Corcom (or other) AC line filters
xanatos
I've always been a fan of Corcom Line filters - partly because I had a seemingly unending supply of them, for free, from surplus equipment. I never had to buy them before... until now. But now when I search Digikey, Mouser or Jameco, it seems that the ones I want to use are not available, and I suspect it is because I am not understanding the criteria for which I am searching. While I am using the Corcoms with regular 120VAC, must I specify them as 120 VAC, or can I go with a unit specified at 250 VAC or above? Those units LOOK like the ones I have been using... I just need to know if when using Corcom line filters, if it is fine/normal practice to use a unit rated for 250vac+ on a system that will be using regular 120 vac line voltage.
Also - if anyone has a better suggestion for line filters than Corcom, I'm open to hearing about them. I just got used to using Corcoms because I had so many of them that I removed from scrapped equipmnent.
THANKS!
Dave
THANKS!
Dave
This helps to make reading the spec sheet about as clear as mud.
http://www.cor.com/pdf/EC.pdf
There really isn't anything obvious concerning 120VAC and 250VAC. The only item was leakage current.
I'm gonna guess you'd be ok with a 250VAC rated unit in a 120VAC application. It's really about the current anyway - for the chokes to work properly, that is.
DJ
Dave
If you specify a certain parameter and an item doesn't have that particular parameter in it's database entry, it won't show up in the search results. For instance, if you're searching for a certain color of LED in 3mm, an LED with it's size specified as T-1 (or no size at all) probably won't appear in search results. In your case, 120 VAC may exclude items rated 90-240 VAC.
I wish they had a boolean search like the old Altavista search engine had, where you could specify AND, OR, AND NOT, and my favorite, NEAR... NEAR was awesome!
Dave
Corvair AC oil filters: Definitely
What??? :-)
Like!
From what I can sort out, many of the modern wall warts are just fine for microcontrollers and don't require further transident trapping unless you have local problems with lightning.
BTW xanatos: You live near the world's largest supply of Corvair parts in Shelburne Falls, MA. I'm so jealous!
http://www.corvair.com/user-cgi/main
And LoopeyB... So far, the ONLY failures I've ever had on my production designs have been due to voltage spikes due primarily to lightening (upstate NY). So I have become a stickler for filters on everything.
A story related to this... When I was about 14, I built my first speech generator using an SPO-256. It was working nicely until I made a mod to make a few phoneme combinations directly addressable by using a dip switch. But I made a critical error by not isolating it from my air compressor pump motor. I powered it up and when the motor started up, my poor SPO-256 actually spoke of its own accord as it was dying. It actually said: "ow ow ow ow ow ow ow..." and fell silent forever. I actually felt sorry for it. I have always tried to protect my circuitry to a ridiculous degree ever since then! :-)
