PING))) doesn't work while moving, even a little?
I'm trying to use a PING))) on a robot platform that can drive around and the PING))) is mounted on a pan-tilt servo pair. If there is even a slight amount of movement I usually don't receive a response, the pulseIn call times out and returns a 0. Is that expected? I'm using the Arduino example code at http://www.arduino.cc/en/Tutorial/Ping
moves the PING continuously and generates a nice onscreen DEBUG display. One of my favorite app notes.
So it seems to be something about the small servos that I bought from Sparkfun ( http://www.sparkfun.com/products/9065 )
When they are plugged in and trying to move, that's when the ultrasonic sensor seems to time out a lot. These servos have other problems where they don't have a full 180 degrees range of motion, sometimes become stuck in place until I physically nudge them, etc... After unplugging them the ultrasonic sensor seemed to work fine, and now I'm just moving the whole robot to sweep and it's good. Also I noticed that sometimes when getting close to the ultrasonic sensor, even when I'm not writing any new positions to the servos, one of them would twitch, so I think they have some kind of electronic interference problem or something, I'm not sure.
Either way, I'm pretty sure the ultrasonic sensor is good. Thanks again for the help.
Diode V+ Source >--->|--o------------> V+ Servo | + 100uF o----||--o | Vss(GND) >-----------------o---> Servo GroundEdit... if erco's suggestion above works, then you can more than likely use the Diode capacitor filter for a single supply.
