------------- Set_RAM: index = CWPr ' Write Protect Register ioByte = WPr0 ' Clear Write Protect GOSUB RTC_Out ' Send Command ioByte = 0 ' Address Of Alarm 1 Minutes index = WrRam | (ioByte << 1) ' Write RAM Mode + Address ioByte = AlmMins ' Set Alarm 1 Minutes GOSUB RTC_Out ' Write Value ioByte = 1 ' Address Of Alarm 1 Hours index = WrRam | (ioByte << 1) ' Write RAM Mode + Address ioByte = AlmHrs ' Set Alarm 1 Hours GOSUB RTC_Out ' Write Value ioByte = 9 ' Address Of Flags index = WrRam | (ioByte << 1) ' Write RAM Mode + Address ioByte = flags ' Set Flags GOSUB RTC_Out ' Write Value index = CWPr ' Write Protect Register ioByte = WPr1 ' Set Write Protect GOSUB RTC_Out ' Send Command RETURN Get_RAM: index = CWPr ' Write Protect Register ioByte = WPr1 ' Set Write Protect GOSUB RTC_Out ' Send Command ioByte = 0 ' Address Of Alarm 1 Minutes index = RdRam | (ioByte << 1) ' Read RAM Mode + Address GOSUB RTC_In ' Get Value AlmMins = ioByte ' Restore Alarm 1 Minutes ioByte = 1 ' Address Of Alarm 1 Hours index = RdRam | (ioByte << 1) ' Read RAM Mode + Address GOSUB RTC_In ' Get Value AlmHrs = ioByte ' Restore Alarm 1 Hours ioByte = 9 ' Address Of Flags index = RdRam | (ioByte << 1) ' Read RAM Mode + Address GOSUB RTC_In ' Get Value flags = ioByte ' Restore Flags RETURN RTC_Out: HIGH DS1302 ' Select DS1302 SHIFTOUT DataIO, Clock, LSBFIRST, [index, ioByte] LOW DS1302 ' Deselect DS1302 RETURN RTC_In: HIGH DS1302 ' Select DS1302 SHIFTOUT DataIO, Clock, LSBFIRST, [index] SHIFTIN DataIO, Clock, LSBPRE, [ioByte] LOW DS1302 ' Deselect DS1302 RETURN Set_Time: ' DS1302 Burst Write HIGH DS1302 ' Select DS1302 SHIFTOUT DataIO, Clock, LSBFIRST, [WrBurst] SHIFTOUT DataIO, Clock, LSBFIRST, [secs, mins, hrs, date, month, day, year, 0] ' Part Of Previous Line LOW DS1302 ' Deselect DS1302 RETURN Get_Time: ' DS1302 Burst Read HIGH DS1302 ' Select DS1302 SHIFTOUT DataIO, Clock, LSBFIRST, [RdBurst] SHIFTIN DataIO, Clock, LSBPRE, [secs, mins, hrs, date, month, day, year] LOW DS1302 ' Deselect DS1302 clockMode = 0 ' Clear BIT7 IF hrs > $11 THEN ' AM/PM? TimeAmPm = 1 ' PM ELSE TimeAmPm = 0 ' AM ENDIF RETURN ' -----[ Subroutines - MAX7219 ]------------------------------------------- Show_Time: index = 1 ' Set First Digit (Minutes) ioByte = mins.LOWNIB ' Minutes Lower Digit IF TimeAmPm = 1 THEN ioByte = ioByte | DecPnt GOSUB Max_Out ' Send To Display index = 2 ' Set Second Digit (Minutes) ioByte = mins.HIGHNIB ' Minutes Upper Digit IF TimeAmPm = 0 THEN ioByte = ioByte | DecPnt GOSUB Max_Out ' Send To Display work = hrs ' Store Hours In Temp Variable IF work > $12 THEN work = (work.NIB1 * 10) + work.NIB0 ' BCD To Decimal work = work - 12 ' Remove 24 Hour Offset work = (work / 10 << 4) + (Work // 10) ' Decimal To BCD ELSEIF work = $00 THEN ' Midnight Adjustment