How Sensitive?
I'm curious how sensitive is this sensor?
http://www.parallax.com/Store/Sensors/GasSensors/tabid/843/CategoryID/91/List/0/SortField/0/Level/a/ProductID/592/Default.aspx
Thanks!
OBC
Thanks!
OBC
It looks like the methane sensor is good for detecting concentrations from 5000ppm to 20000ppm.
It's really cool that you can set it to go off when a preset level has been EXCEEDED.
OBC
I almost asked about what you wanted to measure. I'm a chemist but this not my area of expertise.
The problem is, I'm pretty sure the smell is not related to the amount of methane. There are also other gasses involved. If someone drinks a lot of carbonated beverages they might be the culprit without setting off any methane detectors.
I'm sure you're right about that. But I know my own gas detector goes off when I use floor cleaner too close to it, floor cleaner that has some kind of aromatic compound in it. So I'm just guessing a lot of these sensors are probably sensitive to all sorts of hydrocarbons and not just what they are specified for.
