Catalina 3.4 - Page 7 — Parallax Forums
Catalina 3.4
15791011
  • RossHRossH Posts: 5,694
    edited 2011-11-09 20:31
    Rayman wrote: »
    Ross,
    Just thinking about possible future stuff...
    Does Code:Blocks support breakpoints? I don't see any way to set breakpoints in the editor...
    I remember you said small and large debugging isn't ready yet. Could you just turn off caching to allow debugging and just let it run super slow?
    Code::Blocks does not support Catalina breakpoints - you need to use the BlackBox or BlackCat debuggers, which are stand-alone programs.
    My solution for debugging programs stored in Flash is to actually use the cache to store the breakpoints - i.e. to simulate the debugger writing to what would normally be read-only Flash memory, by instead caching the writes but not writing the dirty pages back to XMM RAM.
    The main thing I am not happy about is that I can only store a small number breakpoints that way - I need to make the cache more efficient in the way it stores each breakpoint - it can't simply leave all the pages with breakpoints hanging around in Hub RAM (as it does now) - this simply runs out of space too quickly!
    Ross.
    edited 2011-11-10 03:51
    RossH wrote: »
    I didn't think a comparison of code size to a PIC24 was meaningful comparison for LMM Propeller code sizes, so I used the only available alternative to try and get a more reasonable one - just to try and emphasize the point that Catalina's code sizes were not excessive (if anything, they are just the opposite!)
    Ross.
    As I think I've said, I wasn't criticising the quality of Catalina code generation. I was trying to understand loader speeds.
  • RaymanRayman Posts: 15,903
    edited 2011-11-10 12:23
    Ross, another basic question for you...
    I'm looking at some C code for the Vinculum II right now... I'm a little surprised to see that they never use a semicolon after braces {};
    Is this not required in regular C?
    I think it is required in all C++, right?
    Just curious...
    edited 2011-11-10 12:28
    Rayman wrote: »
    Just curious...
    It is never required in C or C++ as far as I know. The semicolon after a closing brace will be parsed as an empty statement and could cause syntax errors in the case of something like this:
    if (a == b)
        { printf("a equals b\n"); };
    else
        { printf("a does not equal b"\n"); };
    edited 2011-11-10 12:30
    Well, a semicolon after a closing brace is *sometimes* necessary in variable declarations with initializers:
    int my_array[] = { 1, 2, 3 };
    It is also used in other declarations but not in executable statements.
    edited 2011-11-10 13:43
    Interesting... Goes to show you how much I know... I did just try leaving off some semicolons in Visual Studio C++ and it doesn't complain...
    Still, it just looks wrong to me to leave them off...
    edited 2011-11-10 13:45
    Rayman wrote: »
    Try compiling the example from my previous message with Visual Studio C++. I bet you'll get an error.
    edited 2011-11-10 15:04
    Rayman, David ...
    In C braces are used to delimit both block structures and type structures (including type initializers). The semicolon in C is a statement terminator, so it is required after each statement, even if that statement ends in a type structure or a type initializer - such as a declaration. It is not required after a block structure - there it would represent an empty statement, so it looks like it is "optional" whereas in fact it should not be there at all.
    However, I think C# (and possibly some C/C++ implementations) make the semicolon optional in places where it would be mandatory in "pure" C.
    Ross.
    edited 2011-11-11 02:52
    All,
    Catalina 3.5 is not ready for release yet, but attached is a preview of the new payload loader that will be included (Windows only executable at this stage).
    EDIT : attachment has been removed - you will find an updated version in the second post in this thread
    This new version of payload is significantly faster - it downloads Catalina LMM as well as normal Spin binaries in the same time as the Parallax Propeller Tool (to within a second on my machine). It is also faster downloading Catalina XMM programs.
    Just unzip the attached file into your Catalina\bin directory.
    One of the things that slows the download process is leaving it to payload to locate the correct port to use each time (it does this by trying them all in turn). For faster speeds, explicitly specify the ports to use (if you don't know the ports, just use payload - once - without specifying any ports, and it will tell you!).
