Digi-Key's Web UI is really intimidating.
During my first incarnation with electronics Radio Shack carried things like quad nand gates and D flip flops. When I got back into it a few years ago I found those days were long past. So I've been buying my harder to find components from eBay, Parallax, Modern Device, NKC, and Wulfden. They're used to consumers coming in a buying parts, so they're user friendly, and this has worked well.
But for a new project I want to buy a few IC's that are less common. I'm lucky because I have the Digi-key part number, so I should be OK with those. But I figured I might want to buy a few more parts I might need (pin headers, machine pins, capacitors) that Radio Shack won't have to save future shipping.
But man is their search function unfriendly. I want to buy 3 radial electrolytic capacitors at 47 μF 25V to go with some voltage regulators I already have. But how to find them?
From the main page, click on the "Product Index" link. There you will find an acceptable-level categorized list of items. Under "Capacitors", select "Aluminum". This will lead you to a page with sorting filters at the top that can be used to narrow down your search by value, package type, and working voltage. After you select your filters, click on the "Apply Filters" button. Here's a tip, right above the "Apply Filters" button is an "In Stock" checkbox. I always check that box unless I am just searching for details. I hate finding the perfect part only to find out it is a non-stocked, MOQ item.
Using 47uf, 25v, and radial as filters under the aluminum caps category, I came up with 27 results.
Being as how DigiKey no longer prints paper catalogs, their website is the only window into their product line. So it pays to spend some time with the Search function to learn its ins and outs. Also, it's a great way to get quick access to datasheets, rather than using Google, which tends to return links to the virtually useless datasheets.com and other sites of that ilk.
Finally, if you're looking for stock on a part or want to compare prices, http://www.findchips.com is your friend.
Thanks for that tip. I wish they had a feature to exclude items with a minimum purchase of 8000.
~phil: The funny thing about Digikey's price sorting feature is that it was not available until someone created a script for Greasemonkey so that you could do price sorting on their site. Once that script became popular, Digikey caught on to it's use and realized they were getting an increase in sales after the script was ran on their site. Hence, they added the sort feature to the price column.
Lawson
