ok, I apologize I'm running on little sleep and I'm on the verge of getting my senior project working and this one thing is what is standing in my way.
No need to apologize. The incoming data will most likely be always lower case anyway so the conversion is there just in case. Effectively "a".."f" is treated the same as "A".."F". You mentioned that you had ratronic's program working (reading $66). Meaning you already read the first byte of the number. Now simply read another byte (io.rx) and put both values through the conversion which gives you the value you want.
repeat'repeat continuedrepeatuntil io.rx == "R"'wait here until "R" receivedrepeat i from0to2'receive 3 more characters "SSI"
io.rx 'if io.rx == "="'if the fifth character is "="
A := io.rx ' then assign 6th character to A
B := io.rx ' then assign 7th character to B
C := convert(A)*16 + convert(B)
Ok, trying to put the result of C on the serial terminal, but nothing is displaying
EDIT: Once this part gets fixed I think that should do it, just need to return the value of C.
CON_CLKMODE = XTAL1 + PLL16X_XINFREQ = 5_000_000OBJ
io : "FullDuplexSerial.spin"
pst : "Parallax Serial terminal"PubgetRSSI | i, A, B, C
pst.StartRxTx(31,30,0,9600) 'this starts the serial terminal for debug displaywaitcnt(clkfreq*3 + cnt) 'delay 3 seconds so you can open the parallax serial terminal
io.start(0, 1, 0, 9600) 'this starts the serial port for your bluesmirf
io.str(string("$$$")) 'this sends stringrepeat1000000'use waitcnt for delay
io.tx(13) 'transmit CHR/LF
io.tx("C") 'transmit "C"
io.tx(13) 'transmit CHR/LFrepeat1000000'use waitcnt for delay
io.str(string("$$$")) 'send stringrepeat1000000'use waitcnt for delay
io.tx("L") 'transmit "L"
io.tx(13) 'transmit CHR/LF repeat'repeat continuedrepeatuntil io.rx == "R"'wait here until "R" receivedrepeat i from0to2'receive 3 more characters "SSI"
A := io.rx
B := io.rx ' then assign A to sixth characterwaitcnt(clkfreq/10 + cnt) 'delay 1/10 of a second
pst.Str(C)
PRIconvert(char)case char
"0".."9": return char - "0""a".."f", "A".."F": return (char | $20) - "a" + 10other: abort
C is not a string, just a byte value. So try pst.hex(C, 2) or pst.dec(C) instead. Also, while still in the experimental state you might want to consider replacing abort with return.
Ok I will try that, I have to go to bed, need to get up to a controls systems class in a few hours. When I try this I will write back with results. Also again, thank you so much for the help. This is the most helpful website I've ever used.
Great! instead of io{0}.hex(C,2), I put pst.hex(C,2) and got the two digit hex readings that I wanted on the serial terminal, now I would just like to have that result returned to the method so I can call RSSI in another program. To do that should I just say
result io{0}.hex(C,2)
Also how do I do a hex greater than or less than comparison?
EDIT:
I just put this as my code:
A := io.rx
B := io.rx ' then assign A to sixth characterreturn C := convert(A)*16 + convert(B)
"0".."9": return char - "0""a".."f", "A".."F": return (char | $20) - "a" + 10other: return
I have it set to return C. If I do this, I should be able to call the getRSSI method in another program and set a variable equal to getRSSI right?
x := hex(getRSSI,2) ?
VARBYTE X
OBJ
RSSI: "getRSSI"PUBmain | X
X := RSSI
The code I currently have is not displaying my result.
I just currently had pst.Str(X) setup, Im not sure what data type X is, even though it is displaying hex values.
pst : "Parallax Serial terminal"VARBYTE X
PUBmain
X := getRSSI
pst.str(X)
A := io.rx
That looks OK (for returning the value). The issue I see here is that from the hex dump you sent in post #23 it looks like the bluesmirf keeps repeating the RSSI sequence on its own once it got the L command. If you keep calling the getRSSI method it may get confused because you restart the serial drivers etc. In that case it would be better to either stop said sequence (not sure if there is a command) before returning the result or let the bluesmirf loop run in its own cog and simply report the result to a global variable.