    For example, for a Catalina LMM or Spin binary, specify the port to use for the download via -p:
    payload -p2 hello_world
    or, for an XMM program, specify both the primary and secondary ports to use (on most platforms they are the same) via -p and -s:
    payload -p2 -s2 XMM startrek
    If anyone has any problems with this version, please let me know!
    Ross.
    edited 2011-11-11 04:57
    RossH wrote: »
    All,
    Ross.
    Good work Ross! I guess there is no need for me to add Catalina support to propeller-load anymore!
    edited 2011-11-11 13:09
    David Betz wrote: »
    Hi David,
    I appreciate the work you've done. At this point I'm not sure whether to ask that you continue or not - but I guess it would make sense for you to at least put it on hold for a bit. This version mostly improves the propeller detection/connection time, and so should significantly improve the load time for Spin and LMM programs up to 32k. But a download of an XMM program of a meagabyte or more will still take minutes rather than seconds. That's where your loader may improve things.
    I hope people will report whether this version is faster, since I have only so far tested it on one machine - and the download times do seem to be at least partly machine-dependent.
    Ross.
    edited 2011-11-11 23:29
    All,
    Found a bug when compiling XMM programs that use the EEPROM loader. The fix is in the second post in this thread.
    Ross.
  • pinedustpinedust Posts: 19
    edited 2011-11-14 16:43
    I am relatively new with the propeller, but not C programming. After a few months of spin, I have decided I want to give Catalina 3.4 and Codeblocks a shot.
    This may be more of a codeblocks issue, but I will ask anyway. Everything works fine on my XP laptop, but I am almost exclusively a linux user. I have tried twice on two different boxes, Ubuntu 9.1 and 10.4, both with the same result. I can create a project but I cannot select the build target from the dropdown box, nor can I select it via the build menu... both are empty. What am I overlooking? I am sure it is something, I am pretty good at doing that.
    Although I haven't tried it, I have no problem with a CLI, so if that is what I have to do no biggie.
    Thanks, Dusty
    edited 2011-11-14 17:57
    pinedust wrote: »
    Thanks, Dusty
    Hi Dusty,
    The Code::Blocks installation on Linux is a bit more manual than on Windows, but it works ok. I have not tried it on Ubuntu recently, but I have done so in the past. I think I still have a virtual for Ubuntu (not sure which version), so I will try it when I get home.
    I'm not exactly sure from your description what you mean by "empty". In the "build target" dropdown, you should see "Release" and/Or "Debug" (depending on what configurations you selected in the project wizard. You should see the same thing on the "Build->Select Target" menu. Do you see nothing at all?
    Can you provide a screenshot?
    Also, on Linux you probably also have GCC installed - can you create a normal GCC project successfully in Code::Blocks?
    EDIT: Could you also let me know what version of Code::Blocks you are using?
    Ross.
    P.S. to use the Catalina from the command line, just open a bash shell and type:
    source /usr/local/lib/catalina/use_catalina
    edited 2011-11-14 19:36
    RossH wrote: »
    Hi Dusty,
    Ross.
    Yes, the install process is a little more hands on than with windows, but I've been through worse. I started off in the 90s compiling redhat 4.2 and enlightenment for a window manager, but that is a whole different topic.:nerd:
    Both the dropdown and menu options are there, but the controls are empty, hopefully the screenshots help explain what I meant.
    I verified both release and debug targets were selected when creating the project.
    Yes, I was able to create a gcc project, but am unable to compile it due to the same problem, unable to select a target.
    I may try to build codeblocks from sources, I just need to install the development files, I was hoping not to do that, though. It makes for an easier sell to PHBs. :smile:
    Thanks for your time, Ross.
    806 x 626 - 87K
    806 x 626 - 90K
    edited 2011-11-14 20:04
    pinedust wrote: »
    Now, that's very odd - does this happen with a "clean" install of Code::Blocks 10.05? - i.e. before you install the Catalina replacement compiler plugin?
