ok, I apologize I'm running on little sleep and I'm on the verge of getting my senior project working and this one thing is what is standing in my way.
No need to apologize. The incoming data will most likely be always lower case anyway so the conversion is there just in case. Effectively "a".."f" is treated the same as "A".."F". You mentioned that you had ratronic's program working (reading $66). Meaning you already read the first byte of the number. Now simply read another byte (io.rx) and put both values through the conversion which gives you the value you want.
repeat 'repeat continued
repeat until io.rx == "R" 'wait here until "R" received
repeat i from 0 to 2 'receive 3 more characters "SSI"
io.rx '
if io.rx == "=" 'if the fifth character is "="
A := io.rx ' then assign 6th character to A
B := io.rx ' then assign 7th character to B
C := convert(A)*16 + convert(B)
Ok, trying to put the result of C on the serial terminal, but nothing is displaying
EDIT: Once this part gets fixed I think that should do it, just need to return the value of C.
CON
_CLKMODE = XTAL1 + PLL16X
_XINFREQ = 5_000_000
OBJ
io : "FullDuplexSerial.spin"
pst : "Parallax Serial terminal"
Pub getRSSI | i, A, B, C
pst.StartRxTx(31,30,0,9600) 'this starts the serial terminal for debug display
waitcnt(clkfreq*3 + cnt) 'delay 3 seconds so you can open the parallax serial terminal
io.start(0, 1, 0, 9600) 'this starts the serial port for your bluesmirf
io.str(string("$$$")) 'this sends string
repeat 1000000 'use waitcnt for delay
io.tx(13) 'transmit CHR/LF
io.tx("C") 'transmit "C"
io.str(string("$$$")) 'send string
io.tx("L") 'transmit "L"
io.rx '
A := io.rx
B := io.rx ' then assign A to sixth character
waitcnt(clkfreq/10 + cnt) 'delay 1/10 of a second
pst.Str(C)
PRI convert(char)
case char
"0".."9": return char - "0"
"a".."f", "A".."F": return (char | $20) - "a" + 10
other: abort
C is not a string, just a byte value. So try pst.hex(C, 2) or pst.dec(C) instead. Also, while still in the experimental state you might want to consider replacing abort with return.
Ok I will try that, I have to go to bed, need to get up to a controls systems class in a few hours. When I try this I will write back with results. Also again, thank you so much for the help. This is the most helpful website I've ever used.
The code as such works. I used this slightly modified test case (fake bluesmirf):
CON
OBJ
io[3]: "FullDuplexSerial"
VAR
long stack[32]
PUB getRSSI | i, A, B, C
cognew(blue, @stack{0})
io{0}.start(31, 30, 0, 115200) 'this starts the serial terminal for debug display
io[1].start(16, 17, 0, 9600) 'this starts the serial port for your bluesmirf
io[1].str(string("$$$")) 'this sends string
io[1].tx(13) 'transmit CHR/LF
io[1].tx("C") 'transmit "C"
io[1].str(string("$$$")) 'send string
io[1].tx("L") 'transmit "L"
repeat until io[1].rx == "R" 'wait here until "R" received
io[1].rx '
if io[1].rx == "=" 'if the fifth character is "="
A := io[1].rx
B := io[1].rx ' then assign A to sixth character
io{0}.hex(C, 2)
PRI convert(char)
case char
other: return
PRI blue
io[2].start(17, 16, %0000, 9600)
repeat while io[2].rx <> "L"
repeat
io[2].str(string("RSSI="))
io[2].hex(frqa++, 2)
io[2].tx(",")
io[2].hex(0, 2)
io[2].str(string(13, 10))
waitcnt(clkfreq/2 + cnt)
DAT
Great! instead of io{0}.hex(C,2), I put pst.hex(C,2) and got the two digit hex readings that I wanted on the serial terminal, now I would just like to have that result returned to the method so I can call RSSI in another program. To do that should I just say
result io{0}.hex(C,2)
Also how do I do a hex greater than or less than comparison?
EDIT:
I just put this as my code:
CON
OBJ
io.rx '
A := io.rx
return C := convert(A)*16 + convert(B)
PRI convert(char)
case char
other: return
I have it set to return C. If I do this, I should be able to call the getRSSI method in another program and set a variable equal to getRSSI right?
x := hex(getRSSI,2) ?
VAR
BYTE X
OBJ
RSSI: "getRSSI"
PUB main | X
X := RSSI
The code I currently have is not displaying my result.
I just currently had pst.Str(X) setup, Im not sure what data type X is, even though it is displaying hex values.
