controling two pins at one time
Its been a while since i have played with the BS2 I need to turn on 2 pins at the same time. I rember doing something like HIGH %00001110000 or somthing like that.
Any help would be great
Mike --
Open the Stamp Editor, and click on the Help button. Select Index and type in OUTS. Double-click OUTS and you'll get a lot of information. Using %0000000011100000 will set the 6th through eighth bits, and clear the others.
HTH,
--Rich
works pretty quick, too!
