Remote Motor controler or sylenoid activation ... very remote!
Ok, first post here! Thanks in advance for your help. I am designing a project, and I have little experience with small electronics. I can build just about anything, just need guidance and some help!
Through remote control, I need to activate a switch or possibly motor controller that opens and closes a 12vdc Linear actuator. Like this one:
http://www.robotshop.com/firgelli-4-150lb-linea-actuator.html
The distance is the problem. 1 mile - 1.5 miles away (line of sight, no obstruction).
I do not need fine control of the actuator, speed doesn't matter, just open and close it.
I will have 12v dc power at the site of the actuator to operate the actuator and any other electronics.
The actuator will release a gate, closing off a cattle pen. That design is not a problem. I can make the mechanics of the gate work, the actuators position and function as well. Just need to know how to operate the actuator from a mile away.
Thanks for your help.
Is this possible?
Is this possible?
Your idea of a cell phone intrigues me! Tell me more!
In addition to the one wireless surveillance video setup I have that is used for monitoring, What if I had a transmitter on my side and a receiver at the remote location that could be used to activate the actuator.
Is there an idea there?
http://www.digi.com/xbee/
You will want to colocate the Xbee module with the antenna to avoid running a lossy cable between them. That will require some weather-proofing.
Never thought my solution would be an $18 one ...
Erco, thanks for the idea. You saved me a ton. I will try to post photo or video of the result once it is all constructed. I know it's simple, but it is a unique setup for a very unique problem.
Thanks to everyone who replied.
How do I change the status to "Solved" I can't figure it out.
FYI, this is the one I bought http://www.gsm-auto.com/
The possibilities are numerous. Close one gate, and open another gate all from my iphone, ipad or even a landline phone, from anywhere in the World!
Thanks again for your help.
I'd be interested in reading more about that one. Was it by any chance similar to http://www.thinkgeek.com/interests/doctorwho/a150/ or http://www.cellphonedigest.net/news/2008/02/light_charm_that_senses_incomi.php ?