    Ross.
    edited 2011-11-15 01:47
    pinedust wrote: »
    ... I have tried twice on two different boxes, Ubuntu 9.1 and 10.4, both with the same result. I can create a project but I cannot select the build target from the dropdown box, nor can I select it via the build menu... both are empty. What am I overlooking?
    Hi Dusty,
    I didn't have either of these versions of Ubuntu, so I am downloading a clean install of Ubuntu 10.4.
    While I was waiting I just did a full install of Code::Blocks 10.05 and Catalina 3.5 under Fedora FC12 (32 bit), and everything worked as expected.
    Some questions you may be able to answer:
    Are you using 32 bit or 64 bit Ubuntu?
    Can you tell me what version of wx you have installed? You can find out by executing wx-config --version
    On the images you posted, the "Build target" dropdown list has a funny horizontal bar across half of it - is that what you actually see?
    Ross.
    edited 2011-11-15 06:31
    I am using Codeblocks 10.05, Catalina 3.4, 64 bit Ubuntu, and wx-config --version returns 2.8.12.
    Yes, that funny little horizontal bar is all I see.
    Rather than fight it, I just went ahead and rebuilt Codeblocks from sources and now everything looked as if it is working.
    Well, that was until I uninstalled the default compiler plugin and installed the 64bit libcompiler-0.99.cbplugin plugin, now it is back to the original problem.
    Dusty
    edited 2011-11-15 11:53
    pinedust wrote: »
    Dusty
    Hi Dusty,
    I didn't manage to get Ubuntu installed yet, but I think it is the version of wx that is the problem. My compiler plugin was built with 2.8.11.
    I will post the source of the compiler plugin tonight and you can rebuild that as well. That should fix it.
    Ross.
    edited 2011-11-15 19:09
    Hi Ross,
    I'm experimenting with various displays at the moment and am hoping to get this one working http://www.ebay.com.au/itm/170709358010?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 which uses an ILI9325. Scroll down that product description for the pinout which is a standard 40 pin header.
    Rayman has done some drivers in Spin and I believe there are other drivers out there as well.
    I'm hoping this can be done in C, and I'm encouraged to find that a search for some C code turns up some code that ought to be portable to Catalina. I'm not sure yet of the optimum pin arrangement eg 8 bit using 8 (or more) prop pins vs 16 bit via latches and share with the external ram driver. The latter is a bit more messy, but it does free up more propeller pins to be used for other things, eg reading the touch screen.
    There is some C source code here http://code.google.com/p/lpc1343codebase/source/browse/trunk/drivers/lcd/tft/hw/ILI9325.c?r=137
    Do you think this is something we can integrate into Catalina?
        @file     ILI9325.c
        @author   K. Townsend (microBuilder.eu)
        @section  DESCRIPTION
        Driver for ILI9325 240x320 pixel TFT LCD displays.
        This driver uses an 8-bit interface and a 16-bit RGB565 colour palette.
        Should also work with SPFD5408B, ST7783 or OTM3225A-based LCDs, though
        there are sometimes minor differences (for example vertical scrolling
        via register 0x6A isn't supported with the ST7783 controller).
        @section  UPDATES
        26-11-2010: ili9325ReadData contributed by Adafruit Industries
        @section  LICENSE
        Software License Agreement (BSD License)
        Copyright (c) 2010, microBuilder SARL
        All rights reserved.
        Redistribution and use in source and binary forms, with or without
        modification, are permitted provided that the following conditions are met:
        1. Redistributions of source code must retain the above copyright
        notice, this list of conditions and the following disclaimer.
        2. Redistributions in binary form must reproduce the above copyright
        notice, this list of conditions and the following disclaimer in the
        documentation and/or other materials provided with the distribution.
        3. Neither the name of the copyright holders nor the
        names of its contributors may be used to endorse or promote products
        derived from this software without specific prior written permission.
        THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ''AS IS'' AND ANY
        EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
        WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
        DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER BE LIABLE FOR ANY
        DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
        (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
        LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
        ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
        (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
        SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include "ILI9325.h"
    #include "core/systick/systick.h"
    #include "drivers/lcd/tft/touchscreen.h"
    /* Private Methods                               */
    void ili9325Delay(unsigned int t)
      unsigned char t1;
      while(t--)
      for ( t1=10; t1 > 0; t1-- )
        __asm("nop");
    void ili9325WriteCmd(uint16_t command)
      // Compiled with -Os on GCC 4.4 this works out to 25 cycles
      // (versus 36 compiled with no optimisations).  I'm not sure it
      // can be improved further, so that means 25 cycles/350nS for
      // continuous writes (cmd, data, data, data, ...) or ~150 cycles/
      // ~2.1uS for a random pixel (Set X [cmd+data], Set Y [cmd+data],
      // Set color [cmd+data]) (times assumes 72MHz clock).
      CLR_CS_CD_SET_RD_WR;  // Saves 18 commands compared to "CLR_CS; CLR_CD; SET_RD; SET_WR;"
      ILI9325_GPIO2DATA_DATA = (command >> (8 - ILI9325_DATA_OFFSET));
      CLR_WR;
      SET_WR;
      ILI9325_GPIO2DATA_DATA = command << ILI9325_DATA_OFFSET;
      CLR_WR;
      SET_WR_CS;            // Saves 7 commands compared to "SET_WR; SET_CS;"
    void ili9325WriteData(uint16_t data)
      CLR_CS_SET_CD_RD_WR;  // Saves 18 commands compared to SET_CD; SET_RD; SET_WR; CLR_CS"
      ILI9325_GPIO2DATA_DATA = (data >> (8 - ILI9325_DATA_OFFSET));
      CLR_WR;
      SET_WR;
      ILI9325_GPIO2DATA_DATA = data << ILI9325_DATA_OFFSET;
      CLR_WR;
      SET_WR_CS;            // Saves 7 commands compared to "SET_WR, SET_CS;"
    uint16_t ili9325ReadData(void)
      // ToDo: Optimise this method!
      uint16_t high, low;
      high = low = 0;
      uint16_t d;
      SET_CD_RD_WR;   // Saves 14 commands compared to "SET_CD; SET_RD; SET_WR"
      CLR_CS;
      // set inputs
      ILI9325_GPIO2DATA_SETINPUT;
      CLR_RD;
      ili9325Delay(100);
      high = ILI9325_GPIO2DATA_DATA;
      high >>= ILI9325_DATA_OFFSET;
      high &= 0xFF;
      SET_RD;
      CLR_RD;
      ili9325Delay(100);
      low = ILI9325_GPIO2DATA_DATA;
      low >>= ILI9325_DATA_OFFSET;
      low &=0xFF;
      SET_RD;
      SET_CS;
      ILI9325_GPIO2DATA_SETOUTPUT;
      d = high;
      d <<= 8;
      d |= low;
      return d;
    uint16_t ili9325Read(uint16_t addr)
      ili9325WriteCmd(addr);
      return ili9325ReadData();
    void ili9325Command(uint16_t command, uint16_t data)
      // Provided for convenience sake ... shouldn't be used
      // in critical sections since it adds an extra
      // branch, etc.
