Life Expectancy of Tenergy Li-ion Cell
doggiedoc
I have a dead Tenergy cell. I would have expected it to last longer than this. Any one care to give me any insight into how I may have damaged it. The last thing I was doing with it was powering a breadboard that I was testing capacitors on using another Li-ion charger/pack in series with it.
:frown:
Paul
:frown:
Paul
Jim you mentioned that each cell has internal circuitry. Perhaps this is where the problem is with this cell?
Paul
Time for Ken to say "Send it back and I'll have Matt look at it, in the mean time here's a new one"
Yay!
For the most part, well-taken Li-ion cells really last much longer than other chemistries. In fact, the Li-ion FE technology just gets better with age.
In your case, you may have triggered a 'false alarm' with the inner protection board. Or one cell may have discharged much faster than the other and by letting it rest, it came back to a functional range. Overall, I suspect your batteries will mellow with use.
From the Lithium ion battery Wikipedia.....
Prolonging battery pack life
* Depletion below the low-voltage threshold (2.4 to 2.8 V/cell, depending on chemistry) results in a dead battery which does not even appear to charge because the protection circuit (a type of electronic fuse) disables it.[96]
* Lithium-ion batteries should be kept cool; they may be stored in a refrigerator.[96][97]
* The rate of degradation of Lithium-ion batteries is strongly temperature-dependent; they degrade much faster if stored or used at higher temperatures.[96][98]
Li-Po's are funny animals. Glad that worked out.
So it may be that you just hit a trigger due to an excessive discharge and the battery reset after a delay.
BTW, the low-voltage limit is officially 2.437 Volts and nominally 2.5 Volts. At that point the cells apparently shut down until recharged.
And there is thermal protection as well.
Paul
