propeller-load.cfg entries for ASC
Martin Hodge
Did I get all the important options? Is TV_DEBUG a future feature?
[asc]
clkfreq: 80000000
clkmode: XTAL1+PLL16X
baudrate: 115200
rxpin: 31
txpin: 30
tvpin: 16 # only used if TV_DEBUG is defined
[ascp]
clkfreq: 80000000
baudrate: 115200
rxpin: 31
txpin: 30
cache-driver: eeprom_cache.dat
cache-size: 8K
cache-param1: 0
cache-param2: 0
Yes and No. The option names are correct. TV_DEBUG is not a future feature.
Form more information, please see: http://code.google.com/p/propgcc/wiki/PropGccLoader
TV_DEBUG is only for the loader. You can rebuild the loader if you like with -DTV_DEBUG. Then when the loader starts you will see what it's doing on the TV.
The file propeller-load.cfg only defines how to load/boot a given board. This approach makes the loader easier to maintain, and leaves device definition for the user program. Within the user program, you can insert any device you like. There are hooks for library devices.
The file propgcc/demos/TV/TvText_demo/TvDemo.c shows an example of using both a serial port and TV.
Really, you don't need to define ASP entries, but you can if you like. Without TV_DEBUG the entries you made are identical to HUB and EEPROM.
--Steve
