Getting mutiple results from multiple objects
Good morning,
I've been trying to figure out something for a few days now when using mutiple objects. Say in one object :
test.spin:
test2.spin
If I use 'return resultvar[0]' in test.spin I get the result, but how do I get it to return each result 0,1,2 ?
test.spin:
PUB thisone resultvar[0] := 100 'Y result resultvar[1] := 200 'U result resultvar[2] := 235 'V result returnand in another object I want to get those results for each resultvar and use them
test2.spin
PUB Start PST.DEC(test.thisone) return
You really should post all your code we can't see resultvar's declared type or if it is a VAR or DAT.
TEST.SPIN
TEST2.SPIN
test.spin
Test2.spin
I spent the better part of the day yesterday going through the prop manual working with longs/words/bytes and honestly at times it got more confusing as I went along, there was a section that said something to the effect that global vars were only able to be used in the object it was written in and I took that the wrong way.... I also went through the forums and found some posts that were along the lines of what I was trying to do, but they were mostly about launching methods into other cogs(which I though about, but I don't want to add to my confusion!) Thank you again!