      ili9325WriteCmd(command);
      ili9325WriteData(data);
    uint16_t ili9325BGR2RGB(uint16_t color)
      uint16_t r, g, b;
      b = (color>>0)  & 0x1f;
      g = (color>>5)  & 0x3f;
      r = (color>>11) & 0x1f;
      return( (b<<11) + (g<<5) + (r<<0) );
    /* Returns the 4-hexdigit controller code         */
    uint16_t ili9325Type(void)
      ili9325WriteCmd(0x0);
    void ili9325SetCursor(uint16_t x, uint16_t y)
      ili9325Command(0x0020, x);       // GRAM Address Set (Horizontal Address) (R20h)
      ili9325Command(0x0021, y);       // GRAM Address Set (Vertical Address) (R21h)
    void ili9325InitDisplay(void)
      // Clear data line
      GPIO_GPIO2DATA &= ~ILI9325_DATA_MASK;
      SET_RD;
      SET_WR;
      SET_CS;
      SET_CD;
      // Reset display
      CLR_RESET;
      ili9325Delay(10000);
      SET_RESET;
      ili9325Delay(500);
      ili9325Command(0x00FF, 0x0001);
      ili9325Command(0x00F3, 0x0008);
      ili9325WriteCmd(0x00F3);
      ili9325Command(0x0001, 0x0100);     // Driver Output Control Register (R01h)
      ili9325Command(0x0002, 0x0700);     // LCD Driving Waveform Control (R02h)
      ili9325Command(0x0003, 0x1030);     // Entry Mode (R03h)
      ili9325Command(0x0008, 0x0302);
      ili9325Command(0x0009, 0x0000);
      ili9325Command(0x0010, 0x0000);     // Power Control 1 (R10h)
      ili9325Command(0x0011, 0x0007);     // Power Control 2 (R11h)
      ili9325Command(0x0012, 0x0000);     // Power Control 3 (R12h)
      ili9325Command(0x0013, 0x0000);     // Power Control 4 (R13h)
      ili9325Delay(1000);
      ili9325Command(0x0010, 0x14B0);     // Power Control 1 (R10h)
      ili9325Delay(500);
      ili9325Delay(500);
      ili9325Command(0x0012, 0x008E);     // Power Control 3 (R12h)
      ili9325Command(0x0013, 0x0C00);     // Power Control 4 (R13h)
      ili9325Command(0x0029, 0x0015);     // NVM read data 2 (R29h)
      ili9325Delay(500);
      ili9325Command(0x0030, 0x0000);     // Gamma Control 1
      ili9325Command(0x0031, 0x0107);     // Gamma Control 2
      ili9325Command(0x0032, 0x0000);     // Gamma Control 3
      ili9325Command(0x0035, 0x0203);     // Gamma Control 6
      ili9325Command(0x0036, 0x0402);     // Gamma Control 7
      ili9325Command(0x0037, 0x0000);     // Gamma Control 8
      ili9325Command(0x0038, 0x0207);     // Gamma Control 9
      ili9325Command(0x0039, 0x0000);     // Gamma Control 10
      ili9325Command(0x003C, 0x0203);     // Gamma Control 13
      ili9325Command(0x003D, 0x0403);     // Gamma Control 14
      ili9325Command(0x0050, 0x0000);     // Window Horizontal RAM Address Start (R50h)
      ili9325Command(0x0051, 0x00EF);     // Window Horizontal RAM Address End (R51h)
      ili9325Command(0x0052, 0X0000);     // Window Vertical RAM Address Start (R52h)
      ili9325Command(0x0053, 0x013F);     // Window Vertical RAM Address End (R53h)
      ili9325Command(0x0060, 0xa700);     // Driver Output Control (R60h)
      ili9325Command(0x0061, 0x0001);     // Driver Output Control (R61h)
      ili9325Command(0x0090, 0X0029);     // Panel Interface Control 1 (R90h)
      // Display On
      ili9325Command(0x0007, 0x0133);     // Display Control (R07h)
      ili9325Delay(500);
      ili9325WriteCmd(0x0022);
    void ili9325Home(void)
      ili9325Command(0x0020, 0X0000);     // GRAM Address Set (Horizontal Address) (R20h)
      ili9325Command(0x0021, 0X0000);     // GRAM Address Set (Vertical Address) (R21h)