Ryoshima you don't have to start a new cog you could try something like this
pst : "Parallax Serial terminal"VARlong x
PUBmain
pst.StartRxTx(31,30,0,9600) 'this starts the serial terminal for debug display waitcnt(clkfreq*3 + cnt) 'delay 3 seconds so you can open the parallax serial terminal repeat
x := getRSSI 'assign x with value returned calling getRSSI
pst.char(1) 'home debug cursor
pst.hex(x, 2) 'print 2 digit hex value of x waitcnt(clkfreq+cnt) 'wait one second
io.rxflush
io.str(string("$$$")) 'this sends string repeat1000000'use waitcnt for delay
io.tx(13) 'transmit CHR/LF repeat1000000'use waitcnt for delay
io.str(string("$$$")) 'send string repeat1000000'use waitcnt for delay
io.tx(13) 'transmit CHR/LF repeatuntil io.rx == "R"'wait here until "R" received repeat i from0to2'receive 3 more characters "SSI"
io.rx ' if io.rx == "="'if the fifth character is "="
A := io.rx
B := io.rx ' then assign A to sixth character return C := convert(A)*16 + convert(B)
Edit: you should replace the repeat 1000000 with a waitcnt and I added a rxflush for the io
Ok, once we get the returned value out of getRSSI, I would like to get 3 different readings with variables x,y,z. I would then like to compare x,y,z and find which variable has the greatest value. How would those comparisons go? Since these are hex values would I have to do something special?
I was also going to say that if the device spits out a comma between the two hex digits then you should add an extra io.rx between A and B. As far as comparing hex, decimal or anything else you would do something like this
if x > y
'do something
Edit: nevermind about the comma I forgot you were wanting only one digit
repeat 'repeat continued repeat until io.rx == "R" 'wait here until "R" received repeat i from 0 to 2 'receive 3 more characters "SSI" io.rx ' if io.rx == "=" 'if the fifth character is "=" A := io.rx ' then assign 6th character to A B := io.rx ' then assign 7th character to B C := convert(A)*16 + convert(B)
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ io : "FullDuplexSerial.spin" pst : "Parallax Serial terminal" Pub getRSSI | i, A, B, C pst.StartRxTx(31,30,0,9600) 'this starts the serial terminal for debug display waitcnt(clkfreq*3 + cnt) 'delay 3 seconds so you can open the parallax serial terminal io.start(0, 1, 0, 9600) 'this starts the serial port for your bluesmirf io.str(string("$$$")) 'this sends string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("C") 'transmit "C" io.tx(13) 'transmit CHR/LF repeat 1000000 'use waitcnt for delay io.str(string("$$$")) 'send string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("L") 'transmit "L" io.tx(13) 'transmit CHR/LF repeat 'repeat continued repeat until io.rx == "R" 'wait here until "R" received repeat i from 0 to 2 'receive 3 more characters "SSI" io.rx ' if io.rx == "=" 'if the fifth character is "=" A := io.rx B := io.rx ' then assign A to sixth character waitcnt(clkfreq/10 + cnt) 'delay 1/10 of a second C := convert(A)*16 + convert(B) waitcnt(clkfreq/10 + cnt) pst.Str(C) waitcnt(clkfreq/10 + cnt) PRI convert(char) case char "0".."9": return char - "0" "a".."f", "A".."F": return (char | $20) - "a" + 10 other: abort
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ io[3]: "FullDuplexSerial" VAR long stack[32] PUB getRSSI | i, A, B, C cognew(blue, @stack{0}) io{0}.start(31, 30, 0, 115200) 'this starts the serial terminal for debug display waitcnt(clkfreq*3 + cnt) 'delay 3 seconds so you can open the parallax serial terminal io[1].start(16, 17, 0, 9600) 'this starts the serial port for your bluesmirf io[1].str(string("$$$")) 'this sends string repeat 1000000 'use waitcnt for delay io[1].tx(13) 'transmit CHR/LF io[1].tx("C") 'transmit "C" io[1].tx(13) 'transmit CHR/LF repeat 1000000 'use waitcnt for delay io[1].str(string("$$$")) 'send string repeat 1000000 'use waitcnt for delay io[1].tx(13) 'transmit CHR/LF io[1].tx("L") 'transmit "L" io[1].tx(13) 'transmit CHR/LF repeat 'repeat continued repeat until io[1].rx == "R" 'wait here until "R" received repeat i from 0 to 2 'receive 3 more characters "SSI" io[1].rx ' if io[1].rx == "=" 'if the fifth character is "=" A := io[1].rx B := io[1].rx ' then assign A to sixth character C := convert(A)*16 + convert(B) waitcnt(clkfreq/10 + cnt) io{0}.hex(C, 2) waitcnt(clkfreq/10 + cnt) PRI convert(char) case char "0".."9": return char - "0" "a".."f", "A".."F": return (char | $20) - "a" + 10 other: return PRI blue io[2].start(17, 16, %0000, 9600) repeat while io[2].rx <> "L" repeat io[2].str(string("RSSI=")) io[2].hex(frqa++, 2) io[2].tx(",") io[2].hex(0, 2) io[2].str(string(13, 10)) waitcnt(clkfreq/2 + cnt) DAT
