Railgun to be placed on navy ships? hmmm metal boats and magnets....
Just read this article http://www.dailytech.com/Navy+Railgun+Fired+for+1000th+Time/article23163.htm
Wouldn't it be an extremely bad idea to put a gigantic electro magnet on a metal boat? I could just see how a nearby boat or sub would all of a sudden get attracted to the ship with this onboard. Neat technology but bad placement idea. Wouldn't it be better to drop a large electro magnet in front of enemy troops and turn it on to disarm them?
See this Wikipedia article for a description
BTW, thanks for post this and I knew they were working on this a while ago.
It does sound effective when we go toe to toe with the other guy's battleships and dreadnoughts in fleet engagements.
If you want to see a video of a small one checkout "Mass Launcher" and click the link for the demo videos.
I guess not. But that is just a guess.
As Mike points out the electromagnetism is not spread out. It goes from coil to coil, VERY rapidly. I wouldn't wear a mechanical watch around the thing, but otherwise there's no immense burst of magnetism felt throughout the ship when this thing fires.
In WWII British and US ships were at first outfitted with giant electromagnets connected to coils around the hull to counter the then-new German magnetic mine. In the end, they discovered each ship didn't need its own electromagnet. The same effect was obtained by "wiping" the outside of the hull by coils of a huge electromagnet at the dock. The decreased magnetism worked for 3-6 months.
Should the railgun affect the existing degaussing of a ship it would be basic enough to undo it again.
-- Gordon
*So long as they correctly connect the positive and negative wires and don't switch them so it fires backwards!
Then so far as things related to this requiring licensing in the future, many things, in order to function as a military weapon, can only do so with their secret technology! And that technology has been developed with zillions of dollars of research and years of testing. So I wouldn't worry about that...
They may then outlaw your speaker system and certain types of mechanical actuators namely the ones known as linear motor as that is the exact same principle on which the rail gun is built. This stuff has been in development a very long time. Look at some of the stuff from the 80s by wynn schwartau "information and electronic warefare articles and books in particular.
I think the advantage of the rail gun is the velocity of the projectile. It would be tough to out maneuver a projectile smoking along at 5,000mph.
--Bill
