My Robot Challenge
See my obscure challenge buried in this thread: http://forums.parallax.com/showthread.php?136008-Black-Friday-Deals&p=1054736&viewfull=1#post1054736
Just feeling frisky at the time. Did I rush into this? Was I in error? Should I retract? Logoff forever?
Nah, I'll stick. My spider sense in tingling.
-Tommy
More of a mechanical solution than electronic, and the BS1 has plenty of power. I'm a minimalist!
I will be building over Christmas break. Not holiday break.
CHRIST-mas break!
Ah so this is the long rumored improvement to the dual differential drive. I can't wait to see it.
One of my first programable robots was the Arobot that ran a BS2 and after some goading from some guys in the robotics club I reprogrammed the thing to go in a square and do figure eights going backwards. I will place odds on your simple robot being rather accurate if you take the time to think it out.
... of course having done it myself helps my faith in your position
I suppose you could take things a step farther and eliminate a microcontroller entirely by using something like a counter IC to trigger the jack. The jack would use 555 timers to create the servo wave forms to lever the robot up and rotate it.
But I'm a software guy and prefer the malleability of software with a two encoder differential steering robot.
Neither fast nor accurate, just complicated. PITA! KISS!
Acronyms rock. DYT?
My project placed the coder between the second and third gears giving an accuracy greater then 1/1000 of an inch because of the rpm the motor kicked out. Given the math, accuracy to 1/65,000 of an inch was theoritcally possible. Orginally the coder was going to be placed straight on the motor shaft, but that rpm made the coder wheel turn to fast.