EDIT:
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ io : "FullDuplexSerial.spin" pst : "Parallax Serial terminal" Pub getRSSI | i, A, B, C pst.StartRxTx(31,30,0,9600) 'this starts the serial terminal for debug display waitcnt(clkfreq*3 + cnt) 'delay 3 seconds so you can open the parallax serial terminal io.start(0, 1, 0, 9600) 'this starts the serial port for your bluesmirf io.str(string("$$$")) 'this sends string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("C") 'transmit "C" io.tx(13) 'transmit CHR/LF repeat 1000000 'use waitcnt for delay io.str(string("$$$")) 'send string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("L") 'transmit "L" io.tx(13) 'transmit CHR/LF repeat 'repeat continued repeat until io.rx == "R" 'wait here until "R" received repeat i from 0 to 2 'receive 3 more characters "SSI" io.rx ' if io.rx == "=" 'if the fifth character is "=" A := io.rx B := io.rx ' then assign A to sixth character return C := convert(A)*16 + convert(B) PRI convert(char) case char "0".."9": return char - "0" "a".."f", "A".."F": return (char | $20) - "a" + 10 other: return
VAR BYTE X OBJ RSSI: "getRSSI" PUB main | X X := RSSI
Edit: I am assuming that you saved the top program in your post above as getRSSI.spin
Edit2: Sometime's that can be a little confusing having an object named after one of it's methods.
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ io : "FullDuplexSerial.spin" pst : "Parallax Serial terminal" VAR BYTE X PUB main X := getRSSI pst.str(X) Pub getRSSI | i, A, B, C pst.StartRxTx(31,30,0,9600) 'this starts the serial terminal for debug display waitcnt(clkfreq*3 + cnt) 'delay 3 seconds so you can open the parallax serial terminal io.start(0, 1, 0, 9600) 'this starts the serial port for your bluesmirf io.str(string("$$$")) 'this sends string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("C") 'transmit "C" io.tx(13) 'transmit CHR/LF repeat 1000000 'use waitcnt for delay io.str(string("$$$")) 'send string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("L") 'transmit "L" io.tx(13) 'transmit CHR/LF repeat 'repeat continued repeat until io.rx == "R" 'wait here until "R" received repeat i from 0 to 2 'receive 3 more characters "SSI" io.rx ' if io.rx == "=" 'if the fifth character is "=" A := io.rx B := io.rx ' then assign A to sixth character return C := convert(A)*16 + convert(B) PRI convert(char) case char "0".."9": return char - "0" "a".."f", "A".."F": return (char | $20) - "a" + 10 other: return
COGNEW(getRSSI, 'not sure what goes here')
VAR long stack[32] PUB start cognew(getRSSI, @stack{0})
Inside that method you simply assign convert(A)*16 + convert(B) to a global variable instead of C. And you obviously don't return from it.CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ io : "FullDuplexSerial.spin" pst : "Parallax Serial terminal" VAR long x PUB main io.start(0, 1, 0, 9600) 'this starts the serial port for your bluesmirf pst.StartRxTx(31,30,0,9600) 'this starts the serial terminal for debug display waitcnt(clkfreq*3 + cnt) 'delay 3 seconds so you can open the parallax serial terminal repeat x := getRSSI 'assign x with value returned calling getRSSI pst.char(1) 'home debug cursor pst.hex(x, 2) 'print 2 digit hex value of x waitcnt(clkfreq+cnt) 'wait one second io.rxflush Pub getRSSI | i, A, B, C io.str(string("$$$")) 'this sends string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("C") 'transmit "C" io.tx(13) 'transmit CHR/LF repeat 1000000 'use waitcnt for delay io.str(string("$$$")) 'send string repeat 1000000 'use waitcnt for delay io.tx(13) 'transmit CHR/LF io.tx("L") 'transmit "L" io.tx(13) 'transmit CHR/LF repeat until io.rx == "R" 'wait here until "R" received repeat i from 0 to 2 'receive 3 more characters "SSI" io.rx ' if io.rx == "=" 'if the fifth character is "=" A := io.rx B := io.rx ' then assign A to sixth character return C := convert(A)*16 + convert(B) PRI convert(char) case char "0".."9": return char - "0" "a".."f", "A".."F": return (char | $20) - "a" + 10 other: return
if x > y 'do something
