Need Help with serial interface - Page 2 — Parallax Forums
2»
    edited 2011-11-25 22:39
    David Betz wrote: »
    It seems to me that I have had trouble with extra blank lines whenever I try to go from PST to a normal terminal emulator. I don't think its default settings match common practice. Maybe we can get Parallax to fix that.
    Guys,
    If I am missing the boat on this one let me know. I think that the best way to set up terminal function would be to code things to react as closely to say VT100 as possible. I know that nearly everything can be configured to be compatible with this or VT220. VT320 may be a reach. Or ansi or whatever, as long as it conforms to a known followed standard that is supported across all possible development systems as well as any systems that the end device may be deployed with as an endpoint.
    Frank
    edited 2011-11-26 04:18
    Guys,
    Frank
    The terminal mode in the new propgcc release works the same on under Windows, Linux, and Mac and I believe it behaves the way traditional terminals did with respect to the CR and LF characters. It sends the Propeller a CR when the user presses the RETURN key and it requires a CR and LF at the end of each line of text received from the Propeller. The libraries have been adjusted to work in this mode although I think they may be able to support other modes as well.
  • ReinhardReinhard Posts: 489
    edited 2011-11-26 08:39
    Hi,
    now all Terminal Programs work well.
    I have ported my Radiometer Project ( posted in another Thread) to propgcc.
    Therefore I written my own Terminal Server on PC side and it's work also well.
    http://home.mnet-online.de/reimay/Projects/Radiometer/PC_Software/GUI/Clipboard01.jpg
    Thanks again for the good job.
    best regards
    Reinhard
  • ersmithersmith Posts: 6,269
    edited 2011-11-26 09:22
    Reinhard wrote: »
    Hi,
    That's great news! Thank you for all the testing and for your bug reports -- they've been very helpful.
    Eric
    edited 2011-11-26 20:24
    ersmith wrote: »
    Eric
    Well, I think I have found the reason that my c3 was not behaving correctly with fibo. I noticed that it appeared to be seeing the USB serial port, but was doing nothing. I toggled the DTR pin (a function of GTKterm), and fibo started outputing its values to the terminal program as expected. So I don't believe that the terminal problems I had originally ascribed to the loader / gcc were in fact a gcc problem, rather a serial and USB problem......
    Frank
    edited 2011-11-27 04:54
    Hmmm, interesting. I'm glad you figured that out -- thanks for the update!
    Eric