work = $12 ENDIF index = 3 ' Set Third Digit ioByte = work.LOWNIB | DecPnt ' Hours Lower Digit/DP (Colon) GOSUB Max_Out ' Send To Display index = 4 ' Set Fourth Digit ioByte = Blank ' Pre-Blank Digit IF work.HIGHNIB <> $00 THEN ioByte = work.HIGHNIB ' If Not 0 Set ioByte = ioByte | DecPnt ' Enable Decimal Point (Colon) GOSUB Max_Out ' Send To Display index = 6 ' Set Sixth Digit (DP) ioByte = Blank ' Pre-Blank IF a1Status = 1 THEN ioByte = ioByte | DecPnt ' Enable DP If 1 GOSUB Max_Out ' Send To Display RETURN Display_Test: index = Test ' Select Display Test Register ioByte = 1 ' Set Display Test Mode GOSUB Max_Out ' Send To Display PAUSE 2000 ' Wait For 2 Seconds index = Test ' Select Display Test Register ioByte = 0 ' Clear Display Test Mode GOSUB Max_Out ' Send To Display RETURN Max_Out: SHIFTOUT DataIO, Clock, MSBFIRST, [index, ioByte] PULSOUT MAX7219, 5 ' Latch Data RETURN ' -----[ Subroutines - Alarms ]-------------------------------------------- Alarm: DEBUG BELL PAUSE 1000 DEBUG BELL oldSecs = secs DO GOSUB Get_Time IF INL <> $FF THEN Alarm_Exit LOOP UNTIL secs <> oldSecs oldSecs = secs DO GOSUB Get_Time IF INL <> $FF THEN Alarm_Exit LOOP UNTIL secs <> oldSecs 'NEXT Alarm_Exit: RETURN ' -----[ Subroutines - Snooze_Sub ]-------------------------------------------- 'Insert snooze subroutin here. '________________Sub Routines Buttons_Sub: ' Start of Sub Routine. 'Menu Number Buttons Block IF (IN14 = 0) AND (IN15 = 0) THEN ' Start of "If" statement which adresses both buttons being presses. MenuNum = 0 ' If above statement is true "MenuNum" is set equal to zero. ELSEIF (IN14 = 0) THEN ' Begining of "If" Statement which adds 1 from "MenuNum" variable. MenuNum = MenuNum + 1 ' If above condition is true, adds 1 from "MenuNum" variable. ELSEIF (IN15 = 0) THEN ' Begining of "If" Statement which subtracts 1 from "MenuNum" variable. MenuNum = MenuNum - 1 ' If above condition is true, subtracts 1 from "MenuNum" variable. ENDIF ' End of "IF" statement. 'Alarm Hour Buttons Block IF (MenuNum = 0) THEN SELECT IND & 3 ' Start of "Select Case" statement, possibilities are 00, 01, 10 and 11. CASE = 0 ' Case 3, both buttons pressed... Reset AlmHrs = 6 ' If both buttons are pressed alarm hours set TO 6. AlarmAmPm = 0 AlmMins = 0 CASE = 1 ' Case 2, one button is pressed... advance 1. AlmHrs = AlmHrs + 1 IF AlmHrs = 13 THEN AlmHrs = 1 ' Starts variable counting over at "12" if value is less than "1". CASE = 2 ' Case 1, other button is pressed... subtract 1. AlmHrs = AlmHrs - 1 IF AlmHrs = 0 THEN AlmHrs = 12 ' Starts variable counting over at "1" if value is greater than "12". ENDSELECT ENDIF ' Alarm Minutes Buttons Block IF (MenuNum = 1) THEN SELECT IND & 3 ' Possibilities are 00, 01, 10 and 11. CASE = 0 AlmMins = 0 ' Reset to Zero