      ili9325WriteCmd(0x0022);            // Write Data to GRAM (R22h)
    void ili9325SetWindow(uint16_t x, uint16_t y, uint16_t x1, uint16_t y1)
      ili9325Command(0x0050, x);       // Window Horizontal RAM Address Start (R50h)
      ili9325Command(0x0051, x1);      // Window Horizontal RAM Address End (R51h)
      ili9325Command(0x0052, y);       // Window Vertical RAM Address Start (R52h) )
      ili9325Command(0x0053, y1);      // Window Vertical RAM Address End (R53h)
    /* Public Methods                                */
    void lcdInit(void)
      // Set control line pins to output
      gpioSetDir(ILI9325_CS_PORT, ILI9325_CS_PIN, 1);
      gpioSetDir(ILI9325_CD_PORT, ILI9325_CD_PIN, 1);
      gpioSetDir(ILI9325_WR_PORT, ILI9325_WR_PIN, 1);
      gpioSetDir(ILI9325_RD_PORT, ILI9325_RD_PIN, 1);
      // Set data port pins to output
      // Disable pullups
      ILI9325_DISABLEPULLUPS();
      // Set backlight pin to input and turn it on
      gpioSetDir(ILI9325_BL_PORT, ILI9325_BL_PIN, 1);      // set to output
      lcdBacklightOn();
      // Set reset pin to output
      gpioSetDir(ILI9325_RES_PORT, ILI9325_RES_PIN, 1);    // Set to output
      gpioSetValue(ILI9325_RES_PORT, ILI9325_RES_PIN, 0);  // Low to reset
      systickDelay(50);
      gpioSetValue(ILI9325_RES_PORT, ILI9325_RES_PIN, 1);  // High to exit
      // Initialize the display
      ili9325InitDisplay();
      // Fill black
      lcdFillRGB(COLOR_BLACK);
      // Initialise the touch screen (and calibrate if necessary)
      tsInit();
    void lcdBacklightOn(void)
      // Enable backlight
      gpioSetValue(ILI9325_BL_PORT, ILI9325_BL_PIN, 0);
    void lcdBacklightOff(void)
      // Disable backlight
      gpioSetValue(ILI9325_BL_PORT, ILI9325_BL_PIN, 1);
    void lcdTest(void)
      uint32_t i,j;
      ili9325Home();
      for(i=0;i<320;i++)
        for(j=0;j<240;j++)
          if(i>279)ili9325WriteData(COLOR_WHITE);
          else if(i>239)ili9325WriteData(COLOR_BLUE);
          else if(i>199)ili9325WriteData(COLOR_GREEN);
          else if(i>159)ili9325WriteData(COLOR_CYAN);
          else if(i>119)ili9325WriteData(COLOR_RED);
          else if(i>79)ili9325WriteData(COLOR_MAGENTA);
          else if(i>39)ili9325WriteData(COLOR_YELLOW);
          else ili9325WriteData(COLOR_BLACK);
    void lcdFillRGB(uint16_t data)
      unsigned int i;
      ili9325Home();
      uint32_t pixels = 320*240;
      for ( i=0; i < pixels; i++ )
    void lcdDrawPixel(uint16_t x, uint16_t y, uint16_t color)
      ili9325WriteCmd(0x0020); // GRAM Address Set (Horizontal Address) (R20h)
      ili9325WriteData(x);
      ili9325WriteCmd(0x0021); // GRAM Address Set (Vertical Address) (R21h)
      ili9325WriteData(y);
      ili9325WriteData(color);
    void lcdDrawHLine(uint16_t x0, uint16_t x1, uint16_t y, uint16_t color)
      // Allows for slightly better performance than setting individual pixels
      uint16_t x, pixels;
      if (x1 < x0)
        // Switch x1 and x0
        x = x1;
        x1 = x0;
        x0 = x;
      ili9325WriteData(x0);
      for (pixels = 0; pixels < x1 - x0 + 1; pixels++)
    uint16_t lcdGetPixel(uint16_t x, uint16_t y)
      uint16_t preFetch = 0;
      ili9325SetCursor(x, y);
      preFetch = ili9325ReadData();
      // Eeek ... why does this need to be done twice for a proper value?!?
    void lcdScroll(int16_t pixels, uint16_t fillColor)
      // Note: Not all ILI9325 imitations support HW vertical scrolling!
