Download latest version of PropBasic for Viewport here...
Bean
I have started a new thread to keep the latest version of PropBasic for viewport.
Nov 7, 2011 Version 1.26
Fixed: WDATA and LDATA not generating any values in spin file.
Nov 17, 2011 Version 1.27
Support for ViewPort Terminal (need viewport 4.6.7 or later) using "VPterminal_lib.pbas"
Bean
Bean
Do you have any documentation on how to interface PropBasic with ViewPort. I have ViewPort, but have never used it with PropBasic and have no idea how to integrate the two.
Next -- Simply copy PropBasic in ViewPort Installation directory.
I've pm'ed you the latest beta of ViewPort which includes Propeller Tool style background coloring for sections of PropBasic code as well as the handy indentation guide. You need to:
- install ViewPort and PropBasic
- file/open a "PropBasic" file- they end with the ".pbas" extension. You could start with tutorial "29_PropBasic.pbas" from ViewPort's tutorials.
- you can also start a new document with file/new and then select ".pbas".
- you can start with any "pbas" file and then start adding the viewport specific keywords
Hanno
I haven't used PropBasic in a few months and will love to reacquainted with it.
Oh; and I'm good at breaking things - I'm often used as a beta tester at work!
http://forums.parallax.com/showthread.php?134526-PropBasic-amp-Viewport/page4&highlight=Viewport
Post #65
http://hannoware.com/viewport/beta.php
Hanno
Reason is that with BST when I make a modification to the compiler, I need to send the source files to BradC and HE has to integrate it into BST.
He has been hard to reach lately, so no updates for quite awhile.
With Viewport, I can just post the new PropBasic.exe and updates should be quickly provided.
Bean
Ray
Ray,
I have already brought up the subject with Hanno. He will have to make a business decision about that. But I sure hope he does.
Even if it is a striped-down version. It will be a way to get more people using Viewport and hopefully upgrading it to a paid version.
Bean
Ray
It looks like some people really want a free version so I'll work on a striped down release that edits code, compiles C(catalina and gcc) spin and propbasic and loads binaries to the prop. It will be a separate installer, available on Win, OSX and Linux with an "ad" for the full ViewPort at closing- similar to what I currently do with EZLog:http://hannoware.com/ezlog/
Would be nice if Parallax supported this publicly...
Hanno
I'm now going to download the latest beta, test it with PropBASIC, then expect to purchase @ $29 anyway. Might even upgrade to one of the higher versions if I make enough use of it.
using the homespun compiler & PropBasic.
I think this should be possible with several available editors, i.e. codeblocks, pspad etc.
Cheers, Friedrich
@Hanno: Agreed - Parallax would do well do publicly support ViewPort, it adds so much to the Propeller toolkit.
Yes, I totally agree. Besides, $29 *is* free and as Hanno says, there is a 30 day free trial as well. I'd rather see Hanno continue to spend his time and experience making new features for people who actually pay for and respect his time and experience.
Just like a Lawyer, Hanno's time and experience is his stock in trade.
People *always* want things for free, but I think it would just waste more of Hanno's time supporting something that people are too cheap to pay for.
There is only one Hanno and we should treat his time with respect.
The same goes for Bean. I wish he could somehow get compensated for all the work he has put into PropBasic.
Anyway, that is just my opinion. I hope nobody was offended.
On this board I'm using a 40 MHz VCXO module instead of a 5 MHz crystal, and if I use
DEVICE P8X32A, XINPUT
FREQ 40_000_000
ViewPort can't communicate with the Prop after loading the code.
DEVICE P8X32A, XTAL1
FREQ 40_000_000
does work OK, however and ViewPort works fine. For whatever reason it appears _clkmode isn't getting set correctly for XINPUT modes. No big deal with a simple workaround, but maybe it could be looked at when it's convenient. The VCXO drives Xi and with Xo open it's safe to use XTAL1, right?
Edit: disregard.
With a different board using a 4.096 MHz VCXO, I changed propbasic.pbas example to include
DEVICE P8X32A, XINPUT, PLL16X
FREQ 4_096_000
and it worked correctly, allowing ViewPort to communicate. Not sure what the issues are with the other hardware (parallax pro devevopment board) since the code loaded and ran OK but ViewPort had issues, but this hand-wired board is working so my assumptions were bogus. Sorry. This is an improvement over BST, where even Kuroneko agreed the XINPUT|PLL16X wasn't being handled correctly. Crawling back under my rock now.
Now on the matter of Hanno making Viewport free in a strip down version available for free. I think Hanno could make a version of Viewport that supports Prop Basic only for free and if you want a version that supports other things you could buy the upgrade. Which I wouldn't mind seeing done.
As the other posters mention Bean and Hanno put alot of hard work into the software and we should thank them for this work.
I'm hoping that enough people will support my work by upgrading and paying for the debugging/graphing/etc features of ViewPort. I've been able to convert quite a few Arduino/PICAXE users by showing them the combination of ViewPort and the Propeller.
Hanno
PropBasic is designed to create really fast code, but you give up a alot.
In the future I would like to re-design PropBasic to...
Generate ONLY LMM code (slower I know, but code will be larger than the current version of PropBasic)
Full expression evaluation
String support
Automatic use of subroutines for commands that generate a lot of code (SEROUT for example).
Floating point support
Programs written in the next generation of PropBasic will run much slower, but the language will be much closer to generic BASIC. And they should still be much faster than spin (5x or so ???).
Bean
Yes, thank you Bean, (hope your feeling better), and Hanno!
@Bean
Late congrats on 7000+ posts!
@Hanno
Late congrats on 1000+ post!
Jim
I don't know if it is a good thing to support LMM code only, I would really like to be able to write code
for a single cog running on its own, as fast as it will go. If I could only use a subset of the whole language,
so be it. It is better I think than to write this sort of code in assembly.
Just my 2c Friedrich
I'm afraid it will be a nightmare to support two different compilers. And really confusing for the users.
Bean
Two compilers NO! - But two modes in same Compiler preferred!
I love the idea of easily writing a single task in inline lmm. 5x faster than spin isn't too shabby either. It's difficult to compromise on decisions like these but I think you're making the right one. The nice thing about lmm is that it'll be much easier to support full featured debugging (breakpoints, stepping) at full speed. Just like BlackCat for Catalina. Thanks for working on terminal support
Hanno
It's up to Bean what PropBasic becomes, it's his excellent work and his call, but if he does change I'll be hoping to hang onto the last version of the existing model. Incidentally, I'm not trying to transition from Stamps, although I did use a couple of BS1s in projects some years ago. For the last ten years or so I've used PICs and C. For me, this isn't a Basic vs Spin vs C question. It's anything high-level vs assembler yet still be able to get all the speed the hardware can provide.
-Bob
- PANIC - I totally agree with Bob.
The possibility to write really fast and compact cog code is one of PropBasics biggest strengths! Please keep that alive!
All of the three major projects, where I use PropBasic have used this specific strength: Soundprocessor, CNC- Controller, Mandelbrot-Project.
The soundprocessor would not work at all with LMM code.
CNC-Controller and Mandelbrot would be no fun at all.
It is great, that you can write hardware drivers in PropBasic instead of PASM! And I have learned a lot how to code PASM. I think, it is very attractive, to have a fast simpler language, which produces compact code. (At this moment I am not yet convinced, that GCC will be usable at all because of code size.)
It is great, that there is PropBasic which gives you all of the power of the Prop.
I know, I have asked to support float directly, but this prize would be too high!
- Christof
