How to - send signals to sms?
i need help.
im now developing propane gas sensor. and i would like to find a way to send signals to alert people by using sms. i just wanna send a simple sms or email message to warn me about the gas leak.
thanks for any help
thanks for any help
Spinneret forum
http://forums.parallax.com/showthread.php?135321-How-to-use-email-to-control-Spinneret-OUT-port
Tutorial
http://spinneret.servebeer.com:5000/client/email.htm
Or connect your board to a mobile, there are examples in the propeller forum
Duane
does this telit GE865 compatible with parallex board as picture below? and can i program the telit GE865 by using basic stamp? from what i read, telit is using phyton to program it.
can we program the device by using basic stamp 2?
thanks for your reply
There are two modes for the Telit modules, determined by (i think) the DTR line status at power up. Python is one mode, and "AT commands", just like old dial up modems, is the other mode. Telit has a series of commands called "easy gprs" which make it very easy to send an sms, and not that much harder to send an email. All the low level grunt work is done for you, all you need to do is give it 3 or 4 AT commands to specify the phone number and content of the sms.
Here's an example of a few AT commands to initiate and FTP connection to an external server. Note there are only 3 or 4 commands needed to make things happen.
http://forums.parallax.com/attachment.php?attachmentid=67300&d=1264919600