      // ST7781 - Not supported (ex. RFTechWorld 2.8" displays)
      // OTM3225A - Supported
      int16_t y = pixels;
      while (y < 0)
        y += 320;
      while (y >= 320)
        y -= 320;
      ili9325WriteCmd(0x6A);
    edited 2011-11-15 20:16
    Dr_Acula wrote: »
    Hi Dr_A,
    Apart from the obviously non-portable stuff, it should compile - but it may not run fast enough to be useful. This would be better (and probably much simpler) to write as a PASM plugin - and even then you'd have trouble achieving the kinds of speeds mentioned in the code comments. This code would seem to have been originally written for a faster processor - do you know what it runs on?
    In general, when you see C code written quite that badly, it's usually a sign that it has been rewritten in C after being developed in another language - in this case, most likely it was originally written in assembler. There are even comments in there to the effect that "this function should not be used because it adds an extra branch instruction" - if the timing is that critical, it means assembler is probably the answer.
    Ross.
    edited 2011-11-15 20:59
    Good point. I have the display drivers in C for the existing VGA/TV drivers and generally it is easier to debug in C and then port things over to pasm once they are working. That code above would probably fit in a cog. Then you could do things like move a picture from sd card to hub ram, then another routine to tell a cog where the picture is in hub, and then fire off a cog routine to move that data out to the display.
    Hopefully it should be possible to build it up in blocks of code so that you can do a 'printf" in a variety of fonts/font sizes etc.
    edited 2011-11-16 01:44
    All,
    I have just uploaded the source for the version of Code::Blocks that supports Catalina to SourceForge (here). This includes the source for the updated Compiler plugin with Catalina compiler support.
    Anyone who is having trouble installing Code::Blocks (like those reported on Ubuntu by pinedust) can now rebuild Code::Blocks from source instead of using the binary version included in the various Catalina downloads.
    Ross.
    edited 2011-11-16 07:13
    RossH wrote: »
    All,
    Ross.
    Ross,
    This version works great!
    Thank you!
    edited 2011-11-19 17:27
    All,
    Earlier in this thread, Jazzed asked for a loader that included serial terminal capability so that users would not need to open a separate terminal emulator window. I can see this would be very useful for boards (like the Parallax QuickStart board) which have no keyboard, TV or VGA ports - so I have now added this capability to payload.
    Payload now has an interactive mode (enabled via -i) that makes it act as a simple terminal emulator once the program has been downloaded. This simplifies loading and running programs for those who use the PC HMI option (which does all stdio via a serial port on pins 30 & 31).
    I have added the new executable to the second post in this thread (Windows only at this stage!).
    Here is how you might use it:
    catalina othello.c -lc -D PC
    payload othello -i
    Note the addition of -D PC to the catalina command (to tell catalina to compile the program to use the PC terminal emulator HMI option) and the addition of the -i to the payload command (to tell payload to enter the interactive mode when the download has completed).
    To exit the interactive terminal mode, just press CTRL+D (i.e. the EOT character) at any time.
    Note that interactive mode can be used with any Catalina program (i.e. LMM or XMM) and also with any Spin binary (compiled to use the normal Parallax serial port at 115200 baud).
    To use interactive mode from within Code::Blocks, just select Tools-> Configure tools... and add the new -i option to the relevant tool parameters (e.g. to the Download to Hub RAM tool)
    If anyone has any problems with the interactive mode, or any suggestions for improvements, please let me know.
    Ross.
    edited 2011-11-19 23:12
    This is a nice and welcome feature Ross. I will let you know how I go with it in a few days.
    edited 2011-11-22 14:48
    All,
    I'm having some trouble with the Linux version of the new Payload loader (specifically, with the interactive terminal mode). I am almost sure it is because I run Linux in a virtual machine - but I just need to confirm this.
    I don't want to release the code until I'm sure it is working, so I need a few Catalina Linux users (I know there aren't many in these forums!) willing to run a simple test. You just need to have Catalina 3.4 installed, and have Linux installed "natively" (i.e. not in a virtual machine).