CON
OBJ
VAR
BYTE X
PUB main
X := getRSSI
pst.str(X)
io.rx '
A := io.rx
PRI convert(char)
case char
other: return
That looks OK (for returning the value). The issue I see here is that from the hex dump you sent in post #23 it looks like the bluesmirf keeps repeating the RSSI sequence on its own once it got the L command. If you keep calling the getRSSI method it may get confused because you restart the serial drivers etc. In that case it would be better to either stop said sequence (not sure if there is a command) before returning the result or let the bluesmirf loop run in its own cog and simply report the result to a global variable.
Ryoshima you don't have to start a new cog you could try something like this
CON
OBJ
VAR
long x
PUB main
repeat
x := getRSSI 'assign x with value returned calling getRSSI
pst.char(1) 'home debug cursor
pst.hex(x, 2) 'print 2 digit hex value of x
waitcnt(clkfreq+cnt) 'wait one second
io.rxflush
io.rx '
A := io.rx
PRI convert(char)
case char
other: return
Edit: you should replace the repeat 1000000 with a waitcnt and I added a rxflush for the io
Ok, once we get the returned value out of getRSSI, I would like to get 3 different readings with variables x,y,z. I would then like to compare x,y,z and find which variable has the greatest value. How would those comparisons go? Since these are hex values would I have to do something special?
I was also going to say that if the device spits out a comma between the two hex digits then you should add an extra io.rx between A and B. As far as comparing hex, decimal or anything else you would do something like this
if x > y
'do something
Edit: nevermind about the comma I forgot you were wanting only one digit
repeat 'repeat continued repeat until io.rx == "R" 'wait here until "R" received repeat i from 0 to 2 'receive 3 more characters "SSI" io.rx ' if io.rx == "=" 'if the fifth character is "=" A := io.rx ' then assign 6th character to A B := io.rx ' then assign 7th character to B C := convert(A)*16 + convert(B)EDIT: Once this part gets fixed I think that should do it, just need to return the value of C.
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ io : "FullDuplexSerial.spin" pst : "Parallax Serial terminal" Pub getRSSI | i, A, B, C pst.StartRxTx(31,30,0,9600) 'this starts the serial terminal for debug display waitcnt(clkfreq*3 + cnt) 'delay 3 seconds so you can open the parallax serial terminal io.start(0, 1, 0, 9600) 'this starts the serial port for your bluesmirf io.str(string("$$$")) 'this sends string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("C") 'transmit "C" io.tx(13) 'transmit CHR/LF repeat 1000000 'use waitcnt for delay io.str(string("$$$")) 'send string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("L") 'transmit "L" io.tx(13) 'transmit CHR/LF repeat 'repeat continued repeat until io.rx == "R" 'wait here until "R" received repeat i from 0 to 2 'receive 3 more characters "SSI" io.rx ' if io.rx == "=" 'if the fifth character is "=" A := io.rx B := io.rx ' then assign A to sixth character waitcnt(clkfreq/10 + cnt) 'delay 1/10 of a second C := convert(A)*16 + convert(B) waitcnt(clkfreq/10 + cnt) pst.Str(C) waitcnt(clkfreq/10 + cnt) PRI convert(char) case char "0".."9": return char - "0" "a".."f", "A".."F": return (char | $20) - "a" + 10 other: abortCON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ io[3]: "FullDuplexSerial" VAR long stack[32] PUB getRSSI | i, A, B, C cognew(blue, @stack{0}) io{0}.start(31, 30, 0, 115200) 'this starts the serial terminal for debug display waitcnt(clkfreq*3 + cnt) 'delay 3 seconds so you can open the parallax serial terminal io[1].start(16, 17, 0, 9600) 'this starts the serial port for your bluesmirf io[1].str(string("$$$")) 'this sends string repeat 1000000 'use waitcnt for delay io[1].tx(13) 'transmit CHR/LF io[1].tx("C") 'transmit "C" io[1].tx(13) 'transmit CHR/LF repeat 1000000 'use waitcnt for delay io[1].str(string("$$$")) 'send string repeat 1000000 'use waitcnt for delay io[1].tx(13) 'transmit CHR/LF io[1].tx("L") 'transmit "L" io[1].tx(13) 'transmit CHR/LF repeat 'repeat continued repeat until io[1].rx == "R" 'wait here until "R" received repeat i from 0 to 2 'receive 3 more characters "SSI" io[1].rx ' if io[1].rx == "=" 'if the fifth character is "=" A := io[1].rx B := io[1].rx ' then assign A to sixth character C := convert(A)*16 + convert(B) waitcnt(clkfreq/10 + cnt) io{0}.hex(C, 2) waitcnt(clkfreq/10 + cnt) PRI convert(char) case char "0".."9": return char - "0" "a".."f", "A".."F": return (char | $20) - "a" + 10 other: return PRI blue io[2].start(17, 16, %0000, 9600) repeat while io[2].rx <> "L" repeat io[2].str(string("RSSI=")) io[2].hex(frqa++, 2) io[2].tx(",") io[2].hex(0, 2) io[2].str(string(13, 10)) waitcnt(clkfreq/2 + cnt) DATresult io{0}.hex(C,2)?
