Interfacing with a Camera - Page 2 — Parallax Forums
2»
  • TagametTagamet Posts: 22
    edited 2011-11-23 12:00
    Ray,
    I changed the baudrate, no luck. I left it at 14400 & took out the RX pin on the prop while the program was running & a preview appeared! It's grayscale w/ low resolution. So I'll experiment with the settings & go from there! So, basically I changed nothing from my original setup & it works now. I appreciate all the help & troubleshooting. Now to get the SD card working...
    Thanks again,
    Tagamet
  • RaymanRayman Posts: 16,024
    edited 2011-11-23 18:12
    Glad you got it!
    Looks like the C328RS is still available, I didn't know that... That's good news. Thought my code was obsolete...
    I thought it was cheaper before though... I still have motivation to come up with my own solution...
    edited 2011-11-30 08:23
    Thanks Ray! IThey're still available sparingly & I guess that justifies the $65... I changed appropriate values in the data section but still couldn't get any other resolution.
    Thanks for your time,
    Tagamet