    Please send me a PM (with you email address) and I will post you an executable and some instructions on the test I need run - it will only take a couple of minutes.
    Thanks!
    Ross.
    edited 2011-11-22 15:05
    RossH wrote: »
    All,
    Thanks!
    Ross.
    In case you're interested, here is the terminal code I use in propeller-load.
    #define ESC     0x1b    /* escape from terminal mode */
     * simple terminal emulator
    extern int check_for_exit;
    void terminal_mode(void)
        struct termios oldt, newt;
        char buf[128];
        ssize_t cnt;
        fd_set set;
        int exit_char = 0xdead; /* not a valid character */
        int sawexit_char = 0;
        int sawexit_valid = 0;
        int exitcode = 0;
        int continue_terminal = 1;
        tcgetattr(STDIN_FILENO, &oldt);
        newt = oldt;
        newt.c_lflag &= ~(ICANON | ECHO);
        tcsetattr(STDIN_FILENO, TCSANOW, &newt);
        if (check_for_exit)
    	exit_char = 0xff;
    #if 0
        /* make it possible to detect breaks */
        tcgetattr(hSerial, &newt);
        newt.c_iflag &= ~IGNBRK;
        newt.c_iflag |= PARMRK;
        tcsetattr(hSerial, TCSANOW, &newt);
    #endif
        do {
            FD_ZERO(&set);
            FD_SET(hSerial, &set);
            FD_SET(STDIN_FILENO, &set);
            if (select(hSerial + 1, &set, NULL, NULL, NULL) > 0) {
                if (FD_ISSET(hSerial, &set)) {
    	        if ((cnt = read(hSerial, buf, sizeof(buf))) > 0) {
    		    int i;
    		    // check for breaks
    		    ssize_t realbytes = 0;
    		    for (i = 0; i < cnt; i++) {
    		      if (sawexit_valid)
    			  exitcode = buf[i];
    			  continue_terminal = 0;
    		      else if (sawexit_char) {
    			if (buf[i] == 0) {
    			  sawexit_valid = 1;
    			} else {
    			  buf[realbytes++] = exit_char;
    			  buf[realbytes++] = buf[i];
    			  sawexit_char = 0;
    		      } else if (((int)buf[i] & 0xff) == exit_char) {
    			sawexit_char = 1;
    		      } else {
    		    write(fileno(stdout), buf, realbytes);
                if (FD_ISSET(STDIN_FILENO, &set)) {
                    if ((cnt = read(STDIN_FILENO, buf, sizeof(buf))) > 0) {
                        int i;
                        for (i = 0; i < cnt; ++i)
                            if (buf[i] == ESC)
                                goto done;
                        write(hSerial, buf, cnt);
        } while (continue_terminal);
    done:
        tcsetattr(STDIN_FILENO, TCSANOW, &oldt);
        if (sawexit_valid)
    	exit(exitcode);
    edited 2011-11-22 16:17
    Ross - I think some time ago you posted something about running Spin and C together. I was wondering - is it possible to run two C threads at the same time? Let's say, hypothetically, that each thread had access to half the hub ram and 4 cogs. Or, if that is too complicated, one thread is the Input/Output thread which would handle keyboard/mouse/display via stdio, and the other thread talks to the I/O thread via common hub memory?
    What I am thinking of is an 'operating system' thread that handles input and output, and a 'program' thread where programs can be loaded and unloaded. Or more specifically, I am trying to write a program in C and it ends up with huge overheads running OS type stuff like loading in fonts from sd card and putting them on a display, and it may be easier to split the task into two.
    I'm doing some experiments with 320x240 displays and these have their own internal memory, so this has opened up a whole new way of doing things because no hub is needed for a screen buffer, so essentially all the hub is free.
    If the above is possible, is it also possible to have separate caches for each thread? Maybe 4k for each or something?
    edited 2011-11-22 16:19
    Ross, how much of ctime does Catalina include?
    Is it everything in the usual time.h?
