SDRAM 64MB or more
MacTuxLin
Hi,
Can anyone please recommend me a SDRAM (part#) that would work well with Prop1? Preferably one that you have used or currently in-used and its interface is SPI.
Thank you.
Thank you.
If so, those are memory sticks that fit in PCs and as such are not SPI.
Or do you mean SD card ram? Or SRAM? Or SPI Ram?
Each of those has limits, some wear out (SD), some are limited to a few megabytes and are not SPI (SRAM) and some are only 32k (microchip SPI RAM).
I did a search a while back and I couldn't find anything over 32k. A little surprising really - maybe there is something out there? I toyed with the idea of using HC595 chips to create a serial to parallel converter and then use a SRAM. But then you need to convert back from parallel to serial and the chip count goes too high. Maybe FPGA? I've ended up going back to using 12 prop pins and octal latches and SRAM chips.
Some of the work the C programmers are doing with caching is intriguing. Caching means the actual ram solution need not be as fast nor use as many pins. Caching doesn't work for Spin though because you need Big Spin, which doesn't exist. Big C exists (Catalina, C++), and I believe Big PropBasic exists (LMM mode for PropBasic).
Jazzed's 32Mb circuit is I believe the biggest volatile ram solution.
Thanks Ale, hmm ... volatile storage is still the prime requirement.
Yeap, I have been looking at PropBASIC but not tried it yet, though.
I've used IS32S83200 32Mx8 SDRAM. There is a 64Mx8 SDRAM, but I haven't used it.
I would stay with an 8 bit interface, using 16 bits doesn't offer any great advantage.
The market for SDRAM seems to be thinning out too much. It may not last much longer.
There is a 64KB SPI SRAM chip available from IPSilog: http://www.ipsilog.com/content/index.php
Using 8 SPI SRAM in parallel is a reasonable idea as only 10 Propeller pins would be used.
I'm waiting for QuadSPI versions, but no one seems interested in producing such chips.
The SRAM from IPSilog looks interesting. OK, 10 Prop pins should be fine.
Have a look at 74HC164 and 74HC165, I think this is really what you want.
What is your application ?
I need a storage that is volatile & fast & ,hopefully, larger than 32MB on a single chip but have budget for using 2 of them. xRAM seems to be the only option, I think.
It would be fairly easy to modify the GCC SDRAM driver to use 64MB and a smaller pin footprint design that uses 2 latches like the schematic below. Nick may still have an 32MB SDRAM board if you want to do some tests.
