*global* Find ? — Parallax Forums
*global* Find ?
Don PomplunDon Pomplun Posts: 116
edited 2011-11-17 22:02 in Propeller 1
Is there a way (wouldn't it be nice if there were a way) to search all open objects in a project? (!)
    edited 2011-11-17 20:33
    No, there's not a way in any of the Propeller IDEs. I have seen editors that will search all files in the directory containing the current source program, but none of them support the Propeller.
    Mike Green wrote: »
    *nix (or mac Leopard) once GCC is set up in Eclipse, you could use the eclipse shell function to run a grep "expression" * to find it in the files..........
    Can't speak to emacs, never really spent the time with it, and have not used it w/ prop work. I run linux, so keep a terminal open if I need it; but that is not IDE.
    Frank
