Multiple MOFET on one chip? Or circuit alternative
Hello,
I'm using this circuit as the basis of a leak detector that are 15-30' from a BS2:
I have four of these on a breadboard to detect leaks at four different locations and its taking up lots of space. I suppose the higher sensitivity of the MOSFET helps overcome the lenth of wire between the detectors and the BS2.
Is there a chip available that combines four (or more) MOSFETs into one discrete package to minimize the circuit?
Is a MOSFET overfkill for this purpose? Would any other dicrete device perform the same purpose but in a smaller package? OP AMP maybe?
I've seen the Conductivity Sensor on page 131 of Applied Sensors v1.4 but I really just need a reliable Go/No Go type of device vs. a degree of conductance.
falcon
falcon
There are smaller FETs available, logic-level jobs, TO-92: VN2222L, BS170, 2N7000
These four leak detectors actually feed the 74HC165 circuit found on page 150 of Stampworks v2.1. I figured the 511 might be overkill but that's what the circuit (found on page 112 of Matt Gilliland's The Microcontroller Application Cookbook 2) called for.
I'll take a look at that those T0-92 packaged FETs.
falcon
These are 2 N channel fets in an SOIC-8 package for 30~60 cents. There are lots of "dual" variants in exactly the same SOIC-8 package