CASE = 1 AlmMins = AlmMins + 1 // 60 ' Count up mod 60 using // operator CASE = 2 AlmMins = AlmMins - 1 MAX 59 ' Count down mod 60, return to 59 when value becomes 255 ENDSELECT ENDIF 'Am/Pm Buttons Block IF (MenuNum = 2) THEN SELECT IND & 3 ' Possibilities are 00, 01, and 10. CASE = 0 DEBUG CR, "Test" CASE = 1 AlarmAmPm = AlarmAmPm + 1 MAX 1 CASE = 2 AlarmAmPm = AlarmAmPm - 1 MAX 0 'AlarmAmPm = AlarmAmPm - 1 // 2 ENDSELECT ENDIF ' Snooze Duration (+/- 5 Minutes) Buttons Block IF (MenuNum = 3) THEN SELECT IND & 3 ' Possibilities are 00, 01, 10 and 11. CASE = 0 ' Reset Snooze = 15 CASE = 1 ' Count up mod 60 using // operator Snooze = Snooze + 5 IF Snooze = 60 THEN Snooze = 10 CASE = 2 ' Count down mod 60, return to 59 when value becomes 255 Snooze = Snooze - 5 IF Snooze = 5 THEN Snooze = 55 ENDSELECT ENDIF GOSUB Display_Sub RETURN Display_Sub: 'DEBUG HOME ' Returns cursor to "Home" postion. SEROUT LCD, 84, [12] ' Assigns Pin 6 as LCD output, 84 establishes BAUD rate, 12 clears LCD. LOOKUP MenuNum, [AlarmHr, AlarmMin, AmPmAlarm, Snooze5, empty , empty , empty , empty , empty , empty , empty , empty , empty , empty , empty , empty], MenuText DO ' Start of MenuText Display "Do" loop READ MenuText, Text ' Reads current MenuText from Lookup table and stores it to "Storage" variable. MenuText = MenuText + 1 IF (Text = 0) THEN EXIT 'DEBUG CLREOL, Text ' "CLREOL" format command clears everything to right of cursor before displaying "Storage". SEROUT LCD, 84, [22, 17, Text] ' Assigns Pin 6 as LCD output, 84 establishes BAUD rate, 17 turns on Back Light. LOOP ' End of MenuText Display "Do" loop 'DEBUG CR, CLREOL, ? AlmHrs SEROUT LCD, 84, [CR, DEC AlmHrs] ' Assigns Pin 6 as LCD output, 84 establishes BAUD rate, displays AlarmHrs value on 2nd line LCD. 'DEBUG CLREOL, ? AlarmMins SEROUT LCD, 84, [":", DEC2 AlmMins] ' Assigns Pin 6 as LCD output, 84 establishes BAUD rate, displays ":" on 2nd line of LCD. IF (AlarmAmPm = 0) THEN ' Start of "If Then" statement which detrmines Am/Pm display. 'DEBUG "AM" SEROUT LCD, 84, [9, "AM"] ' Assigns PIN 6 as LCD OUTPUT, 84 establishes BAUD rate, displays "AM" ON 2nd line of LCD. ELSE 'DEBUG "PM" SEROUT LCD, 84, [9, "PM"] ' Assigns PIN 6 as LCD OUTPUT, 84 establishes BAUD rate, displays "PM" ON 2nd line of LCD. ENDIF ' End of "If Then" statement which detrmines Am/Pm display. IF (AlarmSwitch = 0) THEN ' Modify code so that this continually updates the On/Off Alarm state. SEROUT LCD, 84, [9, "-Alarm On-"] ENDIF 'DEBUG CR, ? Snooze SEROUT LCD, 84, [CR, DEC2 Snooze, 9, "Minute Snooze"] ' Assigns Pin 6 as LCD output, 84 establishes BAUD rate, displays Snooze value on 3rd line of LCD. LCDOut = 0 RETURN [B]I understand what you are saying to a point however shouldn't the Debug BELL at least sound twice?