EDIT:
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ io : "FullDuplexSerial.spin" pst : "Parallax Serial terminal" Pub getRSSI | i, A, B, C pst.StartRxTx(31,30,0,9600) 'this starts the serial terminal for debug display waitcnt(clkfreq*3 + cnt) 'delay 3 seconds so you can open the parallax serial terminal io.start(0, 1, 0, 9600) 'this starts the serial port for your bluesmirf io.str(string("$$$")) 'this sends string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("C") 'transmit "C" io.tx(13) 'transmit CHR/LF repeat 1000000 'use waitcnt for delay io.str(string("$$$")) 'send string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("L") 'transmit "L" io.tx(13) 'transmit CHR/LF repeat 'repeat continued repeat until io.rx == "R" 'wait here until "R" received repeat i from 0 to 2 'receive 3 more characters "SSI" io.rx ' if io.rx == "=" 'if the fifth character is "=" A := io.rx B := io.rx ' then assign A to sixth character return C := convert(A)*16 + convert(B) PRI convert(char) case char "0".."9": return char - "0" "a".."f", "A".."F": return (char | $20) - "a" + 10 other: returnI have it set to return C. If I do this, I should be able to call the getRSSI method in another program and set a variable equal to getRSSI right?
VAR BYTE X OBJ RSSI: "getRSSI" PUB main | X X := RSSIEdit: I am assuming that you saved the top program in your post above as getRSSI.spin
Edit2: Sometime's that can be a little confusing having an object named after one of it's methods.
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ io : "FullDuplexSerial.spin" pst : "Parallax Serial terminal" VAR BYTE X PUB main X := getRSSI pst.str(X) Pub getRSSI | i, A, B, C pst.StartRxTx(31,30,0,9600) 'this starts the serial terminal for debug display waitcnt(clkfreq*3 + cnt) 'delay 3 seconds so you can open the parallax serial terminal io.start(0, 1, 0, 9600) 'this starts the serial port for your bluesmirf io.str(string("$$$")) 'this sends string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("C") 'transmit "C" io.tx(13) 'transmit CHR/LF repeat 1000000 'use waitcnt for delay io.str(string("$$$")) 'send string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("L") 'transmit "L" io.tx(13) 'transmit CHR/LF repeat 'repeat continued repeat until io.rx == "R" 'wait here until "R" received repeat i from 0 to 2 'receive 3 more characters "SSI" io.rx ' if io.rx == "=" 'if the fifth character is "=" A := io.rx B := io.rx ' then assign A to sixth character return C := convert(A)*16 + convert(B) PRI convert(char) case char "0".."9": return char - "0" "a".."f", "A".."F": return (char | $20) - "a" + 10 other: returnVAR long stack[32] PUB start cognew(getRSSI, @stack{0})Inside that method you simply assign convert(A)*16 + convert(B) to a global variable instead of C. And you obviously don't return from it.CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ io : "FullDuplexSerial.spin" pst : "Parallax Serial terminal" VAR long x PUB main io.start(0, 1, 0, 9600) 'this starts the serial port for your bluesmirf pst.StartRxTx(31,30,0,9600) 'this starts the serial terminal for debug display waitcnt(clkfreq*3 + cnt) 'delay 3 seconds so you can open the parallax serial terminal repeat x := getRSSI 'assign x with value returned calling getRSSI pst.char(1) 'home debug cursor pst.hex(x, 2) 'print 2 digit hex value of x waitcnt(clkfreq+cnt) 'wait one second io.rxflush Pub getRSSI | i, A, B, C io.str(string("$$$")) 'this sends string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("C") 'transmit "C" io.tx(13) 'transmit CHR/LF repeat 1000000 'use waitcnt for delay io.str(string("$$$")) 'send string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("L") 'transmit "L" io.tx(13) 'transmit CHR/LF repeat until io.rx == "R" 'wait here until "R" received repeat i from 0 to 2 'receive 3 more characters "SSI" io.rx ' if io.rx == "=" 'if the fifth character is "=" A := io.rx B := io.rx ' then assign A to sixth character return C := convert(A)*16 + convert(B) PRI convert(char) case char "0".."9": return char - "0" "a".."f", "A".."F": return (char | $20) - "a" + 10 other: returnEdit: you should replace the repeat 1000000 with a waitcnt and I added a rxflush for the io
