Bluetooth with Propeller
mynet43
I purchased one of the Easy Bluetooth modules (#30085) from Parallax.
The only sample code they supply is not for the Propeller. This looks like it should be easy to interface to the Prop.
Has anyone written Prop code to use this product?
Thank you for your help.
Jim
Jim
You have to connect and pair it to your PC first, however, before it will work at all. Then open the serial port in your computer after it has been paired. E.g. open the serial port using PST.
