Lower I/O Pin Number=Faster Access Time?
I just saw this statement at http://www.hobbyengineering.com/specs/devantech-srf04-tech.pdf
The new code is also useful when connecting the SRF04 to the slower Stamps such as the BS2. Although
the SRF04 works with the BS2, the echo line needs to be connected to the lower numbered input pins. This is
because the Stamps take progressively longer to look at the higher numbered pins and can miss the rising edge
of the echo signal. In this case you can connect the "do not connect" pin to ground and give it an extra 300uS to
get there.
Is it correct that lower number pins can operate faster? Never saw that mentioned anywhere else.
get there.
What a great thread for my birthday week, with two of my three all-time favorite forum gurus sharing their top-notch tech knowledge. Once PhiPi weighs in, I can die happy.
I'm sure he's prototyping as we speak.