Zeus
In order to figure out the alarm function I simply have the alarm represented as a simple DEBUG BELL command for now, (see code above). I set the alarm time to a time in the very near future and the alarm time comes as goes yet no DEBUG BELL command sounds.
Does this help?
IF a1Status = 1 AND mins = AlmMins AND hrs = AlmHrs AND secs = $00 THEN GOSUB Alarm ' Activate Alarm Sequence ENDIF ' DEBUG "Alm Test: ",a1Status," ",mins," ",AlmMins," ",hrs," ",AlmHrs," ",secs,CR IF a1Status = 1 AND mins = AlmMins AND hrs = AlmHrs AND secs = $00 THEN DEBUG "Alarm satisfied",CR GOSUB Alarm ' Activate Alarm Sequence DEBUG "Alarm exited",CR ENDIFIf you don't get the Alarm satisfied message when you expect it, uncomment the 1st DEBUG statement and see what's not what you expect.
I added you bit of code into my code and there was no change. The Debug window was constantly updating with data and as such did not provide any useful insight as to what the problem might ultimately be. I am unfamiliar with your code, specifically...
What was the intent and/or what were you expecting as the result?
Zeus
Zeus
There's an art to debugging that mostly has to do with forgetting that you wrote the program and looking at it as if you were new to the program and the task it's to accomplish. You insert DEBUG statements to trace through it, totest the various paths through the program that it takes and under what circumstances. You display the variables to ensure that their values are what you expect, assuming nothing. You may come up with test cases that will exercise the various functions of the program and reveal boundary cases.
Moving on... Taking a stab at you intent I added the following line to my code...
DEBUG HOME, HEX hrs, ":", HEX2 mins, ":", HEX2 secs, 9, ? a1Status 'This is the line of code mentioned above IF a1Status = 1 AND mins = AlmMins AND hrs = AlmHrs AND secs = $00 THEN GOSUB Alarm ' Activate Alarm SequenceThis confirmed that the four parameters are present right before the block of code is run which determines whether or not to enter the Alarm sub routine. Unfortunately no alarm sounded.
My immediate thought is that there is something early in the code which somehow locks out the remainder of the program from acting/seeing on the data?
I am at a loss here.
Zeus
How about tracing backwards from the GOSUB Alarm? ... putting in DEBUG statements to see what execution path the program is following?
GOSUB Alarm' Activate Alarm Sequence
ELSE
DEBUG BELL - sounded
ENDIF
There must be something simple that I am missing.
I'll take another stab at adding your code and see what happens.
DEBUG HOME, HEX hrs, ":", HEX2 mins, ":", HEX2 secs, 9, ? a1Status IF a1Status = 1 AND mins = AlmMins AND hrs = AlmHrs AND secs = $00 THEN DEBUG BELL ENDIFDoes anyone have any thoughts as to what I am missing here?
Zeus
IF (a1Status = 1) AND (mins = AlmMins) AND (hrs = AlmHrs) AND (secs = $00) THEN
You never gave me this much help back in the day, What gives!!!!!
What ever it is...
Merry Chirstmas...
Bell sounded, (multiple times oddly enough) but this is progress even though it is less than perfect. Also, it worked twice in a row and now it no longer sounds?! I have reloaded the code and currently it is not working, but regardless this is encouraging.
Funny thing is I tried containing each statements before and had no luck with the sub routine functioning.
Next I will try and move the alarm function to a dedicated sub routine function and work out the quirks.
Thanks again,
Zeus
I had a taste if success. I place brackets around each statement and the alarm actually sounded on two separate occasions. However after the second test I could not get it to work again. I made no changes to the code between trials.
Two things do not make sense to me. One I have placed the statements in brackets before and had no luck, so why this time and why intermittent performance? Also I noticed that my LCD was flickering prior to the first run. I am thinging that there may possibly be a power problem?
