TriBlade II - Thinking about a new revision - suggestions please
Cluso99
I have had a number of enquiries about my TriBlade pcbs. However I ran out a long time ago. The pcbs were sooo expensive due to the size, I have not wanted to outlay that expense again.
Quite some time ago I started the design of a replacement TriBlade that would remove some of the features never used, and therefore reduce the pcb size, and hence pcb cost. Nothing eventuated. Here are my current thoughts...
TriBlade II
A through hole pcb design where possible (exceptions include FT232RL, TO252 power regulators, microSD and perhaps RTC)
Prop 1:
Availability: If enough interest... maybe late January, early February 2012
TriBlade II
Prop 1:
- Prop, xtal, eeprom (pluggable xtal, able to be overclocked >=104MHz)
- I/O selectable via links/shunts...
- Keyboard (PS2 mode - dual footprint PS2 or USB)
- Mouse (PS2 mode - dual footprint PS2 or USB )
- TV (RCA and AV4 3.5mm connector combined with stereo)
- Stereo Out (AV4 3.5mm connector combined with TV)
- ADC Input (2 pins or 4 pins) ??? (any suggestions???)
- MicroSD ???
- Header for other unused pins
- 1 x 512KB 55ns SRAM
- MicroSD
- RTC DS1340C??? (any suggestions???)
- Compatible with RamBlade 3
- All I/O on pin headers.
- FT232RL (smt) circuit with transistor reset circuitry
- miniUSB connector
- Self-contained circuit so can be used with other boards via cable header
- External 5V-9V DC via 2.1mm center positive plug
- Onboard 5V and 3V3 regulators TO252 SMT
- Power switch
- 3 uncommited LEDs provided for testing/debugging
- Links/shunts to link P30/31 together between props and propplug
- Prop 2 only has 1x 512KB SRAM, not 2, and no latches (i.e. faster)
- Prop 2 does not have optional Flash chip
- Prop 1 does not have SRAM option
- Prop 3 will have the more common 5v,Gnd,Pn..Pn+7 connectors to each port
Will TriBlade II use DIP or SMT? (Sorry if I missed it. I looked through your discription a couple of times and couldn't find it.)
I'm guessing you'll move to SMT to save on board size.
BTW, I'm always very impressed with how nice your boards look.
What's the advantages of using the 512KB SRAM? It uses a bunch of address lines, right? So is it a lot faster than using eight 23K256 SRAM chips in parallel? (Sorry, if this is a dumb question, I'm still trying to understand the many different memory types.)
Since you are bringing out unused pins on prop 3 to a header, I wonder what your thoughts are about making this a Gadget Gangster format? You could do this as well as a standard header if you wanted.
Drac: Unfortunately I do not think there is enough space to put on the pcb what I want and yet track to the Gadget Gangster footprint. I will however take a look see - good suggestion.
Just my 0.002c
-Tor
